Hi, I have to design a 6th order IIR BPF that will allow a multirate filter structure with D==3.How do i start?Is there a matlab function that does this,I mean also incorporates the multirate structure with design of an IIR BPF like butter().I wil greatly appreciate any guidance on this.
design of iir bpf
Started by ●May 8, 2008
Reply by ●May 8, 20082008-05-08
>Hi, >I have to design a 6th order IIR BPF that will allow a multirate filter >structure with D==3.How do i start?Is there a matlab function that does >this,I mean also incorporates the multirate structure with design of anIIR>BPF like butter().I wil greatly appreciate any guidance on this.no matlab function does this. i think u will have to do it as a 2 step process. so use butter, cheby1 or cheby2 functions and the ouptut of the filter can be decimated by 3. in case if u need more help contact me at bharat at arithos dot com rgds bharat pathak Arithos Designs www.Arithos.com DSP Design Consultancy and Training Company.
munib wrote:> Hi, > I have to design a 6th order IIR BPF that will allow a multirate filter > structure with D==3.How do i start?Is there a matlab function that does > this,I mean also incorporates the multirate structure with design of an IIR > BPF like butter().I wil greatly appreciate any guidance on this. > >"I tried to use Matlab's domyworkforme function, and it isn't in my edition -- what toolbox do I need to get?" The best guidance that I can give you is this: Owning a hammer and saw doesn't make you a carpenter. Owning a lathe and mill doesn't make you a machinist. Owning Matlab doesn't make you a DSP expert. Design the IIR filter separately. I strongly suggest that if you don't know how to do it by hand, you learn, and do it you do it by hand a few times before you start using Matlab. Cascading an IIR filter with a decimate-by-three stage should be child's play, and isn't something I'd expect any Matlab function to do (until they come out with the domyworkforme function, in which case we'll all be replaced by computers). -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" gives you just what it says. See details at http://www.wescottdesign.com/actfes/actfes.html
Reply by ●May 12, 20082008-05-12
On Thu, 08 May 2008 05:09:47 -0500, "munib" <muneeb30772@hotmail.com> wrote:>Hi, >I have to design a 6th order IIR BPF that will allow a multirate filter >structure with D==3.How do i start?Is there a matlab function that does >this,I mean also incorporates the multirate structure with design of an IIR >BPF like butter().I wil greatly appreciate any guidance on this.Hi, I wonder how anyone can ask you to design an IIR filter using MATLAB when it appears that you're unfamiliar with MATLAB. In any case start reading the "Signal Processing Toolbox" manual, that you can find on the Internet. (It's a 780-page PDF file.) Concentrate on the first half of Chapter 2. Once you've computed your IIR filter output samples (variable "Sig"), you can decimate sequence Sig using: DecFactor = 3; SigDec = Sig(1:DecFactor:length(Sig)); Good Luck, [-Rick-]
