Hi, I'm triyng to assemble an SDR using my old ICOM receiver as RF front end. From it I've captured an IF signal at 10.7Mhz (1.3V). I need to sampling this signal and then use the samples as input for a Spartan 3 FPGA. The difficult part of the project for me is the ADC circuit. I've seen the datasheet of MAX1421 (12bit 40MSPS) but I'd like to know if this chip is good (in my case) or maybe there are better ones ? Do I need to use an OPAMP in front of ADC chip or a transformer ? Can you suggest me some schematic for the ADC part ? Thanks Simone
ADC schematic for 10.7Mhz IF
Started by ●March 26, 2008
Reply by ●March 26, 20082008-03-26
On Tue, 25 Mar 2008 20:13:54 -0700, simone.rotondo wrote:> Hi, > I'm triyng to assemble an SDR using my old ICOM receiver as RF front > end. > From it I've captured an IF signal at 10.7Mhz (1.3V). I need to sampling > this signal and then use the samples as input for a Spartan 3 FPGA. > The difficult part of the project for me is the ADC circuit. I've seen > the datasheet of MAX1421 (12bit 40MSPS) but I'd like to know if this > chip is good (in my case) or maybe there are better ones ? Do I need to > use an OPAMP in front of ADC chip or a transformer ? Can you suggest me > some schematic for the ADC part ? > > Thanks > SimoneThere can be quite an art to keeping a signal clean going into a high- speed ADC. There's some charge coupling that happens with the sampling. Go digging for app notes, and if you find any really good ones that aren't Maxim then reward that vendor by buying their parts! Analog Devices has (IIRC) a 60MSPS, 14-bit ADC. I know it works very well for video, but I couldn't tell you how it works in a radio. Sample as fast as you can -- the ADC front-end is much broader band than the sampling rate on those things, so the noise energy/sample is pretty constant. The faster you sample the lower the noise power/Hz gets, which gives you a wider dynamic range in the end. -- Tim Wescott Control systems and communications consulting http://www.wescottdesign.com Need to learn how to apply control theory in your embedded system? "Applied Control Theory for Embedded Systems" by Tim Wescott Elsevier/Newnes, http://www.wescottdesign.com/actfes/actfes.html
simone.rotondo@gmail.com wrote:> Hi, > I'm triyng to assemble an SDR using my old ICOM receiver as RF front > end. > From it I've captured an IF signal at 10.7Mhz (1.3V). > I need to sampling this signal and then use the samples as input for a > Spartan 3 FPGA. > The difficult part of the project for me is the ADC circuit. I've seen > the datasheet of MAX1421 (12bit 40MSPS) but I'd like to know if this > chip is good (in my case) or maybe there are better ones ? > Do I need to use an OPAMP in front of ADC chip or a transformer ? > Can you suggest me some schematic for the ADC part ?I'm sure it's no coincidence that your IF has the same frequency as an FM receiver for the 88 to 108 MHz range. What bandwidth do you need? You woulf like to drive the ADC to about half its range for normal signals, so you might want to boost that 1.3# somewhat. Is that RMS, peak to peak, or what? If you need gain, a transistor and an FM IF transformer might be a good approach. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:> simone.rotondo@gmail.com wrote: >> Hi, >> I'm triyng to assemble an SDR using my old ICOM receiver as RF front >> end. >> From it I've captured an IF signal at 10.7Mhz (1.3V). >> I need to sampling this signal and then use the samples as input for a >> Spartan 3 FPGA. >> The difficult part of the project for me is the ADC circuit. I've seen >> the datasheet of MAX1421 (12bit 40MSPS) but I'd like to know if this >> chip is good (in my case) or maybe there are better ones ? >> Do I need to use an OPAMP in front of ADC chip or a transformer ? >> Can you suggest me some schematic for the ADC part ? > > I'm sure it's no coincidence that your IF has the same frequency as an > FM receiver for the 88 to 108 MHz range. What bandwidth do you need? You > woulf like to drive the ADC to about half its range for normal signals, > so you might want to boost that 1.3# somewhat. Is that RMS, peak to > peak, or what? If you need gain, a transistor and an FM IF transformer > might be a good approach. >... and resist the temptation to split the ground plane. No matter what datasheets, professors and so on say. OTOH I wouldn't have as much work if nobdoy would split ground planes ;-) -- Regards, Joerg http://www.analogconsultants.com/
Joerg wrote: (snip)>> simone.rotondo@gmail.com wrote:(snip)>>> The difficult part of the project for me is the ADC circuit. I've seen >>> the datasheet of MAX1421 (12bit 40MSPS) but I'd like to know if this >>> chip is good (in my case) or maybe there are better ones ?(snip)> ... and resist the temptation to split the ground plane. No matter what > datasheets, professors and so on say. OTOH I wouldn't have as much work > if nobdoy would split ground planes ;-)Since the OP didn't ask about split ground planes ... Some ICs have separate analog and digital ground pins. By split ground plane do you mean a split between the two? I understand the problem with split planes when signals have to cross the split, but with proper split analog/digital parts of the board that shouldn't happen. Then again, real circuits never come out the way they are supposed to come out. Isn't it better for low noise to keep analog and digital signals and power/ground lines separate? -- glen
glen herrmannsfeldt wrote:> Joerg wrote: > (snip) > >>> simone.rotondo@gmail.com wrote: > (snip) > >>>> The difficult part of the project for me is the ADC circuit. I've seen >>>> the datasheet of MAX1421 (12bit 40MSPS) but I'd like to know if this >>>> chip is good (in my case) or maybe there are better ones ? > (snip) > >> ... and resist the temptation to split the ground plane. No matter >> what datasheets, professors and so on say. OTOH I wouldn't have as >> much work if nobdoy would split ground planes ;-) > > Since the OP didn't ask about split ground planes ... >He didn't but IME this is the almost perfect scenario where people head off into that direction. I am usually the guy who has to come in as a consultant after it didn't work and clean things up.> Some ICs have separate analog and digital ground pins. By split > ground plane do you mean a split between the two? >Yes, that's what I meant.> I understand the problem with split planes when signals have to > cross the split, but with proper split analog/digital parts of > the board that shouldn't happen. Then again, real circuits never > come out the way they are supposed to come out. >The last sentence is the reason why it usually doesn't work. Circuits don't live in a vacuum bubble. On one side there is a power supply and thus a power line, then maybe a USB line, some other comm ports, a keyboard that someone with a conductive human body touches, a monitor etc. On the other side of the split there is the RF input which generally leads to some other place. Plus a user interface, usually. Then there is the whole topic of safety ground, you can't just leave one side off because it creates noise. Else the UL guys may not hand you the coveted blessings.> Isn't it better for low noise to keep analog and digital signals > and power/ground lines separate? >Generally not. Mainly because some external connection will form an undesired or totally unexpected loop. The you have an efficient antenna and the brunt of the signal will be present at, voila, the split. Causing lots of headaches. You can combat all that with a box full of toroids but that gets old really fast. There are situations where a star ground or a split can work, for example in audio but usually only until some strong RF source shows up in the neighborhood. Where is usually doesn't work is in the RF world. There are situations in my field of work where a split is mandatory for safety reasons. For example when a part of a circuit gets connected to stuff that resides close to or inside someone's heart during a medical procedure. -- Regards, Joerg http://www.analogconsultants.com/
Reply by ●March 27, 20082008-03-27
Thanks for your advices. I found this schematic on the net: http://oscar.dcarr.org/ssrp/hardware/LTC1746/LTC1746sch.png Do you think is it good for my purpose ? As you noticed I'm a beginner in electronic engineering, becouse I'm a programmer, but I think that if I pass this phase of the project I come on my land (vhdl programming and usb driver) so I hope that with little help this project is not too ambitious for me.> I'm sure it's no coincidence that your IF has the same frequency as an > FM receiver for the 88 to 108 MHz range. What bandwidth do you need?Yes. It's an FM receiver. BW is 50kHz or 443kHz.> Is that RMS, peak to peak, or what?I've read that value on the schematic of my receiver, in the point where I grab the IF signal (at the emitter of NPN Transistor, Q85 on the schematic below): http://www.wentztech.com/radio/PCR1000/files/page9_4.jpg I think that with a 0.1uF capacitor I can drop DC signal. Simone
simone.rotondo@gmail.com wrote:> Thanks for your advices. > I found this schematic on the net: > > http://oscar.dcarr.org/ssrp/hardware/LTC1746/LTC1746sch.png > > Do you think is it good for my purpose ?Probably. I don't know this ADC but as I mentioned before I do not like the split grounds. If you do that at least make sure it's a clean cut and that you have 0805 or 0603 pads across the split every 1/2 inch or so, for zero-ohm resistors. Those can spare you a lot of grief.> As you noticed I'm a beginner in electronic engineering, becouse I'm a > programmer, but I think that if I pass this phase of the project I > come on my land (vhdl programming and usb driver) so I hope that with > little help this project is not too ambitious for me. > >> I'm sure it's no coincidence that your IF has the same frequency as an >> FM receiver for the 88 to 108 MHz range. What bandwidth do you need? > > Yes. It's an FM receiver. BW is 50kHz or 443kHz. > >> Is that RMS, peak to peak, or what? > > I've read that value on the schematic of my receiver, in the point > where I grab the IF signal (at the emitter of NPN Transistor, Q85 on > the schematic below): > > http://www.wentztech.com/radio/PCR1000/files/page9_4.jpg > > I think that with a 0.1uF capacitor I can drop DC signal. >I don't think you can tap off into a 50ohm load there. It'll snuff out part of your signal. One solution would be a source or emitter follower up front. -- Regards, Joerg http://www.analogconsultants.com/
Reply by ●April 4, 20082008-04-04
> > I don't think you can tap off into a 50ohm load there. It'll snuff out > part of your signal. One solution would be a source or emitter follower > up front. >I think the Q85 is a emitter follower yet. So maybe I can tap off directly from its output without loose of signal. is it possible ? (schematic: http://www.wentztech.com/radio/PCR1000/files/page9_4.jpg ) Simone
Reply by ●April 5, 20082008-04-05
simone.rotondo@gmail.com wrote:>> I don't think you can tap off into a 50ohm load there. It'll snuff out >> part of your signal. One solution would be a source or emitter follower >> up front. >> > I think the Q85 is a emitter follower yet. > So maybe I can tap off directly from its output without loose of > signal. is it possible ? > (schematic: http://www.wentztech.com/radio/PCR1000/files/page9_4.jpg ) >Yes. Just don't expect a lot of distortion free amplitude range. The picture is too fuzzy to read DC levels. If it's just a few ten mV of signal level you might be ok. -- Regards, Joerg http://www.analogconsultants.com/
