Hi, I tried to get an answer to this when it came up on comp.arch.fpga but didn't get anywhere. So, Mr Bromley posted as quoted below about algorithms for first order delta-sigma modulators. My question is:- What's the algorithm for a second order delta-sigma modulator? N-order? I tried Googling but struggled to find a clear answer. The Maxim site had some app. notes about their converters, but this still didn't help me. Any pointers gratefully received. TIA. Cheers, Syms. "Jonathan Bromley" <jonathan.bromley@doulos.com> wrote in message news:kc9780d765fn0lor7msd06dhnk033aqp7p@4ax.com...> You can make a simple > distributed PWM by using a first order delta-sigma modulator; > it's essentially the same trick as Bresenham's algorithm > for drawing angled lines on a raster display. Conceptually > the algorithm is: > * maintain a signed accumulator register A > * establish a PWM cycle length, N clock cycles > * have a "desired output" value V > * on each clock cycle, accumulate A = A + V, and then... > - if A is negative, supply 0 as the output > - if A is positive, supply 1 as the output and modify > the accumulator by forming A = A - N >
Second order delta-sigma modulator. How?
Started by ●April 21, 2004
Reply by ●April 21, 20042004-04-21
Hey Symon,
An Lth-order modulator yields a noise transfer function of H(z) =
(1-z^(-1))^L. The power response of this is |H(\omega)|^2 = [2*(1 -
cos(\omega))]^L.
Note this is for a cascade of simple integrators in the modulator
loop. More sophisticated transfer functions can be constructed.
I recommend the following reference:
@BOOK{deltasigmadataconverters,
title = "Delta-Sigma Data Converters: Theory, Design, and Simulation",
author = "{Steven~R.~Norsworthy,} {Richard~Schreier,} and {Gabor~C.~Temes}",
publisher = "IEEE Press",
year = "1997"}
Also note that there is a survey of delta sigma techniques in the current issue
of the Journal of the Audio Engineering Society.
--Randy
"Symon" <symon_brewer@hotmail.com> writes:
> Hi,
> Cheers, Syms.
>> the algorithm is:
% Randy Yates % "Midnight, on the water...
%% Fuquay-Varina, NC % I saw... the ocean's daughter."
%%% 919-577-9882 % 'Can't Get It Out Of My Head'
%%%% <yates@ieee.org> % *El Dorado*, Electric Light Orchestra
http://home.earthlink.net/~yatescr
Reply by ●April 22, 20042004-04-22
Or other people querying on this and related topics -- Don't overlook substantive tutorial material posted on the Usenet over the years, some of it separately WWW-archived (though some of it is semi-technical explanations, partly to answer nonsense fermenting in some audio applications). A 1991 example can be found in stand-alone archive at various sites such as http://members.chello.nl/~m.heijligers/DAChtml/Digital%20Theory/hauser.txt or by searching for the set of words "oversampling curious furious damned." (Its predecessor was a 1987 Usenet tutorial.) I also wrote among other things the standard JAES tutorial-review paper on the subject, in 1991, which the AES will email you instantly via http://www.aes.org/journal/search.html -- enter keyword phrase "Principles of Oversampling" to locate the paper. The AES charges $5 for such reprints (by email or paper); in this case the page count makes it a relative bargain per page. It does include the basic classes of oversampling-quantizer structures in block-diagram form. Many people have commented over the years on the tutorial benefit that they got from that paper. Few other tutorials address explicitly the overlap of quantization and antialias filtering functions or the conflicts of technical "cultures" and languages that pervade the literature (the language issues have worsened since then, by the way). This paper is in steady use as teaching material at MIT; even a few other authors in the JAES have read it ;-). (Also, it's a matter of record that many firms and people saw my seminars on this topic before they later wrote on it themselves or offered products: Analog Devices, Burr-Brown, GE-Intersil, IBM, National Semiconductor, Texas Instruments, Cal Tech, Robert M. Gray, Gabor Temes, many others.) In case this is helpful. -- Max Hauser
Hi Randy,
Thanks for the reply and book recommendation, much appreciated.
So, for a second order modulator, this is the algorithm?
* maintain a signed accumulator registers A, B
* on each clock cycle, accumulate A = A + V, B = B + A and then...
- if B is negative, supply 0 as the output
- if B is positive, supply 1 as the output and modify
the A accumulator by forming A = A - N
Thanks again, Syms.
"Randy Yates" <yates@ieee.org> wrote in message
news:smewwyvm.fsf@ieee.org...
> Hey Symon,
> cos(\omega))]^L.
{Gabor~C.~Temes}",
> year = "1997"}
issue
> --Randy
"Max Hauser" <maxREMOVE@THIStdl.com> wrote in message news:108eo2v4v38nu90@corp.supernews.com...> or by searching for the set of words "oversampling curious furiousdamned."> (Its predecessor was a 1987 Usenet tutorial.) >I must admit, that's one set of words I didn't try....> > In case this is helpful. -- Max Hauser >Very much so, thanks Max, Syms.
Hmmm, thinking about it, I may've missed off B = B - 2N at the end. I must do some simulations later. Cheers, Syms. "Symon" <symon_brewer@hotmail.com> wrote in message news:c68skc$9fj6d$1@ID-212844.news.uni-berlin.de...> Hi Randy, > Thanks for the reply and book recommendation, much appreciated. > So, for a second order modulator, this is the algorithm? > > * maintain a signed accumulator registers A, B > * establish a PWM cycle length, N clock cycles > * have a "desired output" value V > * on each clock cycle, accumulate A = A + V, B = B + A and then... > - if B is negative, supply 0 as the output > - if B is positive, supply 1 as the output and modify > the A accumulator by forming A = A - N > > Thanks again, Syms. > > "Randy Yates" <yates@ieee.org> wrote in message > news:smewwyvm.fsf@ieee.org... > > Hey Symon, > > > > An Lth-order modulator yields a noise transfer function of H(z) = > > (1-z^(-1))^L. The power response of this is |H(\omega)|^2 = [2*(1 - > > cos(\omega))]^L. > > > > Note this is for a cascade of simple integrators in the modulator > > loop. More sophisticated transfer functions can be constructed. > > > > I recommend the following reference: > > > > @BOOK{deltasigmadataconverters, > > title = "Delta-Sigma Data Converters: Theory, Design, and Simulation", > > author = "{Steven~R.~Norsworthy,} {Richard~Schreier,} and > {Gabor~C.~Temes}", > > publisher = "IEEE Press", > > year = "1997"} > > > > Also note that there is a survey of delta sigma techniques in thecurrent> issue > > of the Journal of the Audio Engineering Society. > > > > --Randy > > > >
"Symon" <symon_brewer@hotmail.com> writes:> Hi Randy, > Thanks for the reply and book recommendation, much appreciated. > So, for a second order modulator, this is the algorithm? > > * maintain a signed accumulator registers A, B > * establish a PWM cycle length, N clock cycles > * have a "desired output" value V > * on each clock cycle, accumulate A = A + V, B = B + A and then... > - if B is negative, supply 0 as the output > - if B is positive, supply 1 as the output and modify > the A accumulator by forming A = A - N > > Thanks again, Syms.Hi Syms, The above pseudo-code isn't right - you must subtract the output from the input before accumulating (integrating). Try this: % Initialize: i = 0 % first integrator j = 0 % second integrator y = 0 % output % Loop for n = 0 to infinity d[n] = x[n] - y[n-1] i[n] = d[n] + i[n-1] j[n] = i[n] + j[n-1] y[n] = Q(j[n]) end The Q() function is the quantizer function, which can be as you described above. Note that the operation you described gives you a DC offset, but that's OK. I'm not sure what your "PWM cycle length" is about. Delta sigma modulation is NOT PWM. You also haven't yet mentioned whether this is an A/D or a D/A. What I've given is a "D/D", which is essentially a D/A, where you have to upsample the input data first to the desired oversampling ratio. Does this make sense? Please ask more questions if not. --Randy> > "Randy Yates" <yates@ieee.org> wrote in message > news:smewwyvm.fsf@ieee.org... > > Hey Symon, > > > > An Lth-order modulator yields a noise transfer function of H(z) = > > (1-z^(-1))^L. The power response of this is |H(\omega)|^2 = [2*(1 - > > cos(\omega))]^L. > > > > Note this is for a cascade of simple integrators in the modulator > > loop. More sophisticated transfer functions can be constructed. > > > > I recommend the following reference: > > > > @BOOK{deltasigmadataconverters, > > title = "Delta-Sigma Data Converters: Theory, Design, and Simulation", > > author = "{Steven~R.~Norsworthy,} {Richard~Schreier,} and > {Gabor~C.~Temes}", > > publisher = "IEEE Press", > > year = "1997"} > > > > Also note that there is a survey of delta sigma techniques in the current > issue > > of the Journal of the Audio Engineering Society. > > > > --Randy > > > >-- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
"Randy Yates" <randy.yates@sonyericsson.com> wrote in message news:xxpn05394ok.fsf@usrts005.corpusers.net...> > I'm not sure what your "PWM cycle length" is about. Delta > sigma modulation is NOT PWM. You also haven't yet mentioned > whether this is an A/D or a D/A. What I've given is a "D/D", > which is essentially a D/A, where you have to upsample the > input data first to the desired oversampling ratio. > > Does this make sense? Please ask more questions if not. > > --RandyHi Randy, Yeah, the mists are starting to clear! My next step will be to do some simulations/experiments! The application I'm thinking about is for implementing the fractional-N feedback divider in a fractional-N phase locked loop. The feedback divider output is a single bit (which controls a phase comparator charge pump, which feeds a charge integrator via a LP filter, which controls a VCO), but I'm thinking about how to shape the noise in this signal, specifically to move the noise to a higher frequency. Thanks again, Syms.
Reply by ●April 23, 20042004-04-23
"Symon" <symon_brewer@hotmail.com> writes:> "Randy Yates" <randy.yates@sonyericsson.com> wrote in message > news:xxpn05394ok.fsf@usrts005.corpusers.net... >> >> I'm not sure what your "PWM cycle length" is about. Delta >> sigma modulation is NOT PWM. You also haven't yet mentioned >> whether this is an A/D or a D/A. What I've given is a "D/D", >> which is essentially a D/A, where you have to upsample the >> input data first to the desired oversampling ratio. >> >> Does this make sense? Please ask more questions if not. >> >> --Randy > > Hi Randy, > Yeah, the mists are starting to clear! My next step will be to do some > simulations/experiments!Sounds like the perfect thing to do at this stage.> The application I'm thinking about is for implementing the fractional-N > feedback divider in a fractional-N phase locked loop. The feedback divider > output is a single bit (which controls a phase comparator charge pump, which > feeds a charge integrator via a LP filter, which controls a VCO), but I'm > thinking about how to shape the noise in this signal, specifically to move > the noise to a higher frequency.Sounds like a perfect application! Have fun! -- % Randy Yates % "And all that I can do %% Fuquay-Varina, NC % is say I'm sorry, %%% 919-577-9882 % that's the way it goes..." %%%% <yates@ieee.org> % Getting To The Point', *Balance of Power*, ELO http://home.earthlink.net/~yatescr
"Symon" <symon_brewer@hotmail.com> wrote in message news:c69h5s$9dr4v$1@ID-212844.news.uni-berlin.de...> > "Randy Yates" <randy.yates@sonyericsson.com> wrote in message > news:xxpn05394ok.fsf@usrts005.corpusers.net... > > > > I'm not sure what your "PWM cycle length" is about. Delta > > sigma modulation is NOT PWM. You also haven't yet mentioned > > whether this is an A/D or a D/A. What I've given is a "D/D", > > which is essentially a D/A, where you have to upsample the > > input data first to the desired oversampling ratio. > > > > Does this make sense? Please ask more questions if not. > > > > --Randy > > Hi Randy, > Yeah, the mists are starting to clear! My next step will be to dosome> simulations/experiments! > The application I'm thinking about is for implementing thefractional-N> feedback divider in a fractional-N phase locked loop. The feedbackdivider> output is a single bit (which controls a phase comparator chargepump, which> feeds a charge integrator via a LP filter, which controls a VCO),but I'm> thinking about how to shape the noise in this signal, specificallyto move> the noise to a higher frequency. > Thanks again, Syms. > >Google is your friend: as well as the obvious keywords to search on, try entering "multiple modulator" in the google exact phrase box, and "fractional" in the all words box. Regards Ian
