Piergiorgio Sartor wrote:> Steven Sullivan wrote: > >> *Maybe* your friend was imagining things. > > Exactly! > I was close to say that *maybe* the Earth is flat. > > With this kind of reasoning, everything is possible. > > I tell you another story. > > Once I met another guy, responsible of the quality > in one audio CD factory. > He told me that, looking for quality, they asked > also audiophiles about what they think. > It turned out that some people buy 2~3 copies of the > same audio CD, they "test" it at home, and then keep > the one that "sounds better".This notion might be a hangover from a genuine issue in the early days of CDs. They used to struggle to make them, and many had pin prick holes through the metalisation. You could hold them up to the light, and easily see those holes. Wrapped in plastic in the shop you couldn't see these flaws. I knew an early adopter who would go through several copies until he found one that looked and played flawlessly.> So, he was asking what could it be, are there any > difference between CDs of different batches, maybe. > They told him something about jitter, it seems > different CDs can have different jitter. > > He, then, took some high end CD player and measured > all he could measure, including jitter, of different > copies of the same CD(s). > > He could not find anything strange, the high end CD > player has FIFOs, which keep the jitter constant and > minimum (low end is different story, but audiophiles > use high end).They all have FIFOs. The data isn't played directly from the disk. It is played from the ECC decode buffer. It is clocked from there to the DAC by a stable clock. It would take a pretty broken design to have so much phase noise in that clock that it produced significant jitter.> In the end he could not figure it out what was the > reason why different copies of the same CD should > sound differently. > > Next reply I'll tell you another of this stories.Regards, Steve
What's the use of a 192 kHz sample rate?
Started by ●May 3, 2008
Reply by ●May 8, 20082008-05-08
Steve Underwood wrote:> Piergiorgio Sartor wrote: >> Steven Sullivan wrote: >> >>> *Maybe* your friend was imagining things. >> >> Exactly! >> I was close to say that *maybe* the Earth is flat. >> >> With this kind of reasoning, everything is possible. >> >> I tell you another story. >> >> Once I met another guy, responsible of the quality >> in one audio CD factory. >> He told me that, looking for quality, they asked >> also audiophiles about what they think. >> It turned out that some people buy 2~3 copies of the >> same audio CD, they "test" it at home, and then keep >> the one that "sounds better". > > This notion might be a hangover from a genuine issue in the early days > of CDs. They used to struggle to make them, and many had pin prick > holes through the metalisation.Either that or they are just anally-retentive, with powerful imaginations. geoff
Reply by ●May 9, 20082008-05-09
In rec.audio.tech Jerry Avins <jya@ieee.org> wrote:> Steven Sullivan wrote: > > In rec.audio.tech Jerry Avins <jya@ieee.org> wrote:> ...> >> According to my audiologist, "bone > >> conduction" is an alternate pathway to the auditory nerve. > > > > one that bypasses the hair cells?> No.Ok, then I *should* call it 'hearing'. Now, would it have any relevance to sound that isn't delivered directly at the body surface? -- -S maybe they wanna rock. maybe they need to rock. Maybe it's for the money? But That's none of our business..our business as fans is to rock with them.
