Linear phase and impulse response symmetry
Started by Unknown ●March 11, 2008
On Mar 11, 11:37 am, "bharat pathak" <bha...@arithos.com> wrote:
> >OOOps actually it should be Is it possible to have nonlinear phase in > > frequency domain (nonconstant group delay) and symmetrical impulse > > response in time domain? > > No, it is not possible. For linear phase and constant group delay, > the impulse response has to be symmetrical.
Not quite. (Conjugate) symmetry is a sufficient condition for linear phase, but not a necessary one. -- Oli
>Can nonsymmetrical impulse response (ie nonsymmetrical FIR filter) >have >linear phase?
*************************** absolutely not. If you want explanation tell me. Manolis
>Not quite. (Conjugate) symmetry is a sufficient condition for linear >phase, but not a necessary one. > >Oli
******************************* i apologize, Oli is very correct. It is possible that a filter has linear phase but non-symmetrical impulse response. As a very simple counter-example, let's consider the unit-delay system, with impulse response h[n] = delta[n-1] and frequency response H(omega) = exp(-i*omega) clearly the impulse response is non-symmetrical, but the phase response is linear. Manolis
On 11 Mrz., 13:24, Pawel <prulikow...@gmail.com> wrote:
> On Mar 11, 12:06 pm, "Manolis C. Tsakiris" <el01...@mail.ntua.gr> > wrote: > > > Hello Powell, > > > the answer is no. > > When a filter has a symmetrical impulse response then it's frequency > > response is striclty linear. > > > Manolis > > Hello Manolis, > > Thanks For Your help. > > Is the following possible: > > Can nonsymmetrical impulse response (ie nonsymmetrical FIR filter) > have linear phase?
As Oli wrote, if the impulse response is anti-symmetrical (h[-n] = - h[n]) you also get linear phase response. Furthermore, you can have approximately linear phase over a certain frequency band without seeing that property immediately in the impulse response. Regards, Andor
On Mar 11, 9:00&#4294967295;am, "Manolis C. Tsakiris" <el01...@mail.ntua.gr>
wrote:
> >Not quite. &#4294967295;(Conjugate) symmetry is a sufficient condition for linear > >phase, but not a necessary one. > > >Oli > > ******************************* > i apologize, > > Oli is very correct. It is possible that a filter has linear phase but > non-symmetrical impulse response. > > As a very simple counter-example, let's consider the unit-delay system, > with impulse response > h[n] = delta[n-1] > and frequency response > H(omega) = exp(-i*omega) > clearly the impulse response is non-symmetrical, but the phase response is > linear. > > Manolis
Manolis, The example you gave is actually symmetric, just not symmetric about the origin. Dirk
>Manolis, > >The example you gave is actually symmetric, just not symmetric about >the origin. > >Dirk >
*************************** Hi Dirk, yes, you are right. Thank you for the observation. How about this one: h[n] = 0.5*delta[n] + 0.5*delta[n-1]? Manolis
On Mar 11, 10:11&#4294967295;am, "Manolis C. Tsakiris" <el01...@mail.ntua.gr>
wrote:
> >Manolis, > > >The example you gave is actually symmetric, just not symmetric about > >the origin. > > >Dirk > > *************************** > Hi Dirk, > > yes, you are right. > Thank you for the observation. > > How about this one: > h[n] = 0.5*delta[n] + 0.5*delta[n-1]? > > Manolis
Actually, that would be even symmetric. Dirk
>On Mar 11, 10:11=A0am, "Manolis C. Tsakiris" <el01...@mail.ntua.gr> >wrote: >> >Manolis, >> >> >The example you gave is actually symmetric, just not symmetric about >> >the origin. >> >> >Dirk >> >> *************************** >> Hi Dirk, >> >> yes, you are right. >> Thank you for the observation. >> >> How about this one: >> h[n] = 0.5*delta[n] + 0.5*delta[n-1]? >> >> Manolis > >Actually, that would be even symmetric. > >Dirk >********************************************
If a signal is symmetric, then by appropriate time-shifting, it can be transformed to symmetric about the origin (0). Don't you agree? However, this is can not be applied to h[n] = 0.5*delta[n] + 0.5*delta[n-1] No matter how i shift this, it can never be symmetric about the origin. What do you think? Manolis
On Mar 11, 10:33&#4294967295;am, "Manolis C. Tsakiris" <el01...@mail.ntua.gr>
wrote:
> >On Mar 11, 10:11=A0am, "Manolis C. Tsakiris" <el01...@mail.ntua.gr> > >wrote: > >> >Manolis, > > >> >The example you gave is actually symmetric, just not symmetric about > >> >the origin. > > >> >Dirk > > >> *************************** > >> Hi Dirk, > > >> yes, you are right. > >> Thank you for the observation. > > >> How about this one: > >> h[n] = 0.5*delta[n] + 0.5*delta[n-1]? > > >> Manolis > > >Actually, that would be even symmetric. > > >Dirk > >******************************************** > > If a signal is symmetric, then by appropriate time-shifting, it can be > transformed to symmetric about the origin (0). Don't you agree? > However, this is can not be applied to > h[n] = 0.5*delta[n] + 0.5*delta[n-1] > No matter how i shift this, it can never be symmetric about the origin. > > What do you think? > > Manolis- Hide quoted text - > > - Show quoted text -
No I don't agree. The filter has a delay of 1/2 sample, it is symmetric about n=1/2. Dirk
>No I don't agree. The filter has a delay of 1/2 sample, it is >symmetric about n=3D1/2. > >Dirk >*******************************************
Ok, i understand. Thank you again. Manolis
