We have images with regularly spaced noise. Specifically it occurs every 24 columns of the image, e.g. columns 24, 48, 72, 96, .... There is also weaker noise beside this, so columns 23, 25, 47, 49, 71, 73 etc. are affected. So altogether 1/8 of the image is ruined. The noise is incoherent, but not exactly random: it is predominantly low frequency down the column. So the approach tried by a colleague was to transform each column to frequency domain and kill the low frequency components (on the noisy columns only). Then interpolate these from the adjacent columns with a prediction error filter. However, this did not work as well as he expected. Are there algorithms which can attenuate regularly spaced but incoherent noise?
how to remove incoherent but regularly-spaced noise?
Started by ●April 8, 2008
Reply by ●April 8, 20082008-04-08
Anonymous wrote:> We have images with regularly spaced noise. > Specifically it occurs every 24 columns of the image, > e.g. columns 24, 48, 72, 96, .... > There is also weaker noise beside this, so columns > 23, 25, 47, 49, 71, 73 etc. are affected. So altogether > 1/8 of the image is ruined. The noise is incoherent, but > not exactly random: it is predominantly low frequency > down the column. > So the approach tried by a colleague was to transform > each column to frequency domain and kill the low frequency > components (on the noisy columns only). Then interpolate > these from the adjacent columns with a prediction error filter. > However, this did not work as well as he expected.Why do you first filter the column if you are going to replace them via interpolation? I'm probably misunderstanding you. Anycase, if you view this row-wise, interpolation via prediction filters might work, but you need a non-linear approach to "train" the prediction filter. You have to assume the missing pixels unknown.> Are there algorithms which can attenuate regularly spaced > but incoherent noise?There is another simple approach [1] to reconstruct the periodically missing columns that works under mild bandwidth constraints. Contact me if you cannot access [1]. Regards, Andor [1] A. Bariska, "Recovering Periodically-Spaced Missing Samples," IEEE Signal Process. Mag., DSP Tips and Tricks column, vol. 24, Nov. 2007.
On 8 Apr., 10:00, Andor <andor.bari...@gmail.com> wrote:> Anonymous wrote: > > We have images with regularly spaced noise. > > Specifically it occurs every 24 columns of the image, > > e.g. columns 24, 48, 72, 96, .... > > There is also weaker noise beside this, so columns > > 23, 25, 47, 49, 71, 73 etc. are affected. So altogether > > 1/8 of the image is ruined. The noise is incoherent, but > > not exactly random: it is predominantly low frequency > > down the column. > > So the approach tried by a colleague was to transform > > each column to frequency domain and kill the low frequency > > components (on the noisy columns only). Then interpolate > > these from the adjacent columns with a prediction error filter. > > However, this did not work as well as he expected. > > Why do you first filter the column if you are going to replace them > via interpolation? I'm probably misunderstanding you. > > Anycase, if you view this row-wise, interpolation via prediction > filters might work, but you need a non-linear approach to "train" the > prediction filter. You have to assume the missing pixels unknown. > > > Are there algorithms which can attenuate regularly spaced > > but incoherent noise? > > There is another simple approach [1] to reconstruct the periodically > missing columns that works under mild bandwidth constraints. Contact > me if you cannot access [1]. > > Regards, > Andor > > [1] A. Bariska, "Recovering Periodically-Spaced Missing Samples," > IEEE Signal Process. Mag., DSP Tips and Tricks column, vol. 24, Nov. 2007.By the way, Matlab code that implements this algorithm is available from http://apollo.ee.columbia.edu/spm/?i=external/tipsandtricks Regards, Andor
Anonymous wrote:> We have images with regularly spaced noise. > Specifically it occurs every 24 columns of the image, > e.g. columns 24, 48, 72, 96, .... > There is also weaker noise beside this, so columns > 23, 25, 47, 49, 71, 73 etc. are affected. So altogether > 1/8 of the image is ruined. The noise is incoherent, but > not exactly random: it is predominantly low frequency > down the column. > So the approach tried by a colleague was to transform > each column to frequency domain and kill the low frequency > components (on the noisy columns only). Then interpolate > these from the adjacent columns with a prediction error filter. > However, this did not work as well as he expected. > Are there algorithms which can attenuate regularly spaced > but incoherent noise? >Consider a median filter that only replaces pixels in the noisy region. Stripping the low frequency content with a high-pass, then replacing it with the low frequency content from adjacent columns may work -- but I'm not sure how different what I'm suggesting is from what your colleague was trying. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" gives you just what it says. See details at http://www.wescottdesign.com/actfes/actfes.html
On Apr 8, 12:00 am, Andor <andor.bari...@gmail.com> wrote:> Anonymous wrote: > > We have images with regularly spaced noise. > > Specifically it occurs every 24 columns of the image, > > e.g. columns 24, 48, 72, 96, .... > > There is also weaker noise beside this, so columns > > 23, 25, 47, 49, 71, 73 etc. are affected. So altogether > > 1/8 of the image is ruined. The noise is incoherent, but > > not exactly random: it is predominantly low frequency > > down the column. > > So the approach tried by a colleague was to transform > > each column to frequency domain and kill the low frequency > > components (on the noisy columns only). Then interpolate > > these from the adjacent columns with a prediction error filter. > > However, this did not work as well as he expected. > > Why do you first filter the column if you are going to replace them > via interpolation? I'm probably misunderstanding you.If the damaged columns include signal plus noise, then strictly replacing them via interpolation throws away all of any signal information in those columns which might be separable from the noise.
On 8 Apr., 21:39, "Ron N." <rhnlo...@yahoo.com> wrote:> On Apr 8, 12:00 am, Andor <andor.bari...@gmail.com> wrote: > > > > > > > Anonymous wrote: > > > We have images with regularly spaced noise. > > > Specifically it occurs every 24 columns of the image, > > > e.g. columns 24, 48, 72, 96, .... > > > There is also weaker noise beside this, so columns > > > 23, 25, 47, 49, 71, 73 etc. are affected. So altogether > > > 1/8 of the image is ruined. The noise is incoherent, but > > > not exactly random: it is predominantly low frequency > > > down the column. > > > So the approach tried by a colleague was to transform > > > each column to frequency domain and kill the low frequency > > > components (on the noisy columns only). Then interpolate > > > these from the adjacent columns with a prediction error filter. > > > However, this did not work as well as he expected. > > > Why do you first filter the column if you are going to replace them > > via interpolation? I'm probably misunderstanding you. > > If the damaged columns include signal plus noise, then > strictly replacing them via interpolation throws away > all of any signal information in those columns which > might be separable from the noise.Agreed. However, completely replacing the missing sample is simple and works (under the bandwidth constraints). Finding some kind of scheme to seperate the usable from the noise might be quite difficult. I suggest using redundancy if it is available.
Reply by ●April 9, 20082008-04-09
On Apr 8, 4:28�pm, Andor <andor.bari...@gmail.com> wrote:> On 8 Apr., 21:39, "Ron N." <rhnlo...@yahoo.com> wrote: > > > > > > > On Apr 8, 12:00 am, Andor <andor.bari...@gmail.com> wrote: > > > > Anonymous wrote: > > > > We have images with regularly spaced noise. > > > > Specifically it occurs every 24 columns of the image, > > > > e.g. columns 24, 48, 72, 96, .... > > > > There is also weaker noise beside this, so columns > > > > 23, 25, 47, 49, 71, 73 etc. are affected. So altogether > > > > 1/8 of the image is ruined. The noise is incoherent, but > > > > not exactly random: it is predominantly low frequency > > > > down the column. > > > > So the approach tried by a colleague was to transform > > > > each column to frequency domain and kill the low frequency > > > > components (on the noisy columns only). Then interpolate > > > > these from the adjacent columns with a prediction error filter. > > > > However, this did not work as well as he expected. > > > > Why do you first filter the column if you are going to replace them > > > via interpolation? I'm probably misunderstanding you. > > > If the damaged columns include signal plus noise, then > > strictly replacing them via interpolation throws away > > all of any signal information in those columns which > > might be separable from the noise. > > Agreed. However, completely replacing the missing sample is simple and > works (under the bandwidth constraints). Finding some kind of scheme > to seperate the usable from the noise might be quite difficult. I > suggest using redundancy if it is available.- Hide quoted text - > > - Show quoted text ------------------------------------------------------------------ Andor: I thought this was impressive: http://math.berkeley.edu/~sethian/2006/Applications/ImageProcessing/noiseremoval.html It uses level sets to do noise reduction. It's 2D noise, not periodic, single column noise like you have but maybe it might be useful (adaptable to your situation) in keeping the signal and reducing the noise, unlike interpolation which the others pointed out will throw out your signal. Regards, ImageAnalyst
