Hi, I am new to signal processing, so please don't laugh if my questions appear silly to you. In my knowledge, to get accurate spectrum result using FFT, the sampling period should be close to the integal times of the whole cycles of input signal period and the sampling points should be 2^n. For example, 1KHz square wave, the sampling time should be integal times of 1ms, i.e., 10ms. However, I am using a system from a company that analyzes signal spectrum using FFT. The spectrum lines is only selectable among 1600, 3200, 6400, 12800, and the sampling period is not integral times of signal period. The spectrum result, amazingly, is very close to the one we obtained with standard radix-2 FFT algorithm sampling for integral signal period. My question is, is there some specical FFT algorithm that sample for a fixed time (i.e., probably fractional signal period) but can realize similiar spectrum result as that obtained by standard FFT algorithm with integral signal period? Hopefully I made myself understood. Any contribution to this question is appreciated. David
FFT implementation issues
Started by ●March 26, 2008
Reply by ●March 26, 20082008-03-26
<engp0931@gmail.com> wrote in message news:11b0658a-c87e-4679-ac59-e1aa46090957@i29g2000prf.googlegroups.com...> Hi, > > I am new to signal processing, so please don't laugh if my questions > appear silly to you. > > In my knowledge, to get accurate spectrum result using FFT, the > sampling period should be close to the integal times of the whole > cycles of input signal period and the sampling points should be 2^n. > For example, 1KHz square wave, the sampling time should be integal > times of 1ms, i.e., 10ms. However, I am using a system from a company > that analyzes signal spectrum using FFT. The spectrum lines is only > selectable among 1600, 3200, 6400, 12800, and the sampling period is > not integral times of signal period. The spectrum result, amazingly, > is very close to the one we obtained with standard radix-2 FFT > algorithm sampling for integral signal period. > > My question is, is there some specical FFT algorithm that sample for a > fixed time (i.e., probably fractional signal period) but can realize > similiar spectrum result as that obtained by standard FFT algorithm > with integral signal period? > > Hopefully I made myself understood. > > Any contribution to this question is appreciated. > DavidGeneral signals don't have the type of characteristic that you cite. For example, the sum of sin(t) and sin(pi*t) is not periodic although can be viewed as "close enough" for certain selected time spans. And, generally, DFTs or FFTs aren't "tuned" to a signal period as you suggest. But, if you have a situation where it can be done then more power to you. Whichever time span is selected will smear the spectral information with a sinc whose width is inversely proportional to the time span. When the time span is an integral number of periods of a periodic waveform then the sinc zeros coincide with the frequency samples and you get a nice neat set of samples of single sinc peaks. When the time span isn't an integral number of periods of anything then the sinc peaks occur elsewhere and the sinc zeros don't coincide with the frequency samples. Thus, there will be lots of nonzero samples particularly around the tonal frequencies - and caused perhaps only by a single tone. This is called "spectral leakage". There's one situation where this can be forced and can include variations in frequencies. This is used in studying machinery noise where the noise would otherwise be in the noise or even in the noise coming out of a narrowband analyzer or FFT. A tachometer on the machine is used as the clock base for doing the analysis. This might be done by using the tachometer for the clock base of the sampler. Then the sample rate will be an integer multiple of the machine speed and the spectral components will be harmonically related to the machine speed. Even if the machine speed is erratic the machinery noises will stand out better than in a fixed-clock case. You want to look at "spectral estimation" Fred
On 26 Mar, 06:07, engp0...@gmail.com wrote:> Hi, > > I am new to signal processing, so please don't laugh if my questions > appear silly to you. > > In my knowledge, to get accurate spectrum result using FFT, the > sampling period should be close to the integal times of the whole > cycles of input signal periodWrong. The DFT is a representation of the input sequence which is exact to within numerical accuracy, regardless of the properties of the input signal.> and the sampling points should be 2^n.That used to be a constraint in order to use the FFT; that's not the case anymore. You can use the FFT with any signal length.> For example, 1KHz square wave, the sampling time should be integal > times of 1ms, i.e., 10ms.Nope; the sampling interval should be higher than the Nyquist limit. Defining the Nyquist limit for a square wave may be a bit tricky, as the square wave has infinite bandwidth, but once you decide on a bandwidth B the sampling frequency Fs must satisfy Fs > 2B. There are no constraints wrt to the period of the square wave.> However, I am using a system from a company > that analyzes signal spectrum using FFT. The spectrum lines is only > selectable among 1600, 3200, 6400, 12800, and the sampling period is > not integral times of signal period. The spectrum result, amazingly, > is very close to the one we obtained with standard radix-2 FFT > algorithm sampling for integral signal period.The spectrum analyzer works because the DFT is far more robust to signal parameters than you think. Just take one second to contemplate what you wrote in the paragraph above: IF the FFT happened to depend on signal parameters as strongly as you suggest (it doesn't), that would mean that the designers of the spectrum analyzers would have to make equipment that would have to be able to work at all possible sampling frequencies. It is both very hard and very expensive to make that sort of equipment. Second, you as analyst would have to know what the signal looks like in advance, *before* making an actual measurement, in order to select the correct settings. Whitch is something of a Catch 22 situation.> My question is, is there some specical FFT algorithm that sample for a > fixed time (i.e., probably fractional signal period) but can realize > similiar spectrum result as that obtained by standard FFT algorithm > with integral signal period?Well, the DFT is a *representation* of the data which is very robust, and gives useful results for statonary (not necessarily periodic) data. The key is to remember that the DFT gives the 'big picture' for these general types of data, but you can't trust the details. The details match to prefection only with very special classes of periodic data, where the signal is sampled over an integer multiple of periods etc. Rune
On Mar 26, 4:27 am, Rune Allnor <all...@tele.ntnu.no> wrote:> ... > Well, the DFT is a *representation* of the data which is very > robust, and gives useful results for statonary (not necessarily > periodic) data. The key is to remember that the DFT gives the > 'big picture' for these general types of data, but you can't > trust the details. The details match to prefection only with > very special classes of periodic data, where the signal is > sampled over an integer multiple of periods etc. > > RuneDavid The above has a very 'formalist derived' slant. I would put it differently, and perhaps no more usefully as: Well, the DFT is an exact *representation* of the data within it's window which is very robust, and gives useful results, and for statonary (not necessarily periodic) data gives useful results about data outside it's window. If you want exact representation to be correct at other times, calculate another DFT for a data window then. The key is to remember that the DFT gives the 'big picture' for these general types of data, but you can't trust the details to be ideal. The details match to the ideal only with very special classes of data, where the data window and transform size contain samples over an integer multiple of periods etc. For a good general discussion of spectrum estimation related issues with less slant than either of the above try: Power Spectrum Estimation (04-Nov-1995) http://www.national.com/an/AN/AN-255.pdf Dale B. Dalrymple
On Mar 26, 3:27 am, Rune Allnor <all...@tele.ntnu.no> wrote:> On 26 Mar, 06:07, engp0...@gmail.com wrote: > > I am new to signal processing, so please don't laugh if my questions > > appear silly to you. > > > In my knowledge, to get accurate spectrum result using FFT, the > > sampling period should be close to the integal times of the whole > > cycles of input signal period > > Wrong. The DFT is a representation of the input sequence which > is exact to within numerical accuracy, regardless of the > properties of the input signal.I note that the two above claims are talking about two differently worded concepts, depending on how much the OP's definition of "accurate spectrum result" corresponds with Rune's "accurate representation". If the OP considers an FFT only to produce an "accurate spectrum result" if, say, just the 5 peak bins correspond exactly to a signal composed of 5 arbitrary frequency sinusoids (below Fs/2), then the two above claims are not necessarily contradictory. IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
"Ron N." <rhnlogic@yahoo.com> wrote in message news:3a52c80e-9308-4e3f-9f25-386381db1318@i7g2000prf.googlegroups.com...> On Mar 26, 3:27 am, Rune Allnor <all...@tele.ntnu.no> wrote: >> On 26 Mar, 06:07, engp0...@gmail.com wrote: >> > I am new to signal processing, so please don't laugh if my questions >> > appear silly to you. >> >> > In my knowledge, to get accurate spectrum result using FFT, the >> > sampling period should be close to the integal times of the whole >> > cycles of input signal period >> >> Wrong. The DFT is a representation of the input sequence which >> is exact to within numerical accuracy, regardless of the >> properties of the input signal. > > I note that the two above claims are talking about > two differently worded concepts, depending on how much > the OP's definition of "accurate spectrum result" > corresponds with Rune's "accurate representation". > > If the OP considers an FFT only to produce an "accurate > spectrum result" if, say, just the 5 peak bins correspond > exactly to a signal composed of 5 arbitrary frequency > sinusoids (below Fs/2), then the two above claims are not > necessarily contradictory. >Yes. Another way to say it is that the OP really wants to compute a Fourier Series of an actual periodic waveform and is using the DFT to do that. Probably no reason why not. It's just a slightly unusual way of looking at things. But it does help one understand the difference between a Fourier Series and a general DFT. One (the DFT or a Fourer Transform of a windowed function) has spectral leakage in general and one (a Fourier Series) doesn't perforce. The only other thing to say is that since time is discrete here that the Fourier Series integral over one period becomes finite sum over one period. That's why the DFT can do the "work" of computing a Fourier Series. Fred
On Mar 25, 10:07 pm, engp0...@gmail.com wrote:> Hi, > > I am new to signal processing, so please don't laugh if my questions > appear silly to you. > > In my knowledge, to get accurate spectrum result using FFT, the > sampling period should be close to the integal times of the whole > cycles of input signal period and the sampling points should be 2^n. > For example, 1KHz square wave, the sampling time should be integal > times of 1ms, i.e., 10ms. However, I am using a system from a company > that analyzes signal spectrum using FFT. The spectrum lines is only > selectable among 1600, 3200, 6400, 12800, and the sampling period is > not integral times of signal period. The spectrum result, amazingly, > is very close to the one we obtained with standard radix-2 FFT > algorithm sampling for integral signal period. > > My question is, is there some specical FFT algorithm that sample for a > fixed time (i.e., probably fractional signal period) but can realize > similiar spectrum result as that obtained by standard FFT algorithm > with integral signal period? > > Hopefully I made myself understood. > > Any contribution to this question is appreciated. > DavidDavid Another general reference is at: http://cp.literature.agilent.com/litweb/pdf/5988-6774EN.pdf To deal with the case of signals not having an integer number of cycles in the DFT window and transform size there are at least 5 common responses: 1) generate the sampling frequency to enforce integer number of cycles... Fred has already mention the use of tachs for this. Some references: http://www.home.agilent.com/upload/cmc_upload/All/6C06DATAACQ_ORDER.pdf http://www.ni.com/pdf/labview/us/order_analysis_toolkit.pdf http://pcfarina.eng.unipr.it/Public/Kalman/SAE_972006.pdf 2) resample the time domain data to a new sampling frequency that provides an integer number of cycles... 3) resample the complex frequency domain coefficients at the desired frequencies. In some circles such as IEEE Trans. on Instrumentation and Measurement this is refered to as the 'interpolated FFT' 4) interpolate the peaks of the magnitude response in the frequency domain, such as is included in the good discussion in: http://www.ericjacobsen.org/FTinterp.pdf 5) pick the nearest bin and accept the error or complain about the inaccuracy of the FFT (It ain't like my actual Fourier transform.) I hope these references may be of some use to you. Nevermind while the rest of us sit back in our armchairs, wave our hands and philosophize here at length. Dale B. Dalrymple
Fred Marshall wrote: (snip)> Yes. Another way to say it is that the OP really wants to compute a Fourier > Series of an actual periodic waveform and is using the DFT to do that. > Probably no reason why not. It's just a slightly unusual way of looking at > things. But it does help one understand the difference between a Fourier > Series and a general DFT. One (the DFT or a Fourer Transform of a windowed > function) has spectral leakage in general and one (a Fourier Series) doesn't > perforce.I always thought it should have been called FFS (Fast Fourier Series), along with DFS, DSS, and DCS.> The only other thing to say is that since time is discrete here that the > Fourier Series integral over one period becomes finite sum over one period. > That's why the DFT can do the "work" of computing a Fourier Series.Time is always discrete when doing an FFT, whether you like it or not. You might be simulating continuous time, but the transform is done in discrete time. It would seem to me, then, that the transform name assumes one is simulating continuous time, but the transform doesn't know that. -- glen
On Tue, 25 Mar 2008 22:07:23 -0700 (PDT), engp0931@gmail.com wrote:>Hi, > >I am new to signal processing, so please don't laugh if my questions >appear silly to you.Hi David, Your questions are definitely NOT silly. Although we do have to make assumptions on what are the meanings of some of the terminology that you used in your questions.>In my knowledge, to get accurate spectrum result using FFT, the >sampling period should be close to the integal times of the whole >cycles of input signal period and the sampling points should be 2^n.If by "accurate" you mean FFT results that show very little "leakage", then I believe your statement is essentially correct. However, real-world (information carrying) signals are not periodic. So the idea of having the time-duration of the FFT's input sequence being an integer multiple of some signal's period goes "out the window".>For example, 1KHz square wave, the sampling time should be integal >times of 1ms, i.e., 10ms.As Rune said, squarewaves have an infinite bandwidth so squarewaves are not a good example of a periodic time sequence for use in discussing the "accuracy" of the FFT.>However, I am using a system from a company >that analyzes signal spectrum using FFT. The spectrum lines is only >selectable among 1600, 3200, 6400, 12800, and the sampling period is >not integral times of signal period. The spectrum result, amazingly, >is very close to the one we obtained with standard radix-2 FFT >algorithm sampling for integral signal period.Oops. I don't know what you mean by "spectrum lines" as it pertains to your "system".>My question is, is there some specical FFT algorithm that sample for a >fixed time (i.e., probably fractional signal period) but can realize >similiar spectrum result as that obtained by standard FFT algorithm >with integral signal period?Assuming I understand your question, my answer is, "None that I know of." People use the process of "windowing" their time-damain samples to reduce "FFT leakage", but I know of no algorithm that will totally eliminate FFT leakage due to non-periodic input signals. Good Luck, [-Rick-]
On Mar 26, 10:58 am, dbd <d...@ieee.org> wrote:> On Mar 25, 10:07 pm, engp0...@gmail.com wrote: > > I am new to signal processing, so please don't laugh if my questions > > appear silly to you. > > > In my knowledge, to get accurate spectrum result using FFT, the > > sampling period should be close to the integal times of the whole > > cycles of input signal period and the sampling points should be 2^n. > > For example, 1KHz square wave, the sampling time should be integal > > times of 1ms, i.e., 10ms. However, I am using a system from a company > > that analyzes signal spectrum using FFT. The spectrum lines is only > > selectable among 1600, 3200, 6400, 12800, and the sampling period is > > not integral times of signal period. The spectrum result, amazingly, > > is very close to the one we obtained with standard radix-2 FFT > > algorithm sampling for integral signal period. > > > My question is, is there some specical FFT algorithm that sample for a > > fixed time (i.e., probably fractional signal period) but can realize > > similiar spectrum result as that obtained by standard FFT algorithm > > with integral signal period? > > > Hopefully I made myself understood. > > > Any contribution to this question is appreciated. > > David > > David > > Another general reference is at: > > http://cp.literature.agilent.com/litweb/pdf/5988-6774EN.pdf > > To deal with the case of signals not having an integer number of > cycles in the DFT window and transform size there are at least 5 > common responses: > > 1) generate the sampling frequency to enforce integer number of > cycles... > Fred has already mention the use of tachs for this. Some references: > > http://www.home.agilent.com/upload/cmc_upload/All/6C06DATAACQ_ORDER.pdfhttp://www.ni.com/pdf/labview/us/order_analysis_toolkit.pdfhttp://pcfarina.eng.unipr.it/Public/Kalman/SAE_972006.pdf > > 2) resample the time domain data to a new sampling frequency that > provides an integer number of cycles... > > 3) resample the complex frequency domain coefficients at the desired > frequencies. In some circles such as IEEE Trans. on Instrumentation > and Measurement this is refered to as the 'interpolated FFT'3b) zero-padding and using a longer FFT is one method of computing interpolated or resampled frequency domain coefficients, and may be more computationally efficient than other methods of resampling.> 4) interpolate the peaks of the magnitude response in the frequency > domain, such as is included in the good discussion in: > > http://www.ericjacobsen.org/FTinterp.pdf4b) if by "accurate" you mean accurate magnitude, then you could use a "flat-top" window before the FFT, which then trivializes magnitude "interpolation" in the frequency domain.> 5) pick the nearest bin and accept the error or complain about the > inaccuracy of the FFT (It ain't like my actual Fourier transform.)This seems to be the most common response from non-DSP students attempting to use an FFT.> I hope these references may be of some use to you. > > Nevermind while the rest of us sit back in our armchairs, wave our > hands and philosophize here at length.I have more "hand waving" references regarding various random attempts at frequency estimation on my DSP web page: http://www.nicholson.com/rhn/dsp.html IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
