On Mar 1, 11:16 am, "maxplanck" <erik.bo...@comcast.net> wrote:> Thanks for clarifying Dale. > > I started searching through the IEEE database, and there are many articles > on instantaneous frequency calculation from the 90's.In the Letters on Signal Processing there are 10. Two of them have 'multcomponent' in the title. Try them first. Dale B. Dalrymple
Calculating instantaneous phase of a simple signal
Started by ●February 29, 2008
Reply by ●March 1, 20082008-03-01
On Mar 1, 12:15 pm, "maxplanck" <erik.bo...@comcast.net> wrote:> I have a signal composed of three sine waves added together, each sine wave > having constant frequency and amplitude. Each sine wave's frequency and > amplitude is different from that of the other two. > > I want to reproduce this signal using only ONE sine oscillator, of > variable amplitude and constant frequency. I know that the desired signal > reproduction can be accomplished using only one sine wave of constant > frequency, because it can be derived that for a successful signal > reproduction using only one sine wave the frequency of this lone sine wave > MUST be constant.Calulate the phase that you define in your plot file. Use phase differences to calculate the frequency of your combined signal. It is not constant, so no single frequency oscillator will generate your signal.> What Dale said confirmed this as well.What I confirmed is that no reasonable instantaneous frequency will recreate your signal in the manner you wish. Your signal is not simple enough to have that meaningful an instantaneous frequency.> > I have already calculated the amplitude envelope that would need to be > applied to the lone sine wave. Now all I need to do is calculate the > frequency that this lone sine wave would have to oscillate at in order for > it to equal the original "three summed sine wave" signal.Use the phase increments I suggested you calculate to modulate the frequency of your oscillator as well as the amplitude to reconstruct your signal.> > Thanks for responding >Dale B. Dalrymple
OK, thanks for setting me straight here. I was hoping to avoid using these numerical methods because of the small error inherent in them, but since you're suggesting them I'm assuming that they're the best solution available. Right? The IEEE Letters don't suggest a more exact method, right?>> I have a signal composed of three sine waves added together, each sinewave>> having constant frequency and amplitude. Each sine wave's frequencyand>> amplitude is different from that of the other two. >> >> I want to reproduce this signal using only ONE sine oscillator, of >> variable amplitude and constant frequency. I know that the desiredsignal>> reproduction can be accomplished using only one sine wave of constant >> frequency, because it can be derived that for a successful signal >> reproduction using only one sine wave the frequency of this lone sinewave>> MUST be constant. > >Calulate the phase that you define in your plot file. Use phase >differences to calculate the frequency of your combined signal. It is >not constant, so no single frequency oscillator will generate your >signal. > >> What Dale said confirmed this as well. > >What I confirmed is that no reasonable instantaneous frequency will >recreate your signal in the manner you wish. Your signal is not simple >enough to have that meaningful an instantaneous frequency. > >> >> I have already calculated the amplitude envelope that would need to be >> applied to the lone sine wave. Now all I need to do is calculate the >> frequency that this lone sine wave would have to oscillate at in orderfor>> it to equal the original "three summed sine wave" signal. > >Use the phase increments I suggested you calculate to modulate the >frequency of your oscillator as well as the amplitude to reconstruct >your signal. > >> >> Thanks for responding >> > >Dale B. Dalrymple > >
On Mar 1, 3:06 pm, "maxplanck" <erik.bo...@comcast.net> wrote:> OK, thanks for setting me straight here. > > I was hoping to avoid using these numerical methods because of the small > error inherent in them, but since you're suggesting them I'm assuming that > they're the best solution available. Right? > > The IEEE Letters don't suggest a more exact method, right? >Since you have given us no requirements information, specifications or goals to use as a basis, the term 'best' can't be evaluated. You might generate your signal by scaling and summing three oscillators. The topic of such sinusoidal generators and their characteristics has been discussed frequently in this group. Dale B. Dalrymple
I just want my one oscillator reproduction to match the original 3 oscillator signal, sample for sample, as close as possible. The closer I can get, the better, and computational expensiveness is not an issue (it can be as expensive as it needs to be to produce the closest match possible). My whole point in doing this is to reproduce the three oscillator signal using only one oscillator. To use more than one oscillator in the reproduction would defeat the purpose. I've refrained from explaining the purpose beyond this because it will just make the discussion more confusing. But if you want me to try to explain, let me know and i'll try. In the interest of simplicity, my entire goal can be succinctly stated as: I have a signal composed of three sine waves added together, each sine wave having constant frequency and amplitude. Each sine wave's frequency and amplitude is different from that of the other two. I want to reproduce this signal using only ONE sine oscillator, of variable amplitude and frequency. The single oscillator reproduction should match the original 3 oscillator signal, sample for sample, as close as possible. The closer I can get, the better, and computational expensiveness is not an issue (it can be as expensive as it needs to be to produce the closest match possible).>Since you have given us no requirements information, specifications or >goals to use as a basis, the term 'best' can't be evaluated. > >You might generate your signal by scaling and summing three >oscillators. The topic of such sinusoidal generators and their >characteristics has been discussed frequently in this group. > >Dale B. Dalrymple >
maxplanck wrote: ...> In the interest of simplicity, my entire goal can be succinctly stated > as: > > I have a signal composed of three sine waves added together, each sine > wave > having constant frequency and amplitude. Each sine wave's frequency and > amplitude is different from that of the other two. > > I want to reproduce this signal using only ONE sine oscillator, of > variable amplitude and frequency. > > The single oscillator reproduction should match the original 3 oscillator > signal, sample for sample, as close as possible. The closer I can get, > the better, and computational expensiveness is not an issue (it can be as > expensive as it needs to be to produce the closest match possible).Out of curiosity, why do you want to do this? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
The 3 oscillator signal sounds interesting to the ears when played through a speaker. I want to understand it in terms that the brain/ears can most easily understand, which I think are for this signal: frequency and amplitude of a single sine oscillator. I think this because the signal is of a very small bandwidth, and the generation method involves only sine waves (no noise). This type of signal will probably lend itself to representation through a single sine oscillator nicely. If I can reproduce this signal using one sine oscillator with frequency and amplitude each controlled by a 2-d plot, then I can better understand why the sound is interesting to the ears. Then, the best part, is that representation of the sound in this way is easily manipulable in terms that the brain/ears instinctively understand (frequency and amplitude.)>Out of curiosity, why do you want to do this? > >Jerry >-- >Engineering is the art of making what you want from things you can get. >����������������������������������������������������������������������� >
Incidentally, here's an idea that I had that that may or may not be useful, maybe you guys can tell me your thoughts about it: I know that signal = A*sin(2*pi*f*t) Where f is the instantaneous frequency of the signal and A is the amplitude envelope of the signal. At first glance, I thought that I could then simply say: signal/A = sin(2*pi*f*t) then asin(signal/A) = 2*pi*f*t and then 1/(2*pi*t) * asin(signal/A) = f But when I plot f, it does not match my numerically calculated instantaneous frequency (which was calculated by taking diff(phase) in scilab, i.e. calculating the slope of the tangent line between each of phase's adjacent data points). I think that this must have something to do with the fact that asin(sin(x)) does not equal x if x > pi/2. Does this ring any bells? Any idea how to get past this, to calculate the instantaneous frequency f? Thanks a lot for continuing to respond guys
Reply by ●March 2, 20082008-03-02
"maxplanck" <erik.bowen@comcast.net> wrote in message news:Y_adnfsn8t0WhFfanZ2dnUVZ_oesnZ2d@giganews.com...> > I know that > > signal = A*sin(2*pi*f*t) > > Where f is the instantaneous frequency of the signal and A is > the > amplitude envelope of the signal. > > At first glance, I thought that I could then simply say: > > signal/A = sin(2*pi*f*t) > > then > > asin(signal/A) = 2*pi*f*t > > and then > > 1/(2*pi*t) * asin(signal/A) = fIt's Sunday morning and my Aspirin hasn't kicked in yet but: -pi/2 <= 2*pi*f*t <= pi/2, -1/(4*f) <= t <= 1/(4*f), 0 <= t + 1/(4*f) <= 1/(2*f), so replace t with T where: T = {[t + 1/(4*f)] modulo [1/(2*f)]} - 1/(4*t). For example: T = 0; while (1) { signal = getSignal(); f = 1/(2*pi*T)) * asin(signal/A); T = T + dT; while(T > (1/(2*f))) T -= 1/(2*f); } Note: I really don't see this going anywhere for a general, composite "signal" with a time-varying A. It seems to me that the math is only valid where "signal" is a pure sine with a known, fixed A, so I wonder what the real-world application might be.
On Sat, 01 Mar 2008 14:15:41 -0600, maxplanck <erik.bowen@comcast.net> wrote:>I have a signal composed of three sine waves added together, each >sine wave having constant frequency and amplitude. Each sine wave's >frequency and amplitude is different from that of the other two.I had better admit up front that I'm not a DSP expert; I just spend a lot of time listening and learning here. It sounds like you start with a signal S you assume to be composed of three individual scaled-and-perhaps-phase-shifted pure sine waves of frequencies f1, f2, and f3: S(t) = (k1 + sin(t * (2*%pi)/f1)) + (k2 + sin(t * (2*%pi)/f2)) + (k3 + sin(t * (2*%pi)/f3)) Since you don't specify any relationship between f1, f2, and f3, I'll assume there may not be / isn't one.>I want to reproduce this signal using only ONE sine oscillator, of >variable amplitude and constant frequency. I know that the desired >signal reproduction can be accomplished using only one sine wave of >constant frequency, because it can be derived that for a successful >signal reproduction using only one sine wave the frequency of this >lone sine wave MUST be constant. What Dale said confirmed this as >well. > >I have already calculated the amplitude envelope that would need to >be applied to the lone sine wave. Now all I need to do is calculate >the frequency that this lone sine wave would have to oscillate at in >order for it to equal the original "three summed sine wave" signal.Every time I read this it "feels" like a GCM/LCD (Greatest Common Multiple / Least Common Denominator) question. This may be relevant; it may also indicate I've misunderstood something (wouldn't be the first time <grin!>). Based on this construction of S(t), S(t) will be periodic over the perhaps-very-long period 1/(f1*f2*f3). If you calculate and store the envelope of S over that (fixed length) period, you could use an as a time base to "clock" an infinite number of repetitions of the envelope. Ugly <grin!>, but it seems to satisfy the stated objective. Or (and equally ugly <grin!>), I _think_ you could take that envelope and mathematically calculate a different (fixed length) "envelope" over the same perhaps-very-long period which could be multiplied by the "oscillator" frequency f1*f2*f3 to recreate S(t). Of course, if you can find a least-common-multiple for f1*f2*f3, then you can reduce the period you're concerened with. It'a also possible that you're attempting to find a GCD for f1, f2, and f3 and set up (integral) multipliers so you can generate: f1 = k1*GCD(f1,f2,f3) f2 = k2*GCD(f1,f2,f3) f3 = k3*GCD(f1,f2,f3) If so, be careful: the GCD may be 1, and the k-s could wind up being large. Does this help at all? Frank McKenney -- If you find a path with no obstacles, it probably doesn't lead anywhere. -- Frank McKenney, McKenney Associates Richmond, Virginia / (804) 320-4887 Munged E-mail: frank uscore mckenney ayut mined spring dawt cahm (y'all)
