Hi, I have written already about this problem. But here I am trying to give more details as to what problems I am encountering. I have a custom board with BF534 processor. I am using VDSP++5.0 update2 software with 90 day test drive license. We are getting a few errors when we are trying to connect our target board. I have given the list of errors which I am encountering. I have also given the error(Error 3) that I am getting when I run ICE test in continuous scan mode. We are using the following devices in our board. Flash memory: S29AL0XXD SDRAM: MT48LCXXM16A2 ALso we are using the flash driver shipped with VDSP++5.0 Our board conforms to the EE-68 note mentioned in ADI site. Does anyone know how to get around the problem? PS: We had programmed the board the once already. When we tried to erase the previous program on the flash and re program it with a new one we are having this problem. Thank you in advance, Regards, Nithin Error1: VisualDSP VisualDSP has detected 0 device(s) in the JTAG Chain yet there are 1 device(s) listed in this platform Please verify that all settings are correct in the ICE configuration utility Error2: The target has requested to disconnect from the IDDE Reason: GetMem failed Do you want to disconnect? YES NO Error3: Incorrect byte found at position 5686 of test dat. Data found:0x52, expected :0x53
ADZS-USB-ICE problem
Started by ●May 21, 2008
