"Randy Yates" <yates@ieee.org> wrote in message news:m3zltg9dem.fsf@ieee.org...> "VelociChicken" <bob@yahoob.com> writes: > I've never heard of "two-path" polyphase filters, but the operation of > polyphase decimation filters is very straightforward: since you're going > to throw away M-1 of M samples when decimating by M, simply don't > compute them. The rest is bookkeeping. > --Exactly. Polyphase is only about the internal implementation of some filters and not about filter design - as in coefficient selection. Fred
Low pass filter at half Nyquist
Started by ●March 1, 2008
Reply by ●March 3, 20082008-03-03
"VelociChicken" <bob@yahoob.com> wrote in message news:uUYyj.83377$jH4.73721@fe1.news.blueyonder.co.uk...>>> If you google 'polyphase filter' you'll find better >>> explanations than I can give. I've optimised this >>> codehttp://www.musicdsp.org/archive.php?classid=3#39which states that it >>> can >>> achieve up to '150db rejection' with a transition band of .05 > >>150 dB attenuation, that's on the order of 10e-7, right? >>I'm not sure I believe that - one is pushing the limits >>of what can be done with single-precision floating point >>numbers... >>Rune > > Single-precision floating point? *pfft* - nobody uses those anymore! > : ) >After reading through your references I wonder if it might not be a good idea for you to tell us what you think a "halfband filter" is. Because, it isn't simply a filter with cutoff at fs/4. In order to get a halfband filter of any reasonable length and 150dB rejection, the transition would have to be awfully wide I would think. Fred
Fred Marshall wrote:> "Randy Yates" <yates@ieee.org> wrote in message > news:m3zltg9dem.fsf@ieee.org... >> "VelociChicken" <bob@yahoob.com> writes: >> I've never heard of "two-path" polyphase filters, but the operation of >> polyphase decimation filters is very straightforward: since you're going >> to throw away M-1 of M samples when decimating by M, simply don't >> compute them. The rest is bookkeeping. >> -- > > Exactly. Polyphase is only about the internal implementation of some > filters and not about filter design - as in coefficient selection.It's a different and idiosyncratic use of "polyphase". Mr. Chicken was misled by the author 0f the URL he quoted. Don't cluck at him. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
