glen herrmannsfeldt wrote:> ... Now, is infinity prime or composite?:-) ! Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Calculate MACs in MATLAB
Started by ●April 29, 2008
Reply by ●May 6, 20082008-05-06
>An interesting statement. O() notation gives the order as >N goes to infinity, and it may or may not be of any use >for small N. Now, is infinity prime or composite?I was reading this thinking "yeah, it's probably not very good for small N" then I got to the last bit and had to laugh. :) Mark
On May 6, 3:12 am, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote:> > Cooley-Tukey. It is O(N log N) for all N. > > An interesting statement. O() notation gives the order as > N goes to infinity, and it may or may not be of any use > for small N. Now, is infinity prime or composite?If you look at the definition of asymptotic (O) notation, you'll see that there's no need to say whether "infinity" is prime or composite. In practice, the O(N log N) prime-size algorithms already have clear advantage for N > 100. In principle, you usually have enough freedom to choose your transform to be a composite size, but many people apparently find it useful to not have to worry about resizing their data, without being afraid that if they are unlucky the FFT will be thousands of times slower (as opposed to just a factor of 10). Steven
On May 5, 12:02 pm, "markt" <tak...@pericle.com> wrote:> Yeah, as you note, even "optimal" in terms of the least amount of FLOPS is > not necessarily "optimal" in terms of speed.And even optimality in terms of flop counts is not proven; no one knows tight lower bounds. There isn't even any proof that you can't do better than O(N log N) for an FFT (although no counterexamples are known).> without reference to some criteria. Set your minimum FLOP count algorithm > up in such a way that your next instruction is always waiting for > completion of the current instruction (a pipeline stall) and you'll find it > may not work very well compared to another algorithm with more required > FLOPS, but a better overall flow.Yes, especially for large N I'm not aware of any implementation of the minimal-known-flop FFT algorithm(s) that is competitive in practice with highly optimized implementations. You just have too many other things to worry about that are more important than arithmetic these days. On the other hand, to be fair, I doubt that the highly optimized implementations sacrifice more than 10-15% in the flop count compared to the lowest known flop counts. On the other hand, for small hardcoded transforms of sizes < 100 or so, we have usually found that we do best with the algorithms that come close to the minimum known flop counts. (This relies on the ability to find a good schedule for the code, of course, but we have a generic algorithm for this that seems to work well.) (Sometimes people talk about a "crossover point" at which the O(N log N) algorithms beat the naive O(N^2) algorithm, but in my experience this is mostly about overheads of implementations. For small N you really want to hard-code everything to avoid the overhead, and in that case, we've usually found that a hard-coded O(N log N) algorithm wins over the O(N^2) algorithm for all composite N starting with N=4.) Steven
"glen herrmannsfeldt" <gah@ugcs.caltech.edu> wrote in message news:8JCdncXYrN0Anr3VnZ2dnUVZ_oimnZ2d@comcast.com...> Steven G. Johnson wrote: > (snip) > >> Short answer: FFTW uses the prime-factor algorithm for small sizes (<= >> 16) within its codelets at the leaves of its recursion. Larger >> composite sizes are broken down into smaller sizes using mixed-radix >> Cooley-Tukey. It is O(N log N) for all N. > > An interesting statement. O() notation gives the order as > N goes to infinity, and it may or may not be of any use > for small N. Now, is infinity prime or composite?Yes.> > -- glen >
Reply by ●May 7, 20082008-05-07
glen herrmannsfeldt wrote:> Steven G. Johnson wrote: > (snip) > >> Short answer: FFTW uses the prime-factor algorithm for small sizes (<= >> 16) within its codelets at the leaves of its recursion. Larger >> composite sizes are broken down into smaller sizes using mixed-radix >> Cooley-Tukey. It is O(N log N) for all N. > > An interesting statement. O() notation gives the order as > N goes to infinity, and it may or may not be of any use > for small N. Now, is infinity prime or composite?Composite, of course. Primes get scarcer as numbers increase. By the time infinity is reached, they are vanishingly scarce. Aint logic wunnerful? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
>If you look at the definition of asymptotic (O) notation, you'll see >that there's no need to say whether "infinity" is prime or composite.I think he was intentionally being funny. ;)>In practice, the O(N log N) prime-size algorithms already have clear >advantage for N > 100. In principle, you usually have enough freedom >to choose your transform to be a composite size, but many people >apparently find it useful to not have to worry about resizing their >data, without being afraid that if they are unlucky the FFT will be >thousands of times slower (as opposed to just a factor of 10).I played around with FFTW quite a bit a few years ago (you and I traded emails about my efforts, and my company actually bought a license at the time) and I can say that this is at the very least, empirically true.>And even optimality in terms of flop counts is not proven; no one >knows tight lower bounds. There isn't even any proof that you can't >do better than O(N log N) for an FFT (although no counterexamples are >known).Though I suppose the fact that O(N log N) is called an estimation implies this statement, I did not know this explicitly. Particularly the second statement. Learn something new every day. Do you suppose it is an unprovable problem?>Yes, especially for large N I'm not aware of any implementation of the >minimal-known-flop FFT algorithm(s) that is competitive in practice >with highly optimized implementations. You just have too many other >things to worry about that are more important than arithmetic these >days. On the other hand, to be fair, I doubt that the highly >optimized implementations sacrifice more than 10-15% in the flop count >compared to the lowest known flop counts.Too bad. It's not difficult for other math functions, such as a complex multiply or magnitude function (which is what FFTW's SIMD code does), which are then ordered in memory for fast access and a consistently full pipeline. Once you have to stride or do a corner turn, the effort just ain't worth it, not for the 10% at least. Mark
Reply by ●May 9, 20082008-05-09
On May 7, 12:05 pm, "markt" <tak...@pericle.com> wrote:> >And even optimality in terms of flop counts is not proven; no one > >knows tight lower bounds. There isn't even any proof that you can't > >do better than O(N log N) for an FFT (although no counterexamples are > >known). > > Though I suppose the fact that O(N log N) is called an estimation implies > this statement, I did not know this explicitly. Particularly the second > statement. Learn something new every day. Do you suppose it is an > unprovable problem?I wouldn't say that the O(N log N) asymptotic analysis implies this statement. Having an estimate or an asymptotic bound doesn't mean that you don't know more precise things as well. Exact arithmetic counts are certainly known for the existing algorithms; it's just not known whether better counts are possible. I don't see any reason to assume it's an unprovable axiom-of-choice type of thing, although the proof seems to be fairly difficult and has resisted repeated attempts so far. There are already proofs that Omega(N log N) operations are required under certain restrictions on the type of algorithms [e.g. there is a nice proof by Morgenstern in 1978 that Omega(N log N) additions are required if you restrict yourself to algorithms with bounded multiplicative constants ... unfortunately, there are many interesting algorithms that do not have the property of bounded constants, including the ones with the currently lowest known flop counts (see fftw.org/newsplit.pdf)]. Steven
On May 9, 12:23 am, "Steven G. Johnson" <stev...@alum.mit.edu> wrote:> the type of algorithms [e.g. there is a nice proof by Morgenstern in > 1978 that Omega(N log N) additions are required if you restrictSorry, that's 1973: http://portal.acm.org/citation.cfm?id=321761&dl=GUIDE&coll=GUIDE&CFID=27101559&CFTOKEN=22812989
>I don't see any reason to assume it's an unprovable axiom-of-choice >type of thing, although the proof seems to be fairly difficult and has >resisted repeated attempts so far. There are already proofs that >Omega(N log N) operations are required under certain restrictions on >the type of algorithms [e.g. there is a nice proof by Morgenstern in >1978 that Omega(N log N) additions are required if you restrict >yourself to algorithms with bounded multiplicative constants ... >unfortunately, there are many interesting algorithms that do not have >the property of bounded constants, including the ones with the >currently lowest known flop counts (see fftw.org/newsplit.pdf)].Interesting. I wasn't particularly thinking it was unprovable, just curious whether or not it can be proven unprovable. Rumor has it my advanced calculus professor (oh so long ago) ended up with a known unprovable problem for his dissertation (though he did not know this at the time), which always makes me think about these things. He was, btw, a bit odd, and the rumor claimed it was a result of his dissertation stress. Mark
