Need algorithm to "stabilize" input data
Started by Ciaccia April 7, 2008
Hi all,
I need an algorithm that "stabilizes" the input data I get from a sensor.
The sensor does not capture "perfect" data, and sometimes the data
oscillates around the real value I'm looking for. For example, consider
the following input:
|-----------|----|-----x------|-|-------|------
A           B    C     S      D E       F
In this chart, the asterisks represent the data I get from the sensor.
What I would like to obtain is a chart where the segments A-B, C-D and E-F
are flat (i.e., the oscillation around the "real" value is removed).
Furthermore, I need an algorithm that works in real-time, that is while
the sensor captures the data (I don't have the future samples), and I
can't wait for them.
Sometimes the sensor really gets a wrong sample, for example as in S. The
"wrong" samples should be thrown away.
I tried several simple approaches (for example averaging the old samples),
but none of the was good enough for my needs. I think this is a common
problem, is anyone aware of existing algorithms to solve this problem?
Every help is appreciated
Thanks a lot
Andrea
I noticed that the chart does not look very nice... :-(
I try to put it here again:
<pre>|  *
A           B    C     S      D E       F</pre>
If this should not work, please look at this picture:
http://www.pecore.ch/Ciaccia/chart.png
Sorry for all the mess ;-)
"Ciaccia" <ciacciax@yahoo.com> wrote in message
news:u5WdnWAbheWLfGTanZ2dnUVZ_hadnZ2d@giganews.com...
> Hi all, > I need an algorithm that "stabilizes" the input data I get > from a sensor. > The sensor does not capture "perfect" data, and sometimes the > data > oscillates around the real value I'm looking for. For > example, consider > the following input: > > | * > |** ** ** ** * > | ** * * > | * * > | * *** ** ** > | * ** * * > | ** ** **** ** > | * > |-----------|----|-----x------|-|-------|------ > A B C S D E F > > In this chart, the asterisks represent the data I get from > the sensor. > What I would like to obtain is a chart where the segments > A-B, C-D and E-F > are flat (i.e., the oscillation around the "real" value is > removed). > Furthermore, I need an algorithm that works in real-time, > that is while > the sensor captures the data (I don't have the future > samples), and I > can't wait for them. >
Depending on how you identify A-B, C-D, etc., you might be able to use the median of each of these intervals to filter the data. (By way of a quick review, sort a window of N samples, emit the one in the middle of the sorted list, and then advance your N-sample window by one sample.) It can require a lot of processing, but I've found this filter to be very effective at dealing with outliers and similar anomalies. If you can tolerate some delay in your processed data stream, you can make your filter "think" it is able to work on future samples. That is, if you can tolerate D units of delay, then, after you obtain sample K, you do some processing to emit output K-D. Compared to its output, your filter is looking D units into the future. Not all real-time systems can tolerate much delay; it depends on what you are doing with the sensor data.
On 7 Apr, 10:53, "Ciaccia" <ciacc...@yahoo.com> wrote:
> Hi all, > I need an algorithm that "stabilizes" the input data I get from a sensor.
> I tried several simple approaches (for example averaging the old samples), > but none of the was good enough for my needs. I think this is a common > problem, is anyone aware of existing algorithms to solve this problem?
Kalman filter? Rune
Hi,
  I think a simple hysteresis filter should do.
  step 1 : perform very simple LPF.
  step 2 : perform hystersis option.
  I think your states are pretty much well defined.
  Also these states will be guided by thresholds.
  Meaning if the signal falls within r1 to r2 range
  consider it at state 1. and a state is not changed
  for some instantaneous or erroneaous transitions.
  Check for a stable change for sometime.
  Hysteresis logics are normally implemented using
  counter arithmetic and thresholds. It is a form
  of a state machine.
Regards
Bharat Pathak
Arithos Designs
www.Arithos.com
You can also use a circular buffer of size "N".  Determine the average
of the values in the buffer every time a new sample is added.  This
works well in environments where the data is oscillating around a
threshold.
Kind Regards,
Jaco
On Mon, 07 Apr 2008 03:53:42 -0500, "Ciaccia" <ciacciax@yahoo.com>
wrote:
>Hi all, >I need an algorithm that "stabilizes" the input data I get from a sensor. >The sensor does not capture "perfect" data, and sometimes the data >oscillates around the real value I'm looking for. For example, consider >the following input: > >| * >|** ** ** ** * >| ** * * >| * * >| * *** ** ** >| * ** * * >| ** ** **** ** >| * >|-----------|----|-----x------|-|-------|------ >A B C S D E F > >In this chart, the asterisks represent the data I get from the sensor. >What I would like to obtain is a chart where the segments A-B, C-D and E-F >are flat (i.e., the oscillation around the "real" value is removed). >Furthermore, I need an algorithm that works in real-time, that is while >the sensor captures the data (I don't have the future samples), and I >can't wait for them.
Do you know how fast the change can be in the "real" data ? ie the width of B-C, D-E? If they're slow enough sharp low-pass filter may work. By "I can't wait for them (future samples)" do you mean that you can not tolerate any latency (ie buffer to see what the "future" samples look like)
>On Mon, 07 Apr 2008 03:53:42 -0500, "Ciaccia" <ciacciax@yahoo.com> >wrote: > >>Hi all, >>I need an algorithm that "stabilizes" the input data I get from a
sensor.
>>The sensor does not capture "perfect" data, and sometimes the data >>oscillates around the real value I'm looking for. For example, consider >>the following input: >> >>| * >>|** ** ** ** * >>| ** * * >>| * * >>| * *** ** ** >>| * ** * * >>| ** ** **** ** >>| * >>|-----------|----|-----x------|-|-------|------ >>A B C S D E F >> >>In this chart, the asterisks represent the data I get from the sensor. >>What I would like to obtain is a chart where the segments A-B, C-D and
E-F
>>are flat (i.e., the oscillation around the "real" value is removed). >>Furthermore, I need an algorithm that works in real-time, that is while >>the sensor captures the data (I don't have the future samples), and I >>can't wait for them. > >Do you know how fast the change can be in the "real" data ? ie the >width of B-C, D-E? If they're slow enough sharp low-pass filter may >work. By "I can't wait for them (future samples)" do you mean that you >can not tolerate any latency (ie buffer to see what the "future" >samples look like)
Hi all, First I would like to thank everyone for the suggestions! I tried the algorithm working with the median John (3rd post) suggested, and works pretty well (even if not in all cases). The situation my program has to deal with is very simple, I try to summarize it: -I don't know how fast the data changes (going from one "state" to another could take 2 samples or 30) -the width of a flat "segment" has at least a given length (say 4 samples) -there are not pre-defined statuses (as Bharat suggested). -every time a new sample is captured, my program needs to print an output (i.e., I cannot wait for the next samples that will captured to print a result) If not "sure", return the more likely outcome I understand this problem is somehow complex, consider the following scenario. time 0: the sensor captures 10 time 1: the sensor captures 9 time 2: the sensor captures 8 time 3: the sensor captures 7 time 4: the sensor captures 7 time 5: the sensor captures 6 time 6: the sensor captures 7 If I look at the captured data at time 6, I can easily see that the interval from time 0 to time 2 is a (descending) transition phase, and that at time 3 starts a "flat" phase that goes from time 3 to time 7 (the phase I am interested in). If at time 3 I look at the available data, I cannot say if the samples at time 3 is a sample of the descending transition phase, or if it is the start of the flat phase. At time 4, having more information available, I could say "it's possible that at time 3, a flat phase started". Continuing with the logic, at time 6 I can say for sure at time 3 started a flat phase, since I can look at the past samples. My goal (even if I understand is not fully achievable) is to minimize the "latency" I need to find the flat phases and print them. I guess I must play statistically or create an hidden model, since at time 4 I cannot be sure a flat phase started at three... Maybe I should add probabilities to my computations... Any hints?
"Ciaccia" <ciacciax@yahoo.com> writes:
> Hi all, > I need an algorithm that "stabilizes" the input data I get from a sensor. > The sensor does not capture "perfect" data, and sometimes the data > oscillates around the real value I'm looking for. For example, consider > the following input: > > | * > |** ** ** ** * > | ** * * > | * * > | * *** ** ** > | * ** * * > | ** ** **** ** > | * > |-----------|----|-----x------|-|-------|------ > A B C S D E F > > In this chart, the asterisks represent the data I get from the sensor. > What I would like to obtain is a chart where the segments A-B, C-D and E-F > are flat (i.e., the oscillation around the "real" value is removed). > Furthermore, I need an algorithm that works in real-time, that is while > the sensor captures the data (I don't have the future samples), and I > can't wait for them.
Then your task is impossible because, e.g., in the segment E-F at the third data point (0-indexed), you don't yet know whether data points 0, 1, and 2 are correct and 4 is the deviant or vice-versa. If you could wait until the segment endpoints, e.g., B, D, and F, and have knowledge of the segment begin points and endpoints, then you can simply take a majority vote of the histogram over the segment. -- % Randy Yates % "Watching all the days go by... %% Fuquay-Varina, NC % Who are you and who am I?" %%% 919-577-9882 % 'Mission (A World Record)', %%%% <yates@ieee.org> % *A New World Record*, ELO http://www.digitalsignallabs.com
Correction:
Randy Yates <yates@ieee.org> writes:
> [...] > and 4 is the deviant [...]
and 3 is the deviant [...] -- % Randy Yates % "...the answer lies within your soul %% Fuquay-Varina, NC % 'cause no one knows which side %%% 919-577-9882 % the coin will fall." %%%% <yates@ieee.org> % 'Big Wheels', *Out of the Blue*, ELO http://www.digitalsignallabs.com
