can someone please provide some feedback, I have been trying to program TMS320F2811. On my board I have 2 DSP chained together, I am using code composer 3.1 and JTAG method to program I have downloaded the plugin for the Flash programming. My problem is once I get a new board and open up the Falsh programmer under code composer it says device is locked. I have not locked the device as it is a new board from production with no code. I am unclear why the DSP are locked if they came from the factory is the code composer setting the secure bit. As I do notice the first time as I look at the SEC bit it set to 0. But once I try programming/erasing it changes to 1. Do I have a setup problem that sets this bit. Thank you in advance for any help.
Problems programming TMS320F2811
Started by ●March 12, 2008
