r.lyons@_BOGUS_ieee.org (Rick Lyons) wrote in message > So Dan, please don't be upset. And please know> that anyone who takes the time and trouble to > write tutorials for their colleagues has our > admiration and gratitude. That means you Dan. > > Gosh don't worry about your English, your English > is fine. And I can see that you and I have > about equal skill in spelling. :-) > > Regards, > [-Rick-]OK Rick. I know my English is terrible. Regarding the content, I can see how one can get confused. First we filter, than we do sample and hold. We learn that pre-filtering is the solution to aliasing, so we think of it as removal of high frequencies folding into the base band. True indeed. But the action of sampling itself makes for the high frequency image energy. Now here is the "split point". I as a real hand on engineer, have a lot of interest in the sample hold output signal, and that signal contains a lot of high frequency energy. But someone else may wish to view it as a series of numbers. That person, the "numbers" person, will have to encounter that picture - the steps and "staircases" at the DA side, a place where there is high frequncy energy typicaly filtered by some anti imaging filter. I guess it is not trevial to figure what happens first and what is last. Regards Dan Lavry
CAUTION! was "What is the advantage on high-sampling rate ?"
Started by ●April 23, 2004
Reply by ●April 24, 20042004-04-24
Jerry Avins wrote:> dan lavry wrote: > >> r.lyons@_BOGUS_ieee.org (Rick Lyons) wrote in message >> news:<408922bf.1261440968@news.sf.sbcglobal.net>... >> >>> Hi Guys, >>> in a recent thread, mention was made of a "Sampling" paper by Dan >>> Lavry. At the following web site >>> >>> http://www.lavryengineering.com/pdfs/sample.pdf >>> >>> you can see Dan's 1997 paper: >>> "Sampling, Oversampling, Imaging and Aliasing - a basic tutorial". >>> >>> >>> I recommend caution if you decide to >>> read that paper. In the second paragraph Dan wrote: >> >> >> >> I am showing what happens when you you sample without antialiasing >> filter, and when you do so, you get high frequency images. I do so >> INTENTIONALY to show the need for anti aliasing filters ahead of the >> AD converters. I later explain that the enrgy folds into the base >> band. I meant it to be a stepping stone, and sorry if it ended up >> being confusing. > > > ... > > Until now, I thought I understood. I saw a properly sampled signal > reflected around the sampling frequency and the whole thing repeated up > and up ... > > How does an anti-alias filter before the ADC come into that? > > JerryThe sampling process ends up being the mathematical equivalent of multiplying the signal by a train of dirac delta functions (impulses). In the frequency domain this has the effect of reproducing the frequency an infinite amount of times, with each copy centered on the sampling rate, so if the original signal x(t) has a frequency-domain representation X(w) then the sampled signal looks like: X_s(w) = sum(X(w + w_s * n)) from x = -infinity to x = infinity, where w_s = 2*pi/T_s (radians/sec), T_s = sampling rate. This means that if X(w) has a bandwidth bigger than 1/T_s (Hertz) parts of it will "fold over" the sampling frequency -- this is aliasing. If you don't want aliasing you have to low-pass filter your baseband signal to 1/(2T_s) to account for the positive and negative frequency components when you translate things into mathemagic land. Nyquist's theory basically stated that if the signal going _into_ sampling is perfectly band-limited then you can build a perfect reconstruction filter and get the whole thing back unmolested, which is why 1/(2T_s) is called the Nyquist Frequency. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Reply by ●April 25, 20042004-04-25
Tim Wescott wrote: ...>>> I am showing what happens when you you sample without antialiasing >>> filter, and when you do so, you get high frequency images. I do so >>> INTENTIONALY to show the need for anti aliasing filters ahead of the >>> AD converters. I later explain that the enrgy folds into the base >>> band. I meant it to be a stepping stone, and sorry if it ended up >>> being confusing. >> >> >> >> ... >> >> Until now, I thought I understood. I saw a properly sampled signal >> reflected around the sampling frequency and the whole thing repeated up >> and up ... >> >> How does an anti-alias filter before the ADC come into that? >> >> Jerry > > > The sampling process ends up being the mathematical equivalent of > multiplying the signal by a train of dirac delta functions (impulses). > In the frequency domain this has the effect of reproducing the frequency > an infinite amount of times, with each copy centered on the sampling > rate, so if the original signal x(t) has a frequency-domain > representation X(w) then the sampled signal looks like: > > X_s(w) = sum(X(w + w_s * n)) from x = -infinity to x = infinity, where > w_s = 2*pi/T_s (radians/sec), T_s = sampling rate.Quite.> This means that if X(w) has a bandwidth bigger than 1/T_s (Hertz) parts > of it will "fold over" the sampling frequency -- this is aliasing. If > you don't want aliasing you have to low-pass filter your baseband signal > to 1/(2T_s) to account for the positive and negative frequency > components when you translate things into mathemagic land.Sure.> Nyquist's theory basically stated that if the signal going _into_ > sampling is perfectly band-limited then you can build a perfect > reconstruction filter and get the whole thing back unmolested, which is > why 1/(2T_s) is called the Nyquist Frequency.That's all true, but it's not what the frequency plots seem to indicate. They shoe the spectrum of the series of, if not Kroneker deltas, at least very narrow pulses. The illustration seems to be not of aliasing of out-of-band signals into the passband, but reflection and repetition of the signal about the sampling frequency and multiples of it. As I see it, anti-alias filtering has no connection with that. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
robert bristow-johnson wrote:> > this is very reminiscent of that periodic argument we've have about whether > or not the DFT inherently periodically extends the finite set of input data. > from the purest, simplest mathematical definition, it's pretty clear (to me, > at least, perhaps to Tim, and also to the O&S discussion of the topic) that > the DFT *does* inherently periodically extend the finite length input. i.e. > the DFT views your input data as one period of a discrete periodic function > of "time" and returns one period of a discrete periodic function in the > "frequency" domain. > > lessee how folks react to that. >Despite strong beliefs to the contrary, I swore off that arguement. :-) Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
On Sat, 24 Apr 2004 17:39:38 -0700, Tim Wescott <tim@wescottnospamdesign.com> wrote: (snipped)> >The sampling process ends up being the mathematical equivalent of >multiplying the signal by a train of dirac delta functions (impulses). >In the frequency domain this has the effect of reproducing the frequency >an infinite amount of times, with each copy centered on the sampling >rate, so if the original signal x(t) has a frequency-domain >representation X(w) then the sampled signal looks like: > >X_s(w) = sum(X(w + w_s * n)) from x = -infinity to x = infinity, where >w_s = 2*pi/T_s (radians/sec), T_s = sampling rate. > >This means that if X(w) has a bandwidth bigger than 1/T_s (Hertz) parts >of it will "fold over" the sampling frequency -- this is aliasing. If >you don't want aliasing you have to low-pass filter your baseband signal >to 1/(2T_s) to account for the positive and negative frequency >components when you translate things into mathemagic land. >Hi, "fold over" is probably not the best phrase to use here. "Fold over" is a phrase people use to describe the freq-domain characteristics of discrete signals (sequences). And as I realized, Dan's discussion is strictly about continuous (analog) signals. Instead of "fold over", I'd call it "overlapped spectral replications". I'm just being nit picky Tim. [-Rick-]
Jerry Avins <jya@ieee.org> wrote in message news:<408b2d86$0$28910> > Nyquist's theory basically stated that if the signal going _into_> > sampling is perfectly band-limited then you can build a perfect > > reconstruction filter and get the whole thing back unmolested, which is > > why 1/(2T_s) is called the Nyquist Frequency. > > That's all true, but it's not what the frequency plots seem to indicate. > They shoe the spectrum of the series of, if not Kroneker deltas, at > least very narrow pulses. The illustration seems to be not of aliasing > of out-of-band signals into the passband, but reflection and repetition > of the signal about the sampling frequency and multiples of it. As I see > it, anti-alias filtering has no connection with that. > > JerryI agree with Jerry. In my paper, I just started with 4 inband (under Nyquist) sine. Of corse I could have included an antialiasing filter, but that is not where the high frequency source is. It is the sample hold. One may choose to view it as numbers, but a "hardware guy" needs to view it as a physical entity - a signal that can be measured with a scope (time domain), a spectrum analyzer (frquency waves) and other means. Say you take a 1KHz sine wave and do a sample hold operation at 44.1KHz. Each sampled 1KHz cycles is made out of 441 little steps. A step is a "sharp edge", a "sharp corner" on a time domain plot, and "those things" require a signal infinite bandwidth. Of corse one does not get perfect square waves. The rise time of each step is not vertical, it is usualy exponetial (capacitor charing or discharging). The exponent does not ever start as an abrupt corner, because real hardware does not have infinit bandwidth (it is sort of rounded where the corner should be in theory). But the point is - the real actual signal has high frequency content due to the sample hold action. Is it importent to make that point? It is if you design hardware or measure hardware. The front end sample hold is a very imortant circuit. This is where timing jitter has its bad impact. This is where your cap value seems too small from leakage (holding charge) and feed through (unwanted signals coupled in capacitivly) the point of view, but raising the capacitance will prevent it from charging fully to the new valu (under maximim slew rate conditions). So a hardware guy can not view the final (charged capacitor) per sample as a "number", or "sample value". I guess a DSP person may choose to view it as a number. What is the relationship between a series of numbers to frequncy content? Well, the DSP code person may choose to "not think about it", but the DA desiger will have to deal with real signals with high frequency content, thus scopes, spectrum analyzers analog filters... BR Dan Lavry
robert bristow-johnson wrote:> In article N8-dnUQz4eUnxRTdRVn-hA@centurytel.net, Fred Marshall at > fmarshallx@remove_the_x.acm.org wrote on 04/23/2004 13:56: > > ...-- snip --> this is very reminiscent of that periodic argument we've have about whether > or not the DFT inherently periodically extends the finite set of input data. > from the purest, simplest mathematical definition, it's pretty clear (to me, > at least, perhaps to Tim, and also to the O&S discussion of the topic) that > the DFT *does* inherently periodically extend the finite length input. i.e. > the DFT views your input data as one period of a discrete periodic function > of "time" and returns one period of a discrete periodic function in the > "frequency" domain. > > lessee how folks react to that. > > r b-j > >Oh hell, I'll bite. The action of sampling a signal (_not_ taking it's DFT) makes your data appear as one period of a theoretically infinite number of periods _in frequency_. The action of "sampling" your signal _in frequency_ makes your time-domain data appear to be one period of a theoretically infinite number of periods _in time_. In fact, you can prove this mathematically: Take a periodic signal and "window" it down to one period in time. Now take it's Fourier transform -- you get a result that's continuous in frequency, and extends to infinite frequency in both directions. Now allow the window to be exactly two periods, but divide the signal by 2 -- your result is still continuous in frequency, but it's starting to develop peaks. Now take the Fourier transform of N periods, times 1/N, and take the limit as N goes to infinity -- you get a Foirier transform that's a train of impulses at the harmonics of the fundamental, with zero energy between them. You can use this to prove that it's periodic in one domain if and only if it's a train of impulses in the other. So the DFT is (mathematically) a periodic train of impulses in both domains. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
robert bristow-johnson wrote: (snip)> this is very reminiscent of that periodic argument we've have about whether > or not the DFT inherently periodically extends the finite set of input data. > from the purest, simplest mathematical definition, it's pretty clear (to me, > at least, perhaps to Tim, and also to the O&S discussion of the topic) that > the DFT *does* inherently periodically extend the finite length input. i.e. > the DFT views your input data as one period of a discrete periodic function > of "time" and returns one period of a discrete periodic function in the > "frequency" domain.I agree. Just like the Fourier series did a long time ago. -- glen
Jerry Avins wrote:> Tim Wescott wrote: > > ... > >>>> I am showing what happens when you you sample without antialiasing >>>> filter, and when you do so, you get high frequency images. I do so >>>> INTENTIONALY to show the need for anti aliasing filters ahead of the >>>> AD converters. I later explain that the enrgy folds into the base >>>> band. I meant it to be a stepping stone, and sorry if it ended up >>>> being confusing. >>> >>> >>> >>> >>> ... >>> >>> Until now, I thought I understood. I saw a properly sampled signal >>> reflected around the sampling frequency and the whole thing repeated up >>> and up ... >>> >>> How does an anti-alias filter before the ADC come into that? >>> >>> Jerry >> >> >> >> The sampling process ends up being the mathematical equivalent of >> multiplying the signal by a train of dirac delta functions (impulses). >> In the frequency domain this has the effect of reproducing the >> frequency an infinite amount of times, with each copy centered on the >> sampling rate, so if the original signal x(t) has a frequency-domain >> representation X(w) then the sampled signal looks like: >> >> X_s(w) = sum(X(w + w_s * n)) from x = -infinity to x = infinity, where >> w_s = 2*pi/T_s (radians/sec), T_s = sampling rate. > > > Quite. > >> This means that if X(w) has a bandwidth bigger than 1/T_s (Hertz) >> parts of it will "fold over" the sampling frequency -- this is >> aliasing. If you don't want aliasing you have to low-pass filter your >> baseband signal to 1/(2T_s) to account for the positive and negative >> frequency components when you translate things into mathemagic land. > > > Sure. > >> Nyquist's theory basically stated that if the signal going _into_ >> sampling is perfectly band-limited then you can build a perfect >> reconstruction filter and get the whole thing back unmolested, which >> is why 1/(2T_s) is called the Nyquist Frequency. > > > That's all true, but it's not what the frequency plots seem to indicate. > They shoe the spectrum of the series of, if not Kroneker deltas, at > least very narrow pulses. The illustration seems to be not of aliasing > of out-of-band signals into the passband, but reflection and repetition > of the signal about the sampling frequency and multiples of it. As I see > it, anti-alias filtering has no connection with that. > > Jerry >That reflection and repetition of the signal around the sampling frequency and it's harmonics _is_ aliasing -- that's how a signal at 5/8 of the sample frequency ends up at 3/8 of the sample frequency (and 5/8, and 1-3/8, and 1-5/8, etc.). Since it's usually undesirable it's what drives the need for an anti-aliasing filter. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Reply by ●April 26, 20042004-04-26
In article 108o7mfh158eb95@corp.supernews.com, Tim Wescott at tim@wescottnospamdesign.com wrote on 04/25/2004 16:26:> robert bristow-johnson wrote: > >> In article N8-dnUQz4eUnxRTdRVn-hA@centurytel.net, Fred Marshall at >> fmarshallx@remove_the_x.acm.org wrote on 04/23/2004 13:56: >> >> ... > -- snip -- >> this is very reminiscent of that periodic argument we've have about whether >> or not the DFT inherently periodically extends the finite set of input data. >> from the purest, simplest mathematical definition, it's pretty clear (to me, >> at least, perhaps to Tim, and also to the O&S discussion of the topic) that >> the DFT *does* inherently periodically extend the finite length input. i.e. >> the DFT views your input data as one period of a discrete periodic function >> of "time" and returns one period of a discrete periodic function in the >> "frequency" domain. >> >> lessee how folks react to that.> Oh hell, I'll bite.BWAA-HA-HA-HA-HA!> The action of sampling a signal (_not_ taking it's DFT) makes your data > appear as one period of a theoretically infinite number of periods _in > frequency_.i agree, but not quite completely. the language i would use that that the action of sampling a continuous-time signal has the effect of periodically extending its spectrum in the frequency domain by shifting the spectrum by all integer multiples of Fs, overlapping, and summing (this would cause aliasing if B is not less than Fs/2). (there is a scaling issue also, the "T" or "1/Fs" factor, but i don't wanna slug that out now since it has been *many* times before.) where i think i substantively disagree with your semantic is in the inclusion of the words "one period of". i would delete those words in your statement to be fully accurate.> The action of "sampling" your signal _in frequency_ makes your > time-domain data appear to be one period of a theoretically infinite > number of periods _in time_.same sentiment of agreement and disagreement.> In fact, you can prove this mathematically: > > Take a periodic signal and "window" it down to one period in time.okay, fine. but the DFT (or the plain ol' FT) doesn't do that. the operation of windowing (and what it does to your spectrum) is a separate operation done before the DFT or FT sees the data.> Now take it's Fourier transform -- you get a result that's continuous > in frequency, and extends to infinite frequency in both directions.yup.> Now > allow the window to be exactly two periods, but divide the signal by 2 > -- your result is still continuous in frequency, but it's starting to > develop peaks. Now take the Fourier transform of N periods, times 1/N, > and take the limit as N goes to infinity -- you get a Foirier transform > that's a train of impulses at the harmonics of the fundamental, with > zero energy between them.sure. i'll drink to that.> You can use this to prove that it's periodic in one domain if and only > if it's a train of impulses in the other. So the DFT is > (mathematically) a periodic train of impulses in both domains.oh, i thought we had a disagreement brewing here. i should read the whole damn USENET post before i hit "Reply to Newsgroup". never mind. (actually, i would say the DFT and iDFT works on "numbers", not "impulses". the DFT is a discrete-time and discrete-frequency thingie whose domains have no impulses. in these domains, there is no "between them" for there to be zero energy. i think i'm being more anal in my semantics than what you're saying, Tim.) another way i might word it is that the DFT transforms a periodic discrete function (or "periodic sequence") of infinite length and period N (of which you need only specify one period or N numbers) to another periodic sequence of infinite length and period N and the iDFT transforms it back. Tim, multiple times in the past 9 years, we have had this topic tossed around and i have taken a fairly rigid stand about it because i think it *should* be sorta uncontroversial (sorta like the MATLAB index base issue or where the "T" or "1/T" scaling factor belongs in the sampling/reconstruction theorem, or the dimension of the dependent variable of a Dirac impulse in time). but i have certainly found out different (about the controversy, not my position on this stuff, which is pretty firm) and have the singe marks to show for it. a few very respectable folks on comp.dsp (like R. Cain and A. Hey, IIRC) have staunchly disagreed with one thing or 'nother. r b-j
