how do I do DCT on a 100x100 image?
Started by huhua ●May 28, 2008
Let's say I have an image, which is 100 x 100.
Each pixel is currently a real number, between 0 and 1.
Totally there are 10000 pixels.
The goal is to use DCT to reduce the 10000 pixels to hopefully 100 pixels,
just like those DCTs in JPEG...
Because there is an obvious pattern in the 100 x 100 image.
What's the most convenient way to do it in Matlab?
Thanks!
Is this simply for data compression, or are you trying to extract key
parameters from the original data set?
If for data compression, is a lossy algorithm OK, or do you need it to be
lossless?
matlab has a function called dct2
use it.
bharat pathak
arithos designs
www.Arithos.com
"SteveSmith" <Steve.Smith1@SpectrumSDI.com> wrote in message
news:Iu2dnbg7Lb0VX6DVnZ2dnUVZ_r3inZ2d@giganews.com...
> Is this simply for data compression, or are you trying to extract key > parameters from the original data set? > > If for data compression, is a lossy algorithm OK, or do you need it to be > lossless? > >
I hope the majority of info/energy is concentrated in the 100 "essential" elements after transform. So lossy is okay. DCT should be enough for me, I guess. Because my 100x100 image has really very obvious pattern in it. For example, I hope the 100 "essential" elements will keep 99% of the energy/info of the original image, so I am willing to do the truncation and approximation!
"bharat pathak" <bharat@arithos.com> wrote in message
news:x-ydnb2qdvrRjKPVnZ2dnUVZ_srinZ2d@giganews.com...
> matlab has a function called dct2 > use it. > > bharat pathak > > arithos designs > www.Arithos.com >
Do I need to cut the 100 x 100 image into 8x8 first? I remember in JPEG we do that... but not sure here... Any more elaborated examples for a real-valued (from 0 to 1) image? Thanks!
On May 29, 11:33 am, "huhua" <lunamoonm...@gmail.com> wrote:
> "SteveSmith" <Steve.Smi...@SpectrumSDI.com> wrote in message > > news:Iu2dnbg7Lb0VX6DVnZ2dnUVZ_r3inZ2d@giganews.com... > > > Is this simply for data compression, or are you trying to extract key > > parameters from the original data set? > > > If for data compression, is a lossy algorithm OK, or do you need it to be > > lossless? > > I hope the majority of info/energy is concentrated in the 100 "essential" > elements after transform. > > So lossy is okay. DCT should be enough for me, I guess. Because my 100x100 > image has really very obvious pattern in it.
DCT based compression(as in JPEG,MPEG) is used when the images are of nature generated, meant for human viewing bcoz higher frequencies are not present in naturally generated image and also cannot be percieved by human visual system. What kind of data is your image holding and whoom it is meant for ? If its just a very obvious pattern doesnt mean you can ignore higher frequencies. You can also look for KLT bases compression for obvious patterns. ignore higher frequencies.
> > For example, I hope the 100 "essential" elements will keep 99% of the > energy/info of the original image, so I am willing to do the truncation and > approximation!
huhua wrote:
> > "bharat pathak" <bharat@arithos.com> wrote in message > news:x-ydnb2qdvrRjKPVnZ2dnUVZ_srinZ2d@giganews.com... > > matlab has a function called dct2 > > use it. > > > > bharat pathak > > > > arithos designs > > www.Arithos.com > > > > Do I need to cut the 100 x 100 image into 8x8 first?
If you want to go from 100X100 to 10X10 you need to make each DCT transform 10X10 (instead of 8X8). Then when you have 100 transforms results with 100 frequency elements in each. Then you need iterate thru the 100 elements in each by discarding and quantizing some or all. Usually the scheme for doing that affects the higher frequencies the most the lower frequencies less and usually leaves the DC element alone). That is the lossy part. After that you get data reduction by standard data compression techniques which are usually lossless. In other words, if you do the quantization and/or discarding part as just zeroing bits you will after doing that have the same size data as the original (with a lot of bits zeroed). If you then run that data thru a typical compression scheme (e.g. zip it) you will get much greater data reduction than just compressing the original. Or you can create your own compression scheme based on your knowledge of where the data is dense and where it is sparse. To reverse the process you would uncompress (e.g. unzip) and then do the inverse transform. -jim < I remember in JPEG we
> do that... but not sure here... Any more elaborated examples for a > real-valued (from 0 to 1) image? > > Thanks!
----== Posted via Pronews.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.pronews.com The #1 Newsgroup Service in the World! >100,000 Newsgroups ---= - Total Privacy via Encryption =---
we
>do that... but not sure here... Any more elaborated examples for a >real-valued (from 0 to 1) image?
Not needed. example listed: a = rand(100, 100); % will generate 100x100 real random nums from 0 to 1 y = dct2(a); %------------------------ done Bharat Pathak Arithos Designs www.Arithos.com DSP Design Consultancy and Training Company.
"jim" <"sjedgingN0sp"@m@mwt.net> wrote in message
news:1212070084_3372@isp.n...
> > > huhua wrote: >> >> "bharat pathak" <bharat@arithos.com> wrote in message >> news:x-ydnb2qdvrRjKPVnZ2dnUVZ_srinZ2d@giganews.com... >> > matlab has a function called dct2 >> > use it. >> > >> > bharat pathak >> > >> > arithos designs >> > www.Arithos.com >> > >> >> Do I need to cut the 100 x 100 image into 8x8 first? > > If you want to go from 100X100 to 10X10 you need to make each DCT > transform 10X10 (instead of 8X8). Then when you have 100 transforms > results with 100 frequency elements in each. Then you need iterate thru > the 100 elements in each by discarding and quantizing some or all. Usually > the scheme for doing that affects the higher frequencies the most the > lower frequencies less and usually leaves the DC element alone). That is > the lossy part. After that you get data reduction by standard data > compression techniques which are usually lossless. > In other words, if you do the quantization and/or discarding part as > just zeroing bits you will after doing that have the same size data as the > original (with a lot of bits zeroed). If you then run that data thru a > typical compression scheme (e.g. zip it) you will get much greater data > reduction than just compressing the original. Or you can create your own > compression scheme based on your knowledge of where the data is dense and > where it is sparse. > To reverse the process you would uncompress (e.g. unzip) and then do the > inverse transform. > > -jim >
Is it possible to run 2D DCT on my 100x100 image directly and select the top-left panel (approx. 10x100) which are the dominating ones and neglect the rest?
huhua wrote:
> "jim" <"sjedgingN0sp"@m@mwt.net> wrote in message > news:1212070084_3372@isp.n... >> >> huhua wrote: >>> "bharat pathak" <bharat@arithos.com> wrote in message >>> news:x-ydnb2qdvrRjKPVnZ2dnUVZ_srinZ2d@giganews.com... >>>> matlab has a function called dct2 >>>> use it. >>>> >>>> bharat pathak >>>> >>>> arithos designs >>>> www.Arithos.com >>>> >>> Do I need to cut the 100 x 100 image into 8x8 first? >> If you want to go from 100X100 to 10X10 you need to make each DCT >> transform 10X10 (instead of 8X8). Then when you have 100 transforms >> results with 100 frequency elements in each. Then you need iterate thru >> the 100 elements in each by discarding and quantizing some or all. Usually >> the scheme for doing that affects the higher frequencies the most the >> lower frequencies less and usually leaves the DC element alone). That is >> the lossy part. After that you get data reduction by standard data >> compression techniques which are usually lossless. >> In other words, if you do the quantization and/or discarding part as >> just zeroing bits you will after doing that have the same size data as the >> original (with a lot of bits zeroed). If you then run that data thru a >> typical compression scheme (e.g. zip it) you will get much greater data >> reduction than just compressing the original. Or you can create your own >> compression scheme based on your knowledge of where the data is dense and >> where it is sparse. >> To reverse the process you would uncompress (e.g. unzip) and then do the >> inverse transform. >> >> -jim >> > > Is it possible to run 2D DCT on my 100x100 image directly and select the > top-left panel (approx. 10x100) which are the dominating ones and neglect > the rest?
You will get a result, but it may not be a result you like. Try it. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
