spectral peak-estimation by cross-correlation
Started by banton March 8, 2008
>One interesting technique applicable in high SNR situations for >estimating two poorly separated tones involves use of a Gaussian >window on data in an FFT and using the bins, off peak on the side away >from the interfering signal to estimate the frequency and amplitude. >Take a look at: > >http://www.edn.com/archives/1994/030394/graph/05df1fg1.htm > >There is a figure 1 you can click on to enlarge to see an example of >the performance capability on the data set fred harris used to discuss >frequency resolution. C code is provided. This is from a back issue of >EDN magazine. > >The Gaussian window was chosen to: >1) widen mainlobe response >2) increase sidelobe rolloff >3) simplify calculation of frequency and magnitude from the ratio of >the amplitudes of two non-peak bins. >
That looks interesting! And it's simple to implement - which is great. So I will immediately start to check if that will help my analysis. Now I am really curious to see how that method performs with more narrow filters (the example in the paper uses an fft size of 64 .. I need much higher resolution). Great link. gr. Bjoern
On Mar 10, 1:53&#2013266080;am, "banton" <bant...@web.de> wrote:
> >On Mar 9, 6:54 am, "banton" <bant...@web.de> wrote: > >> >3) Do you want to identify two close peaks as separate? > > >> Yes. &#2013266080;But I am not talking about Peaks which are so close > >> that they just cause beating. &#2013266080;I mean Peaks which can easily > >> be identified by eye, if you look at plots of the spectrum.
Human perception can, in general, not be easily reproduced by means of DSP. Questions of the type 'I can easily identify whatever when I hear or see the data - how can I achieve the same with DSP or image processing?' are very common, but only the very simplest can be answred. Most of what is 'easily' identifyable by humans is not at all easy to identify by use of computers.
> >> But it is still the interference between them which causes trouble. > > >Simple magnitude peak finding methods with FFT results will > >likely encounter problems if there are less than some small > >number, say 2 or 3, of beats per frame. &#2013266080; > > You say: "simple magnitude peak finding methods" - and I wonder > what other methods I could try. > Any suggestions/references?
One could try statistical methods which analyze the magnitude of the spectrum coeffcients and somehow evaluate them against the genral shape of the spectrum, to try and decide where peaks might exist, at the same time one discards local maxima caused by noise. I have never seen that done, though. Rune
> Rune Allnor wrote: >> >> But it is still the interference between them which causes trouble. >> >> >Simple magnitude peak finding methods with FFT results will >> >likely encounter problems if there are less than some small >> >number, say 2 or 3, of beats per frame. =A0 >> >> You say: "simple magnitude peak finding methods" - and I wonder >> what other methods I could try. >> Any suggestions/references? > >One could try statistical methods which analyze the >magnitude of the spectrum coeffcients and somehow evaluate >them against the genral shape of the spectrum, to try and >decide where peaks might exist, at the same time one discards >local maxima caused by noise. > >I have never seen that done, though.
Exactly something like this is what crosses my mind all the time while working on this. By examining the results from the things I have tried so far, I can see one interesting point which might help to do this: The parabolic-interpolation-based peak estimator catches at least the existence of the peaks. Just the estimated parameters are sometimes quite off. But if I additionally look at the frame-to-frame phase deltas of 2-3 surrounding bins on each side, I can see that the correct values often show up in most of them. I think some people call that spectral clustering (Miller Puckette?). Intuitively I think that this information combined with the right statistical method could lead to much better results. But .. oh well, "the right statistical method" is certainly not easy to come up with. At least I can use this phase-information to make my system aware of its errors. I can identify problematic estimates and that is allready helpfull. gr. Bjoern
On Mar 10, 9:02&#2013266080;am, "banton" <bant...@web.de> wrote:
> Intuitively I think that this information combined with the > right statistical method could lead to much better results. > But .. oh well, "the right statistical method" is > certainly not easy to come up with. &#2013266080;At least I can use > this phase-information to make my system aware of its errors. > I can identify problematic estimates and that is allready helpfull.
I can't help with the details, but it seems you have a pretty realistic view on how to proceed, what to try, as well as where and why problems might occur. Rune
>> Rune Allnor wrote: >>> >> But it is still the interference between them which causes
trouble.
>>> >>> >Simple magnitude peak finding methods with FFT results will >>> >likely encounter problems if there are less than some small >>> >number, say 2 or 3, of beats per frame. =A0 >>> >>> You say: "simple magnitude peak finding methods" - and I wonder >>> what other methods I could try. >>> Any suggestions/references? >> >>One could try statistical methods which analyze the >>magnitude of the spectrum coeffcients and somehow evaluate >>them against the genral shape of the spectrum, to try and >>decide where peaks might exist, at the same time one discards >>local maxima caused by noise. >> >>I have never seen that done, though. > >Exactly something like this is what crosses my mind all the time >while working on this. >By examining the results from the things I have tried so far, I can >see one interesting point which might help to do this: > >The parabolic-interpolation-based peak estimator catches at least >the existence of the peaks. Just the estimated parameters are >sometimes quite off. >But if I additionally look at the frame-to-frame phase deltas of >2-3 surrounding bins on each side, I can see that the correct values >often show up in most of them. I think some people call that >spectral clustering (Miller Puckette?). >Intuitively I think that this information combined with the >right statistical method could lead to much better results. >But .. oh well, "the right statistical method" is >certainly not easy to come up with. At least I can use >this phase-information to make my system aware of its errors. >I can identify problematic estimates and that is allready helpfull.
And this idea of finding a statistical method is also the root of the idea to use cross-correlation with the transform of the window. A single non-modulated sinusoid would correlate perfectly. In praxis that would never happen. Now there are different causes for the "deformation" of the peak. Amplitude modulation, frequency modulation and near-by peaks - all will cause deviations in the peak (deviations from the shape of a peak that a non-modulated windowed sinusoid would result in). The question is: Is it possible to identify the cause by the symptomes? gr. Bjoern
banton wrote:
> I am working on a plugin that involves estimation of spectral > peaks
> In most cases that works sufficiently well, but when sinusoids > are involved that are too close together (but still a few bins arpart), > the sidelobes overlap too much and the whole thing gives pretty > bad results.
> compute the cross-correlation: > A[n] = sum(k = -N...N, X[n] * W[n+k]) > > Then I want to use peaks in A[n] to calculate sinusoidal parameters.
The results will be much sharper if you normalize the corellation to the energy of the signals. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
>Vladimir Vassilevsky wrote: > >banton wrote: > >> I am working on a plugin that involves estimation of spectral >> peaks > >[...] > >> In most cases that works sufficiently well, but when sinusoids >> are involved that are too close together (but still a few bins
arpart),
>> the sidelobes overlap too much and the whole thing gives pretty >> bad results. > >[...] > >> compute the cross-correlation: >> A[n] = sum(k = -N...N, X[n] * W[n+k]) >> >> Then I want to use peaks in A[n] to calculate sinusoidal parameters. > >The results will be much sharper if you normalize the corellation to the
I need further explanations. How do I normalize the correlation? I am sure that must mean something else then just _one_ scaling factor for the correlation results, since I can't see how this would change anything. I found Rune's explanation http://groups.google.no/group/comp.dsp/msg/d184833f2fa03ee7 So I guess I should interpret "the length of the signal" as the part which is non-zero. And then normalize the longer signal always for the part which contributes to the inner-product? thanks, Bjoern
