Ben Bradley wrote: (someone wrote)>>> This doesn't sound right. If you want the best quality possible in >>>the final 16-bit signal, look into dithering and noise-shaping rather >>>than doing rounding, and it's best to do all your processing in >>>floating point (that way you can change the level to any arbitrary >>>value, rather than only in the 3dB steps that bit shifting gives). >>> OTOH, the difference can be subtle, and many people can't tell even >>>under the best listening conditions.It isn't hard to do other step sized, but I didn't so far. Just multiply by some number before shifting. Even a 32 bit int should be enough, but definitely 64 bits.>>I thought about it, but so far I haven't tried. By finding the >>peak and appropriate shifting, the quietest parts aren't so far down.>>It is a recording with a live audience, and the background isn't all >>that quiet, anyway. It would be nice, though. Do others do it?> Yes, I'm pretty sure most all audio editing software (everything > from Audacity to Pro Tools) have been doing it as I described for many > years now.This was pretty simple and free. This is personal, and the budget is low.> It might be easier to write some script file for an audio editing > program to do what you want. I don't know what programs have what > features nowadays, but the old Cool Edit 2000 has/had scripting so you > could do several automated things with audio files.If I want to add dither can I use an array of some reasonable length as a periodic data stream? Generating enough random numbers for a whole CD might take a while. -- glen
audio sampling rate question
Started by ●April 27, 2008
Reply by ●May 18, 20082008-05-18
Reply by ●May 19, 20082008-05-19
On Sat, 17 May 2008 22:39:00 -0800, glen herrmannsfeldt <gah@ugcs.caltech.edu> wrote:>Ben Bradley wrote: >(someone wrote)...>>>It is a recording with a live audience, and the background isn't all >>>that quiet, anyway. It would be nice, though. Do others do it? > >> Yes, I'm pretty sure most all audio editing software (everything >> from Audacity to Pro Tools) have been doing it as I described for many >> years now. > >This was pretty simple and free. This is personal, and the >budget is low.Audacity is free, you might want to play around with it: http://audacity.sourceforge.net/> >> It might be easier to write some script file for an audio editing >> program to do what you want. I don't know what programs have what >> features nowadays, but the old Cool Edit 2000 has/had scripting so you >> could do several automated things with audio files. > >If I want to add dither can I use an array of some reasonable >length as a periodic data stream?since it's likely "below the threshold of hearing", a second's worth of random numbers (44,000) ought to do (if it's loud enough to hear, the ear will be able to hear the repeated nature of the noise), but a simple what's-it-called, 'congruence' random number generator can generate adequate numbers with minimal code execution per sample. If you filter the noise for noise-shaping, the filter code will take more CPU cycles.>Generating enough random >numbers for a whole CD might take a while. > >-- glen
