Hi: What are the specs of uncompressed linear PCM video? The specs of uncompressed linear PCM audio are bit-rate, sample-rate, bit-resolution, and number of channels [1 if mono, 2 if stereo] In LPCM audio, Bit-rate = sample-rate X bit-resolution X # of channels In CD-audio, sample-rate is 44.1 kHz, bit-resolution is 16-bit, and with 2 channels [stereo] For CD, Bit-rate = 44,100 X 16 X 2 = 1,411,200 bits per seconds Thanks a bunch, Radium
Linear PCM video; specs?
Started by ●June 1, 2008
Reply by ●June 1, 20082008-06-01
On May 31, 10:14 pm, "Green Xenon [Radium]" <gluceg...@excite.com> wrote:> What are the specs of uncompressed linear PCM video? > > The specs of uncompressed linear PCM audio are bit-rate, sample-rate, > bit-resolution, and number of channels [1 if mono, 2 if stereo] > > In LPCM audio, > > Bit-rate = sample-rate X bit-resolution X # of channels > > In CD-audio, sample-rate is 44.1 kHz, bit-resolution is 16-bit, and with > 2 channels [stereo] > > For CD, > > Bit-rate = 44,100 X 16 X 2 = 1,411,200 bits per secondsLook up CCIR 601 (or ITU Rec. 601) for SD digital video. 3 channels: Y Cr Cb, luminance sample rate at 13.5 MHz, half that for U and V color. The D1 digital tape format was an 8-bit serial protocol version at 216 Mbit/s. Rec. 709 is the equivalent format standard for HD. IMHO. YMMV.
