Can a LPF have linear phase when the impuse response is not symmetric?
Started by miner_tom March 30, 2008
On Sun, 30 Mar 2008 09:13:26 -0700, "miner_tom" <tom_nospam@yahoo.com>
wrote:
>Oppenheimer says that this figure shows a "linear phase system for which the >impulse response is not symmetric". I do not understand that statement.
>On page 309 there are figures showing the decimated impulse responses of the >various polyphase subfilters. The decimated impulse responses exhibit no >symmetry that I can see even though the original prototype filter is >symmetic. Each of the subfilters is described as having linear phase.
Linear phase only means that the phase is a linear function of frequency (so that the first derivative is a constant). Impulse response symmetry is sufficient to produce linear phase, but not necessary, at least not in the discrete-time case. The problem is in the definition of symmetry. If one adheres strictly to the definition as (from page 5-34 of the Oppenheim presentation that you cited): h(n) = h(M-n); 0<=n<=M 0; otherwise or h(n) = -h(M-n); 0<=n<=M 0; otherwise then if the envelope of the impulse response is delayed by anything other than an integer multiple of one-half the sample period, the symmetry definition is no longer satisfied, even though the phase is still linear. This can be avoided by broadening the definition of symmetry to apply to the envelope, and not just to the discrete-time samples themselves. Greg
On Mar 30, 9:13 am, "miner_tom" <tom_nos...@yahoo.com> wrote:
> Hi, > > I had always believed that in order to have linear phase or constant group > delay, the impulse response of a digital filter needed to have even symmetry > or odd symmetry. In "Discrete time signal processing" by Oppenheim and > Shafer, there is a section on "Generalized systems with linear phase". There > is a figure, 5.32C where the impulse response is not symmetric but the > filter is said to have the property of linear phase. > > Here is a link to a PPT lecture that uses this figure from the book and the > slide in question is 5-33. The link should open to the proper slide. > > http://www.vcipl.okstate.edu/~glfan/ECEN5763/chapter5.ppt#289,33,Example > > Oppenheimer says that this figure shows a "linear phase system for which the > impulse response is not symmetric". I do not understand that statement. > > There is another example of this in a very famous paper concerning Polyphase > filtering, "Interpolation and decimation of Digital Signals" by Crochiere > and Rabiner. The identical arguments appear in the book "Multirate Digital > Signal processing" by the same authors. > > Here is a link to the paper. > > http://www.caip.rutgers.edu/~lrr/lrr%20papers/179_interpolation_decim... > > On page 309 there are figures showing the decimated impulse responses of the > various polyphase subfilters. The decimated impulse responses exhibit no > symmetry that I can see even though the original prototype filter is > symmetic. Each of the subfilters is described as having linear phase. Each > of the subfilters has a different linear phase because the samples in each > subfilter have a different relationship to the center of symmetry of the > original prototype filter. > > What is the fundamental concept that I have missed? > > Thank You > Tom > tom_cip_11...@hotmail.com
What is broken is your substitution of "exhibit symmetry I can see" for the possession symmetry. The symmetries you have learned to "see" at this point are symmetries about a sample point or a point half-way between samples. But a uniform sampling (satisfying Nyquist) of a symmetric waveform is still symmetric. You just haven't learned to "see" these symmetries. The set you know and have learned to "see" as symmetric doesn't span the concept. As Wil Rogers once said, "The problem isn't what we don't know so much as what we know that ain't so." Dale B Dalrymple
On Mar 30, 5:29 am, Greg Berchin <gberc...@comicast.net> wrote:
> On Sun, 30 Mar 2008 09:13:26 -0700, "miner_tom" <tom_nos...@yahoo.com> > wrote: > > >Oppenheimer says that this figure shows a "linear phase system for which the > >impulse response is not symmetric". I do not understand that statement. > > ... > > >On page 309 there are figures showing the decimated impulse responses of the > >various polyphase subfilters. The decimated impulse responses exhibit no > >symmetry that I can see even though the original prototype filter is > >symmetic. Each of the subfilters is described as having linear phase. > > Linear phase only means that the phase is a linear function of > frequency (so that the first derivative is a constant). Impulse > response symmetry is sufficient to produce linear phase, but not > necessary, at least not in the discrete-time case. The problem is in > the definition of symmetry. If one adheres strictly to the definition > as (from page 5-34 of the Oppenheim presentation that you cited): > > h(n) = h(M-n); 0<=n<=M > 0; otherwise > or > h(n) = -h(M-n); 0<=n<=M > 0; otherwise > > then if the envelope of the impulse response is delayed by anything > other than an integer multiple of one-half the sample period, the > symmetry definition is no longer satisfied, even though the phase is > still linear. This can be avoided by broadening the definition of > symmetry to apply to the envelope, and not just to the discrete-time > samples themselves. > > Greg
I have proof in another book that you get linear phase rom 4 possible cases: Even number of weights,even symmetry Odd number of weights,even symmetry Even number of weights, odd symmetry Odd numberof weights, odd symmetry. They all have their applications too. In the case of an even number of weights the centry point is between samples. K.
On Mar 29, 12:55 pm, kronec...@yahoo.co.uk wrote:
> On Mar 30, 5:29 am, Greg Berchin <gberc...@comicast.net> wrote: > > > > > On Sun, 30 Mar 2008 09:13:26 -0700, "miner_tom" <tom_nos...@yahoo.com> > > wrote: > > > >Oppenheimer says that this figure shows a "linear phase system for which the > > >impulse response is not symmetric". I do not understand that statement. > > > ... > > > >On page 309 there are figures showing the decimated impulse responses of the > > >various polyphase subfilters. The decimated impulse responses exhibit no > > >symmetry that I can see even though the original prototype filter is > > >symmetic. Each of the subfilters is described as having linear phase. > > > Linear phase only means that the phase is a linear function of > > frequency (so that the first derivative is a constant). Impulse > > response symmetry is sufficient to produce linear phase, but not > > necessary, at least not in the discrete-time case. The problem is in > > the definition of symmetry. If one adheres strictly to the definition > > as (from page 5-34 of the Oppenheim presentation that you cited): > > > h(n) = h(M-n); 0<=n<=M > > 0; otherwise > > or > > h(n) = -h(M-n); 0<=n<=M > > 0; otherwise > > > then if the envelope of the impulse response is delayed by anything > > other than an integer multiple of one-half the sample period, the > > symmetry definition is no longer satisfied, even though the phase is > > still linear. This can be avoided by broadening the definition of > > symmetry to apply to the envelope, and not just to the discrete-time > > samples themselves. > > > Greg > > I have proof in another book that you get linear phase rom 4 possible > cases: > > Even number of weights,even symmetry > Odd number of weights,even symmetry > Even number of weights, odd symmetry > Odd numberof weights, odd symmetry. > > They all have their applications too. In the case of an even number of > weights the centry point is between samples. > > K.
Yes K These symmetries guarantee linear phase. Linear phase doesn't guarantee these symmetries. Note that for weight sets having the same delay, any linear combination of the weight sets with these symmetries will have linear phase. I suggest that any weight set with linear phase can be decomposed into no more than 4 weight sets with these symmetries and that is why you find them in your texts. Dale B. Dalrymple
On Mar 30, 8:27 am, dbd <d...@ieee.org> wrote:
> On Mar 29, 12:55 pm, kronec...@yahoo.co.uk wrote: > > > > > On Mar 30, 5:29 am, Greg Berchin <gberc...@comicast.net> wrote: > > > > On Sun, 30 Mar 2008 09:13:26 -0700, "miner_tom" <tom_nos...@yahoo.com> > > > wrote: > > > > >Oppenheimer says that this figure shows a "linear phase system for which the > > > >impulse response is not symmetric". I do not understand that statement. > > > > ... > > > > >On page 309 there are figures showing the decimated impulse responses of the > > > >various polyphase subfilters. The decimated impulse responses exhibit no > > > >symmetry that I can see even though the original prototype filter is > > > >symmetic. Each of the subfilters is described as having linear phase. > > > > Linear phase only means that the phase is a linear function of > > > frequency (so that the first derivative is a constant). Impulse > > > response symmetry is sufficient to produce linear phase, but not > > > necessary, at least not in the discrete-time case. The problem is in > > > the definition of symmetry. If one adheres strictly to the definition > > > as (from page 5-34 of the Oppenheim presentation that you cited): > > > > h(n) = h(M-n); 0<=n<=M > > > 0; otherwise > > > or > > > h(n) = -h(M-n); 0<=n<=M > > > 0; otherwise > > > > then if the envelope of the impulse response is delayed by anything > > > other than an integer multiple of one-half the sample period, the > > > symmetry definition is no longer satisfied, even though the phase is > > > still linear. This can be avoided by broadening the definition of > > > symmetry to apply to the envelope, and not just to the discrete-time > > > samples themselves. > > > > Greg > > > I have proof in another book that you get linear phase rom 4 possible > > cases: > > > Even number of weights,even symmetry > > Odd number of weights,even symmetry > > Even number of weights, odd symmetry > > Odd numberof weights, odd symmetry. > > > They all have their applications too. In the case of an even number of > > weights the centry point is between samples. > > > K. > > Yes K > > These symmetries guarantee linear phase. > > Linear phase doesn't guarantee these symmetries. > > Note that for weight sets having the same delay, any linear > combination of the weight sets with these symmetries will have linear > phase. > > I suggest that any weight set with linear phase can be decomposed into > no more than 4 weight sets with these symmetries and that is why you > find them in your texts. > > Dale B. Dalrymple
Ok is that what you mean by sufficent but not nescessary? I have always been confused with these terms.. K.
kronecker@yahoo.co.uk writes:
> [...] > Ok is that what you mean by sufficent but not nescessary? I have > always been confused with these terms..
"p -> q" (read "p implies q", or "if p then q") is equivalent to saying "p is sufficient for q" and "q is necessary for p". The contrapositive (which is equivalent logicially) is ~q -> ~p (where "~" denotes "not" or negation). The converse (which is NOT logically equivalent) is "p -> q". As an example, let "p" be "pregnant human" and "q" be "human female". So p -> q means "Being a pregnant human is a sufficient condition for being a human female" or, in the contrapositive, "If you're not a human female, then you're not a pregnant human." Notice that the converse is NOT true: "If you're a human female, then you're a pregnant human." The notation "p <-> q" means "p if and only if q" ("if and only if" is sometimes abbreviated "iff") or "p is necessary and sufficient for q". It is a short-hand way of asserting that both "p -> q" and "q -> p". For example, "A mapping is invertible iff the mapping is one-to-one and onto." [durbin] has a set of appendices that discusses this as well as other "tricky" yet fundamental logic ideas (such as set equivalent) in his text on modern algebra. Dated, but highly recommended if you're near a library. --Randy @book{durbin, title = "Modern Algebra: An Introduction", author = "John~R.~Durbin", edition = "3rd", year = "1992", publisher = "John Wiley \& Sons, Inc."} -- % Randy Yates % "I met someone who looks alot like you, %% Fuquay-Varina, NC % she does the things you do, %%% 919-577-9882 % but she is an IBM." %%%% <yates@ieee.org> % 'Yours Truly, 2095', *Time*, ELO http://www.digitalsignallabs.com
Randy Yates <yates@ieee.org> writes:
> [...] > The converse (which is NOT logically equivalent) is "p -> q".
Sorry, that should be "q -> p". -- % Randy Yates % "Ticket to the moon, flight leaves here today %% Fuquay-Varina, NC % from Satellite 2" %%% 919-577-9882 % 'Ticket To The Moon' %%%% <yates@ieee.org> % *Time*, Electric Light Orchestra http://www.digitalsignallabs.com
On Sat, 29 Mar 2008 12:29:29 -0500, Greg Berchin
<gberchin@comicast.net> wrote:
>Linear phase only means that the phase is a linear function of >frequency (so that the first derivative is a constant).
Having said that, let me attempt a thought experiment. Suppose I have a system with real, even-symmetric impulse response (note that the value at n=0 is zero): . x x . x| |x . x|| ||x . x||| |||x . x|||| ||||x -----------------x-----x-----x------------------ <- -n*Ts 0 +n*Ts -> Because the system is real, the real part of the spectrum will be even-symmetric and the imaginary part will be odd-symmetric. In this case the spectrum will be purely real; the phase will be everywhere zero. Now suppose that I have another system with real, odd-symmetric impulse response: . x . |x . ||x . |||x . ||||x -----------------x-----x-----x------------------ <- -n*Ts x|||| +n*Ts -> x||| x|| x| x Because the system is real, the real part of the spectrum will be even-symmetric and the imaginary part will be odd-symmetric. In this case the spectrum will be pure-imaginary; the phase will be -PI/2 at positive frequencies and +PI/2 at negative frequencies (assuming the definition of the FT having the "-j" term in the forward transform). Now I add the two impulse responses together: . x . | . |x . || . ||x . ||| . |||x . |||| . ||||x . ||||| -----------------------x-----x------------------ <- -n*Ts 0 +n*Ts -> Because the system is real, the real part of the spectrum will be even-symmetric and the imaginary part will be odd-symmetric. In this case the phase will be -PI/4 at positive frequencies and +PI/4 at negative frequencies (because the magnitudes of the real and imaginary parts are equal to each other at every frequency). Now here's what's confusing me: Except for the discontinuity at n=0, this system is linear phase (the first derivative of the phase is, in fact, zero). Yet neither the impulse response nor the envelope of the impulse response is symmetrical about any point in time. What is the proper way to interpret this? Greg
Hi,
http://www.caip.rutgers.edu/~lrr/lrr%20papers/179_interpolation_decimation.pdf
Thank You
Tom
tom_cip_11551@hotmail.com
