Hi: Is spatial aliasing caused by an insufficient pixel-density? Also, some video websites say that spatial aliasing causes jaggies, other say it causes the Moire effect, still others say it causes pixelation. Who is right? Thanks, Radium
Does an inadequate pixel-density cause spatial aliasing?
Started by ●May 25, 2008
Reply by ●May 25, 20082008-05-25
On May 24, 9:01 pm, "Green Xenon [Radium]" <gluceg...@excite.com> wrote:> Is spatial aliasing caused by an insufficient pixel-density?You seem to be assuming that images have some natural band limit. Although lens aberration and aperture diffraction do limit resolution, the result isn't exactly the same as somehow restricting the photon density to below some frequency in the spatial domain.> Also, some video websites say that spatial aliasing causes jaggies, > other say it causes the Moire effect, still others say it causes > pixelation. Who is right?Yes, they are. The above affects can all be seen as related to one another is certain situations. . IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
Pixellation and jaggies i think are similar. Moire patterns are caused mainly when we do interlaced to progressive conversion. when doing I2P we take help of motion, if pixels are static we do temporal interpolation and if things are moving we do spatial interpolation. Sometimes the motion detection makes errors and in area's there is no motion, declares motion and thus spatial deinterlacing takes place. this is mainly a problem in high freq area's. in spatial domain we try to create info even though it is missing. and hence this creates moire patterns. i have ppt explaining deinterlacing in simple terms, if interested send me mail at bharat at arithos dot com. Regards Bharat Pathak Arithos Designs www.Arithos.com DSP Design Consultancy and Training Company> >Is spatial aliasing caused by an insufficient pixel-density? > >Also, some video websites say that spatial aliasing causes jaggies, >other say it causes the Moire effect, still others say it causes >pixelation. Who is right? > > >Thanks, > >Radium >
Reply by ●May 26, 20082008-05-26
bharat pathak wrote:> Pixellation and jaggies i think are similar. Moire patterns > are caused mainly when we do interlaced to progressive > conversion. when doing I2P we take help of motion, if pixels > are static we do temporal interpolation and if things are > moving we do spatial interpolation. Sometimes the motion detection > makes errors and in area's there is no motion, declares motion > and thus spatial deinterlacing takes place. this is mainly > a problem in high freq area's. in spatial domain we try to > create info even though it is missing. and hence this creates > moire patterns. i have ppt explaining deinterlacing in simple > terms, if interested send me mail at bharat at arithos dot com.Are pixelation/jaggies caused by spatial aliasing?
>Are pixelation/jaggies caused by spatial aliasing?No it is not a concept of aliasing. It is a concept of imaging. When you are zooming into the image you will see pixellated image (or jaggies). Zooming in is the process of interpolation by means of pixel duplication. So whenever we interpolate data new frequencies get created called "images" by means of "zero insertion" now we need to filter the "images". If improper filtering is applied this causes jagginess or pixaltion. Hence a solution to overcome this problem is a technique called DCDi (patented by Faroudja, now the patent is with STM). Full form of DCDi is direction correlated diogonal interpolation. search google and u will hit a page which explains DCDi. Hence jagginess or pixalation is not a concept of aliasing but a concept of "imaging" Regards Bharat Pathak Arithos Designs www.Arithos.com DSP Design Consultancy and Training Company.
An example of spatial aliasing is the cart wheels in a movie when captured by motion camera at 24hz seems to roll in opposite direction. and then back in the same direction. This is phenomena of temporal frequencies getting aliased. When they get aliased it shows up on 2D image. Some companies claim that they can correct such artifacts. even if possible it will require lot of hardware to achieve it like frame buffers or so. and the advantage u gain will be small w.r.t just living with the phenomena. Regards Bharat Pathak Arithos Designs www.Arithos.com
bharat pathak wrote:> An example of spatial aliasing is the cart wheels > in a movie when captured by motion camera at 24hz > seems to roll in opposite direction. and then back > in the same direction.That temporal aliasing. Not spatial aliasing.
bharat pathak wrote:> No it is not a concept of aliasing. It is a concept of > imaging. When you are zooming into the image you will > see pixellated image (or jaggies). Zooming in is the > process of interpolation by means of pixel duplication. > So whenever we interpolate data new frequencies get > created called "images" by means of "zero insertion" > now we need to filter the "images". If improper filtering > is applied this causes jagginess or pixaltion. Hence > a solution to overcome this problem is a technique > called DCDi (patented by Faroudja, now the patent is with > STM). Full form of DCDi is direction correlated diogonal > interpolation. search google and u will hit a page which > explains DCDi. Hence jagginess or pixalation is not a > concept of aliasing but a concept of "imaging"You say pixelation/jaggies have nothing to do with aliasing. Then why does an insufficient pixelXpixel resolution cause an image to pixelate? My monitor's resolution has a pixelXpixel resolution of 1280 X 1024. The pixelation/jaggies on many of the compressed video on Utube as well as many movies generally available online have an insufficient pixelXpixel resolution. This causes pixelation/jaggies. Why does it cause pixelation/jaggies if pixelation/jaggies have nothing to do with aliasing? AFAIK, a higher pixelXpixel resolution allows for higher spatial frequencies without spatial distortion. http://en.wikipedia.org/wiki/Spatial_frequency
On May 26, 10:13 am, "Green Xenon [Radium]" <gluceg...@excite.com> wrote:> You say pixelation/jaggies have nothing to do with aliasing. Then why > does an insufficient pixelXpixel resolution cause an image to pixelate?Pixels can become visible because of the addition of high frequency edges during the imaging process. Depends on whether you are talking about the pixel resolution of the capture, the compressed storage format, the decompressed image format, or the display format, and/or any conversion or filtering processes between any of the above and also between the display and the back of the viewers eyeballs. IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
Hi, Let's look at it from sampling theorem perpective. Any ADC has 2 stages. 1. first stage that performs time discretization. 2. second stage that performs value discretization. Time discretization will tell how fine a pixel could be. Basically the resolution of the image like 512x512 pixels or 1920x1080 pixels. One aspect of image looking coarse or fine can come from this. This exactly is something like your digital camera specifying 5 mega pixels or 10 mega pixels. If you are not making hoardings out of your photos then you really don't have to buy 10 mega pixel camera. So this pixel density makes sense only when you tell what size of display in inches u r going to display or print the image and what is the distance from which you will be viewing the same. Second aspect is pixel depth (or value quantization). Let us assume that a gray scale pixel could be represented using 8 bit depth. But instead you represented using 4 bit depth then the image is coarsely quantized and thus causes contouring artifacts. The one that u see on you tube fall under this category. Originally the video would like fine. but due to compression, you see blocking artifacts (which u refer as pixellation/jagginess). Hope this clears some cloud. Bharat Pathak Arithos Designs www.Arithos.com DSP Design Consultancy and Training Company.
