"Jerry Avins" <jya@ieee.org> wrote in message news:eb2dnQ1z1ZGRiJvVnZ2dnUVZ_gudnZ2d@rcn.net...> bulegoge@columbus.rr.com wrote: > > > It's not an explanation of details that's needed, but an understanding of > the fundamentals. I'll try to help. > > A decibel is a ratio of powers. It is a tenth of a bel; one bel represents > a power ratio of ten, the familiar "order of magnitude". > > Ten decibels also represents a power ratio 10, so 20 dB is a ratio of 100, > and so on. A table of logs will show that a ratio of 4 is about 6 dB. The > formula is dB = 10*log10(power ratio). > > In linear systems, power at any given node is proportional to the square > of voltage, so (power ratio) = (voltage ratio)^2. Observe that if > 10*log10(power ratio) = 10*log10((voltage ratio)^2), then it also equals > 20*log10(voltage ratio). > > The various subscripted dB types are named for different references. A > power of 1 milliwatt = 0 dBm. On a 600-ohm line, that represents a voltage > of .7746; sqrt(.6). .7746 volts on any impedance = 0 dBu. Note that when > computing dB from voltage, the multiplier is 20. 0 dBm = 0 dBu in a > 600-ohm circuit. > > I'd be happy to try to clarify any of that if is wasn't as helpful as I > would have liked. >Jerry, Thanks for the thoughtful inputs. Brent
DFT spectrum and coefficient insight
Started by ●April 13, 2008
Reply by ●April 16, 20082008-04-16
