I'm trying to set up my XDS510PP on a Windows XP laptop that uses a Quatech SPP-100 PCMCIA parallel port card. I was able to set up the card correctly and mapped its resources to I/O range 0x378-0x37F, and set its IRQ to 7. The card shows up in the device manager without an asterisk/exclamation mark, so I'm guessing it's set up correctly as far as windows is concerned. However, SDConfig refuses to detect a parallel port when I select: Configuration->Ports Available->Printer The funny thing is that previously I tried using a USB-to-Parallel cable (which supported neither ECP or EPP), which did show up as a parallel port at that step. Does anyone have experience with using these two together? Thanks a ton!
Quatech SPP-100 with XDS510PP
Started by ●April 1, 2008
