I wrote:> I thought that part in the paper was a bit odd.I also like this quote from the paper: "... for large enough values of f_min (no more than 2 or 3 decades from 0) ... " :-)
Generating 1/f (flicker/pink) noise
Started by ●March 21, 2008
Reply by ●March 26, 20082008-03-26
Reply by ●September 3, 20092009-09-03
>On 25 Mar, 14:51, dbd <d...@ieee.org> wrote: >> On Mar 24, 4:51 pm, maxlittle2...@googlemail.com wrote: >> >> >> >> > On 23 Mar, 18:33, dbd <d...@ieee.org> wrote: >> >> > > On Mar 22, 4:03 pm, maxlittle2...@googlemail.com wrote: >> >> > > > ... >> > > > Ah, well I did find those resources, but no simple "one pager"of>> > > > Matlab code for generating perfect 1/f^alpha noise. >> > > > ... >> > > > Max >> >> > > There can be no page that is 'simple' and 'perfect' for all >> > > applications. >> >> > > One characteristic of your implementation choice is that the power >> > > spectrum does not just have the desired expectation value in any >> > > frequency region, but it equals the expectation value. While thisis a>> > > possible power spectum value, it is not a likely one, and isunlikely>> > > to repeat. This can be useful in certain testing situations. Itmight>> > > be inappropriate in others. An alternative is to use independent >> > > Gaussian samples for real and imaginary frequency components and >> > > weight them with the desired frequency weighting. An example >> > > implementation of this, modified from your implementation, follows >> > > below. This could provide more realistic statistical behavior insome>> > > applications. >> >> > > Dale B. Dalrymplehttp://dbdimages.com >> >> > Dale >> >> > Thanks, these are excellent points. I've added an option to the >> > routine so that a choice can be made between deterministic and >> > stochastic power. I've also added an option that normalises the >> > signal amplitude so that it lies in the range -1 to +1. This may be >> > useful in certain circumstances. Grab the code from: >> >> >http://www.eng.ox.ac.uk/samp/powernoise_soft.html >> >> > Max >> >> Max >> >> If you really think a normalization and a peak limiting capability >> should be included inside the function, I suggest you do so with a >> gain and a clipping capability instead of putting the mean and scale >> of the output under the control of the extremal behavior of the noise >> generated. >> >> There are test purposes where the original function or my addition >> could be called multiple times to generate longer sequences of test >> data. Even these special cases no longer work when gain and offset >> change from block to block. >> >> Dale B. Dalrymple > >Thanks for the thoughtful suggestions Dale. > >I think the normalization to the range [-1, 1] is required for some >applications (particularly nonlinear time series analysis): at least >one member of this group has found that some gain is desireable, and I >reason that it's better to have a signal that uses a standard number >range. Otherwise, as you imply, there probably isn't much point in >putting this scaling in the function. If by clipping I understand you >to mean some kind of nonlinear "clamping" of values outside a certain >range, I don't agree with this because it will distort the spectrum. > >This also leads on to your second paragraph. Unfortunately this >method, as it stands, can't be called multiple times to generate >longer sequences: there will be several problems. One of them is that >the signal is not guaranteed to be continuous across multiple calls. >The resulting discontinuities will introduce spectral distortions. > >Of course, one could imagine a solution to fix this problem that >matches the endpoints of each successive call, but then you'd also >need to match as many derivatives of the signal as are required to >ensure the appropriate differentiability for the chosen "roughness" of >the signal (which, informally, is inversely proportional to alpha). I >don't think such an approach would be elegant though, and I'm sure >there's a better one, although I can't think of it right now. > >Max >Hi Max & Dale, I have been trying to use your code to create a background noise signal with 1/f characteristics (between [-1 1]). That is fine and moves very efficiently. Now, I need to create a signal (1/f again) which is not normalized between [-1 1] but rather has an average gain defined by factor K. How do I do that? Simply adding or multiplying the background noise by the factor of K does not provide the same 1/f characteristics. What is the right solution? Best Nim
>>On 25 Mar, 14:51, dbd <d...@ieee.org> wrote: >>> On Mar 24, 4:51 pm, maxlittle2...@googlemail.com wrote: >>> >>> >>> >>> > On 23 Mar, 18:33, dbd <d...@ieee.org> wrote: >>> >>> > > On Mar 22, 4:03 pm, maxlittle2...@googlemail.com wrote: >>> >>> > > > ... >>> > > > Ah, well I did find those resources, but no simple "one pager" >of >>> > > > Matlab code for generating perfect 1/f^alpha noise. >>> > > > ... >>> > > > Max >>> >>> > > There can be no page that is 'simple' and 'perfect' for all >>> > > applications. >>> >>> > > One characteristic of your implementation choice is that thepower>>> > > spectrum does not just have the desired expectation value in any >>> > > frequency region, but it equals the expectation value. While this >is a >>> > > possible power spectum value, it is not a likely one, and is >unlikely >>> > > to repeat. This can be useful in certain testing situations. It >might >>> > > be inappropriate in others. An alternative is to use independent >>> > > Gaussian samples for real and imaginary frequency components and >>> > > weight them with the desired frequency weighting. An example >>> > > implementation of this, modified from your implementation,follows>>> > > below. This could provide more realistic statistical behavior in >some >>> > > applications. >>> >>> > > Dale B. Dalrymplehttp://dbdimages.com >>> >>> > Dale >>> >>> > Thanks, these are excellent points. I've added an option to the >>> > routine so that a choice can be made between deterministic and >>> > stochastic power. I've also added an option that normalises the >>> > signal amplitude so that it lies in the range -1 to +1. This may be >>> > useful in certain circumstances. Grab the code from: >>> >>> >http://www.eng.ox.ac.uk/samp/powernoise_soft.html >>> >>> > Max >>> >>> Max >>> >>> If you really think a normalization and a peak limiting capability >>> should be included inside the function, I suggest you do so with a >>> gain and a clipping capability instead of putting the mean and scale >>> of the output under the control of the extremal behavior of the noise >>> generated. >>> >>> There are test purposes where the original function or my addition >>> could be called multiple times to generate longer sequences of test >>> data. Even these special cases no longer work when gain and offset >>> change from block to block. >>> >>> Dale B. Dalrymple >> >>Thanks for the thoughtful suggestions Dale. >> >>I think the normalization to the range [-1, 1] is required for some >>applications (particularly nonlinear time series analysis): at least >>one member of this group has found that some gain is desireable, and I >>reason that it's better to have a signal that uses a standard number >>range. Otherwise, as you imply, there probably isn't much point in >>putting this scaling in the function. If by clipping I understand you >>to mean some kind of nonlinear "clamping" of values outside a certain >>range, I don't agree with this because it will distort the spectrum. >> >>This also leads on to your second paragraph. Unfortunately this >>method, as it stands, can't be called multiple times to generate >>longer sequences: there will be several problems. One of them is that >>the signal is not guaranteed to be continuous across multiple calls. >>The resulting discontinuities will introduce spectral distortions. >> >>Of course, one could imagine a solution to fix this problem that >>matches the endpoints of each successive call, but then you'd also >>need to match as many derivatives of the signal as are required to >>ensure the appropriate differentiability for the chosen "roughness" of >>the signal (which, informally, is inversely proportional to alpha). I >>don't think such an approach would be elegant though, and I'm sure >>there's a better one, although I can't think of it right now. >> >>Max >> > >Hi Max & Dale, >I have been trying to use your code to create a background noise signal >with 1/f characteristics (between [-1 1]). That is fine and moves very >efficiently. Now, I need to create a signal (1/f again) which is not >normalized between [-1 1] but rather has an average gain defined byfactor>K. How do I do that? > >Simply adding or multiplying the background noise by the factor of Kdoes>not provide the same 1/f characteristics. What is the right solution? >Best >Nim > > > >Actually never mind, I changed the code to adapt that: function x = powernoise(alpha,N, varargin) % function x = powernoise(alpha,N, 'key','value') % Generate samples of power law noise. The power spectrum % of the signal scales as f^(-alpha). % % Useage: % x = powernoise(alpha, N) % x = powernoise(alpha, N, % 'randpower','off','normalize','on','normfactor',n) % % Inputs: % alpha - power law scaling exponent % N - number of samples to generate % % Output: % x - N x 1 vector of power law samples % % With no option strings specified, the power spectrum is % deterministic, and the phases are uniformly distributed in the range % -pi to +pi. The power law extends all the way down to 0Hz (DC) % component. By specifying the 'randpower' option string however, the % power spectrum will be stochastic with Chi-square distribution. The % 'normalize' option string forces scaling of the output to the range % [-1, 1], consequently the power law will not necessarily extend % right down to 0Hz. % % if you decide to normalize, you can also add normfactor option: % 'normfactor',k will normalize the output between [-k,k] % % (cc) Max Little, 2008. This software is licensed under the % Attribution-Share Alike 2.5 Generic Creative Commons license: % http://creativecommons.org/licenses/by-sa/2.5/ % If you use this work, please cite: % Little MA et al. (2007), "Exploiting nonlinear recurrence and fractal % scaling properties for voice disorder detection", Biomed Eng Online, 6:23 % % As of 20080323 markup % If you use this work, consider saying hi on comp.dsp % Dale B. Dalrymple % % Modified by Nima Dehghani : added normfactor to scale between %[-normfactor normfactor] % Sep 3rd 2009 callbacks = {'normalize','randpower','normfactor'}; try options = varargin; for index = 1:length(options) if iscell(options{index}) & ~iscell(options{index}{1}), options{index} = { options{index} }; end; end; if ~isempty( varargin ), g=struct(options{:}); else g= []; end; catch fprintf('%s: calling convention {''key'', value, ... } error',mfilename); return; end; try, g.normalize; catch; g.normalize = 'off'; end; try, g.randpower; catch; g.randpower = 'off'; end; try, g.normfactor; catch; g.normfactor = 1; end; if strcmpi(g.normalize, 'on'), opt_normal = true; else optnormal = false; end; if strcmpi(g.normalize, 'on'), opt_randpow = true; else opt_randpow = false; end; N2 = floor(N/2)-1; f = (2:(N2+1))'; A2 = 1./(f.^(alpha/2)); if (~opt_randpow) p2 = (rand(N2,1)-0.5)*2*pi; d2 = A2.*exp(i*p2); else % 20080323 p2 = randn(N2,1) + i * randn(N2,1); d2 = A2.*p2; end d = [1; d2; 1/((N2+2)^alpha); flipud(conj(d2))]; x = real(ifft(d)); if (opt_normal) x = ((x - min(x))/(max(x) - min(x)) - 0.5) * g.normfactor*2; end
