Hi, I am working with Blackfin processor BF534......... I am configuring three timers in the PWM_OUT mode.... I am mapping three timers to three separte interrupt Service routines as shown below.............I have intialized all the Timers in PWM_OUT, PULSE_HI=0, IRQ_ENA=PERIOD_CNT=1......... void Init_Interrupts() { // assign core IDs to interrupts *pSIC_IAR0 = 0xffffffff; *pSIC_IAR1 = 0xffffffff; *pSIC_IAR2 = 0xf4ffffff; /////Timer3 ISR-->IVG11 *pSIC_IAR3 = 0xfffff5f6; /////Timer7 ISR-->IVG12////Timer5 ISR-->IVG13// // assign ISRs to interrupt vectors register_handler(ik_ivg11, Timer3_ISR); // Timer3 ISR -> IVG 11 register_handler(ik_ivg12, Timer7_ISR); // Timer7 ISR -> IVG 12 register_handler(ik_ivg13, Timer5_ISR); // Timer5 ISR -> IVG 13 // enable Timer0 interrupt *pSIC_IMASK |= IRQ_TIMER3|IRQ_TIMER5|IRQ_TIMER7; ssync(); } I have written Individual ISR's for all the three timers as given below...... EX_INTERRUPT_HANDLER(Timer3_ISR) { *pTIMER_DISABLE =0x0008; ssync(); // confirm interrupt handling/// *pTIMER_STATUS |= 0x00000008;//------------------------->>(1) ssync(); } EX_INTERRUPT_HANDLER(Timer7_ISR) { *pTIMER_DISABLE =TIMDIS7; ssync(); // confirm interrupt handling/// *pTIMER_STATUS |= 0x00080000;------------------------->>(2) ssync(); } EX_INTERRUPT_HANDLER(Timer5_ISR) { *pTIMER_DISABLE =TIMDIS5; ssync(); // confirm interrupt handling/// *pTIMER_STATUS |= 0x00020000;------------------------->>(3) ssync(); } My problem is based on the equations 1, 2 and 3........After the timer counter reaches the value of the timer period register, it jumps to the ISR........In the ISR, I am clearing the TIMILx bit of the particular timers by writing (WIC) to TIMER_STATUS registers.....But the interrupt bit is cleared (Particular TIMILx bit becomes zero on writing 1 to that bit(wruite 1 to clear)) only in Equation (1)....but not in equation (2) and (3).......Can you suggest the remedy for my problem....... Regards, Nithin K S PS: Can I use the three different ISR's for three timers....?or should i map the three timers into same ISR......
On Blackfin Timer
Started by ●April 17, 2008
