Hello, Maybe everybody knows the idea that an infinite number of monkeys with typewriters would type the complete works of shakespeare. In reality there is little chance for that to happen: http://www.guardian.co.uk/uk/2003/may/09/science.arts Anyway.. If one replaces the monkeys with a random process how would that relate to the property of "stationarity" of the process if a continous part of the output would be pcm samples that resemble Orson Well's voice reading the complete works of Shakespear. The output wouldn't look stationary at all, but there still should be a possibility (with extremely small probability) that this happens within a stationary random process, or am I wrong with this? gr. Bjoern
monkeys with typewriters and stationarity
Started by ●May 16, 2008
Reply by ●May 16, 20082008-05-16
On May 16, 7:30�pm, "banton" <bant...@web.de> wrote:> Hello, > > Maybe everybody knows the idea that > an infinite number of monkeys with typewriters would > type the complete works of shakespeare. > > In reality there is little chance for that to happen:http://www.guardian.co.uk/uk/2003/may/09/science.arts > > Anyway.. >I always preferred the idea that creating a library containing every book with every possible combination of words would (it would also contain a book describing the cure for cancer, your life story, correct theory of the universe etc)
Reply by ●May 17, 20082008-05-17
On May 17, 7:30 am, "banton" <bant...@web.de> wrote:> Hello, > > Maybe everybody knows the idea that > an infinite number of monkeys with typewriters would > type the complete works of shakespeare. > > In reality there is little chance for that to happen:http://www.guardian.co.uk/uk/2003/may/09/science.arts > > Anyway.. > > If one replaces the monkeys with a random process > how would that relate to the property of "stationarity" of > the process if a continous part of the output would > be pcm samples that resemble Orson Well's voice reading the > complete works of Shakespear. > > The output wouldn't look stationary at all, but there still > should be a possibility (with extremely small probability) > that this happens within a stationary random process, or > am I wrong with this? > > gr. > BjoernThis principle is infact used in CELP based speech coders.
banton wrote:> The output wouldn't look stationary at all, but there still > should be a possibility (with extremely small probability) > that this happens within a stationary random process, or > am I wrong with this?I'm not sure I got your question, but if I give you two (finite) sequences generated by a random process, can you tell me which one is stationary and which one is not? Actually, can you tell me which one is random and which one is not random? I think if a random process generate something that does not "look" random, someone might argue is not random. Anyhow, as wrote at the beginning, maybe I did not get the question right. bye, -- piergiorgio
>banton wrote: > >> The output wouldn't look stationary at all, but there still >> should be a possibility (with extremely small probability) >> that this happens within a stationary random process, or >> am I wrong with this? > >I'm not sure I got your question, but if I give you >two (finite) sequences generated by a random process, >can you tell me which one is stationary and which one >is not? > >Actually, can you tell me which one is random and which >one is not random? >For a stationary process the autocorrelation should not change, if evaluated at different times. But as I see it, it always would if the process is random. Just if you average over time it would be the same. So there must be some idea of time-scale in connection with stationarity. Or similary. White noise should have an FFT of 1. Now if you evaluate an DFT over a finite time interval, the SFT itself would not look contant at all, but if you average enough DFT results it would be constant. So I wonder if there is any idea (or measure) that deals with the time-scale in connection to this?
"banton" <bantone@web.de> wrote in message news:xp-dnSmAoNit3rPVnZ2dnUVZ_obinZ2d@giganews.com...> > Hello, > > Maybe everybody knows the idea that > an infinite number of monkeys with typewriters would > type the complete works of shakespeare. > > In reality there is little chance for that to happen: > http://www.guardian.co.uk/uk/2003/may/09/science.arts >After a billion years someone will plot a graph and call it 'The Great Guassian Monkey Curve,' then go home for tea. : ) VC
"banton" <bantone@web.de> writes:> [...] > The output wouldn't look stationary at all,This is where your presumption is revealed. Random processes and the stationary property utilize ensemble averages - you're referring to a specific realization. The statistics of the two are not at all necessarily equivalent unless the process is ergodic. -- % Randy Yates % "The dreamer, the unwoken fool - %% Fuquay-Varina, NC % in dreams, no pain will kiss the brow..." %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Eldorado Overture', *Eldorado*, ELO http://www.digitalsignallabs.com
Reply by ●May 19, 20082008-05-19
"Randy Yates" <yates@ieee.org> wrote in message news:m3abioju6i.fsf@ieee.org...> "banton" <bantone@web.de> writes: >> [...] >> The output wouldn't look stationary at all, >Well, if the monkeys were using old-fashioned typewriters instead of modern keyboards and computers, their output could be categorized as (used) stationery, no?
Reply by ●May 20, 20082008-05-20
Hi Bjoern, This is a difference between probability and statistics. For instance, the probability of a flipped coin being "heads" is exactly 50%. However, if you flip the coin 100 times, it is certainly possible that it might be heads all 100 times. Thst is, the statistics of the actual outcome is one thing, and the probability of the underlying process is another. The statement that a process is "stationary" refers to probability. The actual outcomes (statistics) will contain a random component. Regards, Steve
Reply by ●May 24, 20082008-05-24
banton wrote:> For a stationary process the autocorrelation should not change, > if evaluated at different times.From -inf to +inf, difficult to compute...> White noise should have an FFT of 1.Maybe I did not get it correctly, but the FFT of white noise is still white noise... The FFT of the auto-correlation is constant one, since the auto-correlation is a "pulse", by _definition_.> So I wonder if there is any idea (or measure) that > deals with the time-scale in connection to this?Usually not, if I get your problem right. I mean, how can be decided if a sequence is random? bye, -- piergiorgio
