Hi, I have some problems regarding IFFT used in Matlab. I have a frequency range from 2M to 4M Hz where I have obtained the datas into 1601 data points. Currently, I am trying to get the real values of time domain. Currently, I have IFFT the data obtained (1601 points) and plotted out the time domain waveform. Currently, I am having problem in determine the real time axis of waveform for 1600 points. I wonder example like whta is the real N=800 point in time domain after IFFT?
real values of time domain after IFFT
Started by ●May 21, 2008
Reply by ●May 21, 20082008-05-21
Sorry, but I think your English is not good enough to explain your problem. If we don't understand the question, we can't give you an answer. You might try having someone help you write the question. Also, here's some reading material on the topic that might help. Good luck. Steve http://www.dspguide.com/ch8.htm http://www.dspguide.com/ch12.htm
Reply by ●May 22, 20082008-05-22
>Sorry, but I think your English is not good enough to explain yourproblem.> If we don't understand the question, we can't give you an answer. You >might try having someone help you write the question. Also, here's some >reading material on the topic that might help. Good luck. >Steve > >http://www.dspguide.com/ch8.htm >http://www.dspguide.com/ch12.htm >Hi Steve, I apologise for my earlier post. I believed I have a weak fundamentals of FFT. Actually, I am doing a baseband processing of using two antenna, from a frequency range of 200M Hz to 400 MHz and capturing the complex data (1601 points) from a VNA. Currently, I am trying to use Matlab IFFT to compute the time delay of the system response. I have doubt for my processing technique: 1) I wonder if it is necessary place zero pladding on 0 Hz to 200MHz to capture the accuracy of the time delay? or just use IFFT to plot out the 1601 points of data from 200M to 400MHz? 2) From the IFFT, I have discovered that I have plotted out the x axis in number of points (N). I wonder how can I achieve in ploting in seconds from the earlier example of 200M to 400MHz? Thanks for advice. Rdgs keng
>Actually, I am doing a baseband processing of using two antenna, from a >frequency range of 200M Hz to 400 MHz and capturing the complex data(1601>points) from a VNA. Currently, I am trying to use Matlab IFFT to compute >the time delay of the system response. > >1) I wonder if it is necessary place zero pladding on 0 Hz to 200MHz to >capture the accuracy of the time delay? or just use IFFT to plot out the >1601 points of data from 200M to 400MHz? > >2) From the IFFT, I have discovered that I have plotted out the x axisin>number of points (N). I wonder how can I achieve in ploting in secondsfrom>the earlier example of 200M to 400MHz? >Hi Keng, So, your English is OK! I don't work with Matlab or VNAs, but I'll try to help. As I understand it, the Vector Network Analyzer (VNA) is giving you 1601 points. Further, each point contains the Magnitude and Phase (or real and imaginary parts) of equally spaced frequencies between 200 MHz and 400 MHz. Given this frequency response, you want to calculate the corresponding impluse response by using the IFFT. Here's the cookbook explanation. Set up a complex array of 8,192 entries, running from 0 to 8,191. The values between 0 and 4,096 correspond to the frequencies between DC and 512 Mhz. This places the 1601 values you know at points 1600 to 3200, corresponding to the frequencies of 200Mhz to 400 MHz. The values you don't know (DC-200MHz and 400Mhz-512MHz) may affect your final outcome, but for the first try just set them to zero. The values between 4097 and 8191 need to be a mirror image of the other points. See here: http://www.dspguide.com/ch12/1.htm After taking the IFFT, you will have an impluse response of 8,192 points, with each point representing 1/(2 x 512Mhz) = 0.9765 nsec. This may work as you expect. However, it may also turn into a mess because of the unknown values in the frequency response. Good luck. Steve
