Hi, I am doing the synchronization for ISDB-T at the moment. For pure coherent modulation, it is easy to use the embedded SP for fine timing synchronization since we may use them to estimate the time domain CIR. However, if differential modulation is adopted, there will not be available SP in the frequency domain, in this case, how fine timing sychronization is done? Many thanks eeed
ISDB-T synchronization
Started by ●April 16, 2008
