Hi, I am new to this programming world, and i really need some serious help. I have done a program in which i design a filter in frequency domain, then i take a CT image, which is a 3d image, read each voxel and make a 1d array. then i equal the number of samples for both the data set. so i have equal samples. then i do convolution using fftw3 library. but what happens is that i am doing circular convolution, I want help to do this as a linear convolution. please help me with this. waiting for your replies. any other data you need please let me know. thank you.
Circular convolution to Linear convolution.
Started by ●April 2, 2008
Reply by ●April 2, 20082008-04-02
usual process of getting the effect of linear convolution. if x is data and h is filter M = data length N = filter length then zero pad x with N-1 zeros zero pad h with M-1 zeros perform FFT of both x and h with length >= M+N-1 do multiplication in complex domain to get the effect of filter. perform IFFT and get back y(n) hope this helps, regards bharat pathak Arithos Designs www.Arithos.com %--- DSP design consultancy and training company ------------>Hi, > I am new to this programming world, and i really need some serioushelp.>I have done a program in which i design a filter in frequency domain,then>i take a CT image, which is a 3d image, read each voxel and make a 1d >array. then i equal the number of samples for both the data set. so ihave>equal samples. then i do convolution using fftw3 library. but whathappens>is that i am doing circular convolution, I want help to do this as a >linear convolution. please help me with this. waiting for your replies. >any other data you need please let me know. > >thank you. > > >
