On Tue, 6 May 2008 15:04:25 -0700 (PDT), DigitalSignal <digitalsignal999@yahoo.com> wrote:>Congratulations Rick! > >James >www.go-ci.comHi, Thanks James. [-Rick-]
Rick Lyons gets two attaboys
Started by ●May 5, 2008
Reply by ●May 7, 20082008-05-07
DigitalSignal wrote:> Where can I buy this book TODAY? > > James > www.go-ci.comYou can order today at http://tinyurl.com/59qaux or http://tinyurl.com/6fbaeo B&N may have it on the shelf. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●May 11, 20082008-05-11
On Wed, 7 May 2008 16:22:54 -0700 (PDT), DigitalSignal <digitalsignal999@yahoo.com> wrote:>Where can I buy this book TODAY? > >James >www.go-ci.comHi, Check out: http://www.amazon.com/Streamlining-Digital-Signal-Processing-Guidebook/dp/0470131578/ref=sr_1_1?ie=UTF8&s=books&qid=1210558628&sr=8-1 Regards, [-Rick-]
Reply by ●May 12, 20082008-05-12
On Sun, 11 May 2008 20:58:12 -0700 (PDT), DigitalSignal <digitalsignal999@yahoo.com> wrote:>Yes. I did order it from Amazon. I am really looking forward to seeing >it. > >JamesHi James, Great. Here's the errata, as best as I know it: [-Rick-] ---------------------------------------------- Page 6: In the first sentence of the last paragraph, the text: "It's interesting to notice that Hs(z) has the same half-power frequency (-6dB point) as H(z)." the phrase "half-power" should be changed to "half-amplitude". Error found by Markus Nentwig on 11/8/07. --------------------------------------------- Page 77: In Figure 8-5, the label: "M = 7" should have the "M" changed to "L" making that label: "L = 7" Error found by Editor Lyons on 3/6/08. --------------------------------------------- Page 190: In the next to the last line, the text: "... interval [0,1]." should be changed to: "... interval [-1,1]." Error found by Editor Lyons on 2/10/08. --------------------------------------------- Page 271: In the second and third lines below Eq. (24-17), the text: "... FIR filter's (24-13) through (24-16) coefficients ..." should be changed to: "... FIR filter's (24-14) through (24-17) coefficients ..." Error found by Editor Lyons on 2/8/08. ---------------------------------------------
