Silly Question about "movement"
Started by porterboy April 16, 2004
porterboy wrote:
> OK, I know this is a silly question, and not even much related to > DSP...
> They say you shouldnt leave A VHS cassette on pause for a long time, > because it damages the read-head. Similarly, you should use a moving > screen saver on a monitor, because a static image can impair the > screen...
It is mostly wear on that spot on the tape. If you have an expensive prerecorded tape, and pause too long on it, it can wear out that spot. I have noticed on rented tapes, at spots where people might pause to look at more carefully, weak signal due to worn tape.
> On this note I have two questions... > 1. Is it bad for a DVD player to be left on pause for a long time
> 2. If you are using a debugging tool on a computer program, is it bad > for the computer if you wander off mid-debug and leave the programme > hanging mid run for a long time.
Well, that is what screen savers are for. Hours should be fine, it is days, weeks, and months that cause the problem. -- glen
On 16 Apr 2004 23:52:31 -0700, stephan.bernsee@web.de (Stephan M.
Bernsee) wrote:
>You can say that again, Rick! I too learned to appreciate the advice >given here over the past years... (you may remember me as Stephan >Sprenger)... ;-) > >Cheers, >Stephan
Ah Ha!!! Hello Stephan. I'm glad you are back on comp.dsp! So it's Stephan Bernsee now, huh? I hope that means your were adopted by a rich older woman and are now living in her castle (schloss) and driving a new Mercedes Benz.!!! Best Regrads, [-Rick-] .
Hey Rick,
I'm afraid we neither have a Schloss nor a Mercedes yet (in fact, our
old Toyota is celebrating its 20th birthday this year), but we're
working on it! :-)
But at least, unlike me, she has what some would call a "normal"
daytime job. You know, one of these you can explain to people without
the help of a blackboard or headphones and where you don't sleep in
the lab face down on a computer keyboard...
Cheers,
Stephan
> Rick wrote: > > Ah Ha!!! > > Hello Stephan. I'm glad you are back on > comp.dsp! > > So it's Stephan Bernsee now, huh? > > I hope that means your were adopted by > a rich older woman and are now living in > her castle (schloss) and driving > a new Mercedes Benz.!!! > > Best Regrads, > [-Rick-] > .
