Hello All, The TimingAnalyzer can be used to quickly and easily draw timing diagrams. Signals, clocks, buses, delays, constraints, and states are easily added from the GUI. It can also be used to quickly do a timing analysis and check for timing faults. Minimum, typical, and worst case analysis can be performed. Delays and constraints are easily specified and changed to see if faster clocks or slower parts can be used without any timing faults. There are 3 editions planned. The Free Edition(FE), the Standard Edition(SE), and the Professional Edition(PE). You can download the Free Edition now and read all about the TimingAnalyzer at: www.timing-diagrams.com Comments and feedback are welcome at support@timing-diagrams.com
ANNOUNCE:-- TimingAnalyzer Free Version -- Draw timing diagrams
Started by ●June 2, 2008
Reply by ●June 2, 20082008-06-02
On Jun 2, 5:58 am, timinganalyzer <timinganaly...@gmail.com> wrote:> Hello All, > > The TimingAnalyzer can be used to quickly and easily draw timing > diagrams. > Signals, clocks, buses, delays, constraints, and states are easily > added > from the GUI. > > It can also be used to quickly do a timing analysis and check for > timing faults. Minimum, typical, and worst case analysis can be > performed. > Delays and constraints are easily specified and changed to see if > faster > clocks or slower parts can be used without any timing faults. > > There are 3 editions planned. The Free Edition(FE), the Standard > Edition(SE), > and the Professional Edition(PE). > > You can download the Free Edition now and read all about the > TimingAnalyzer at: > > www.timing-diagrams.com > > Comments and feedback are welcome at > > supp...@timing-diagrams.comHey, it's back! It's good to see that this hasn't died. The commercial alternatives are WAAAAAY too expensive. -a
On Jun 2, 5:40 pm, Andy Peters <goo...@latke.net> wrote:> On Jun 2, 5:58 am, timinganalyzer <timinganaly...@gmail.com> wrote: > > > > > Hello All, > > > The TimingAnalyzer can be used to quickly and easily draw timing > > diagrams. > > Signals, clocks, buses, delays, constraints, and states are easily > > added > > from the GUI. > > > It can also be used to quickly do a timing analysis and check for > > timing faults. Minimum, typical, and worst case analysis can be > > performed. > > Delays and constraints are easily specified and changed to see if > > faster > > clocks or slower parts can be used without any timing faults. > > > There are 3 editions planned. The Free Edition(FE), the Standard > > Edition(SE), > > and the Professional Edition(PE). > > > You can download the Free Edition now and read all about the > > TimingAnalyzer at: > > >www.timing-diagrams.com > > > Comments and feedback are welcome at > > > supp...@timing-diagrams.com > > Hey, it's back! > > It's good to see that this hasn't died. The commercial alternatives > are WAAAAAY too expensive. > > -aYes, it's alive and doing well, and yes the competition is expensive. The TimingAnalyzer will not be. I'm trying very hard to make it as easy as possible to use. Please feel free to request new features or suggest feature improvements. Regards, Dan
Reply by ●June 4, 20082008-06-04
On Jun 2, 8:37 pm, timinganalyzer <timinganaly...@gmail.com> wrote:> On Jun 2, 5:40 pm, Andy Peters <goo...@latke.net> wrote: > > > > > On Jun 2, 5:58 am,timinganalyzer<timinganaly...@gmail.com> wrote: > > > > Hello All, > > > > TheTimingAnalyzercan be used to quickly and easily draw timing > > > diagrams. > > > Signals, clocks, buses, delays, constraints, and states are easily > > > added > > > from the GUI. > > > > It can also be used to quickly do a timing analysis and check for > > > timing faults. Minimum, typical, and worst case analysis can be > > > performed. > > > Delays and constraints are easily specified and changed to see if > > > faster > > > clocks or slower parts can be used without any timing faults. > > > > There are 3 editions planned. The Free Edition(FE), the Standard > > > Edition(SE), > > > and the Professional Edition(PE). > > > > You can download the Free Edition now and read all about the > > >TimingAnalyzerat: > > > >www.timing-diagrams.com > > > > Comments and feedback are welcome at > > > > supp...@timing-diagrams.com > > > Hey, it's back! > > > It's good to see that this hasn't died. The commercial alternatives > > are WAAAAAY too expensive. > > > -a > > Yes, it's alive and doing well, and yes the competition is expensive. > TheTimingAnalyzerwill not be. I'm trying very hard to make it as > easy as > possible to use. > > Please feel free to request new features or suggest feature > improvements. > > Regards, > DanI installed the program and it ran once. But when I try to run it a second time, it will not start. Any ideas?
On Jun 4, 1:36 pm, rickman <gnu...@gmail.com> wrote:> On Jun 2, 8:37 pm, timinganalyzer <timinganaly...@gmail.com> wrote: > > > > > On Jun 2, 5:40 pm, Andy Peters <goo...@latke.net> wrote: > > > > On Jun 2, 5:58 am,timinganalyzer<timinganaly...@gmail.com> wrote: > > > > > Hello All, > > > > > TheTimingAnalyzercan be used to quickly and easily draw timing > > > > diagrams. > > > > Signals, clocks, buses, delays, constraints, and states are easily > > > > added > > > > from the GUI. > > > > > It can also be used to quickly do a timing analysis and check for > > > > timing faults. Minimum, typical, and worst case analysis can be > > > > performed. > > > > Delays and constraints are easily specified and changed to see if > > > > faster > > > > clocks or slower parts can be used without any timing faults. > > > > > There are 3 editions planned. The Free Edition(FE), the Standard > > > > Edition(SE), > > > > and the Professional Edition(PE). > > > > > You can download the Free Edition now and read all about the > > > >TimingAnalyzerat: > > > > >www.timing-diagrams.com > > > > > Comments and feedback are welcome at > > > > > supp...@timing-diagrams.com > > > > Hey, it's back! > > > > It's good to see that this hasn't died. The commercial alternatives > > > are WAAAAAY too expensive. > > > > -a > > > Yes, it's alive and doing well, and yes the competition is expensive. > > TheTimingAnalyzerwill not be. I'm trying very hard to make it as > > easy as > > possible to use. > > > Please feel free to request new features or suggest feature > > improvements. > > > Regards, > > Dan > > I installed the program and it ran once. But when I try to run it a > second time, it will not start. Any ideas?To get some info on why it won't run I ran it in a DOS box. TimingAnalyzer Version 0.82 Free Edition(FE) OS Name = Windows 2000 OS Version = 5.0 OS Arch = x86 Java Version = 1.6.0_03 installDir = C:\Program Files\TimingAnalyzer_b82 Settings File = C:\Program Files\TimingAnalyzer_b82\settings \ta_defaults Exception in thread "main" java.lang.NullPointerException at org.dmad.ta.TimingDiagram.findEdge(TimingDiagram.java:2238) at org.dmad.ta.TimFileIO.readDelay(TimFileIO.java:481) at org.dmad.ta.TimFileIO.processFileRequest(TimFileIO.java: 1245) at org.dmad.ta.TimFileIO.<init>(TimFileIO.java:103) at org.dmad.ta.TimingDiagram.openFile(TimingDiagram.java:3641) at org.dmad.ta.TimingAnalyzer.openRecentFile(TimingAnalyzer.java:1682) at org.dmad.ta.TimingAnalyzer.loadOpenFileList(TimingAnalyzer.java:1511) at org.dmad.ta.TimingAnalyzer.<init>(TimingAnalyzer.java:314) at org.dmad.ta.TimingAnalyzer.main(TimingAnalyzer.java:138)
On Jun 2, 8:58 am, timinganalyzer <timinganaly...@gmail.com> wrote:> Hello All, > > The TimingAnalyzer can be used to quickly and easily draw timing > diagrams. > Signals, clocks, buses, delays, constraints, and states are easily > added > from the GUI. > > It can also be used to quickly do a timing analysis and check for > timing faults. Minimum, typical, and worst case analysis can be > performed. > Delays and constraints are easily specified and changed to see if > faster > clocks or slower parts can be used without any timing faults. > > There are 3 editions planned. The Free Edition(FE), the Standard > Edition(SE), > and the Professional Edition(PE). > > You can download the Free Edition now and read all about the > TimingAnalyzer at: > > www.timing-diagrams.com > > Comments and feedback are welcome at > > supp...@timing-diagrams.comI spent about 5 minutes working with this program before I gave up. My reason is not the problem posted below, but because of the user interface decisions made. I don't know why every new program has to reinvent something about the user interface. There is a standard call Common User Interface (CUI) that is even documented by Microsoft, IIRC. The one big difference that hit me up side my head was the way the Cntl key is used counter-intuitively with mouse clicks for selections. If you click on one item it is selected. If you click on an second item, it is *added* to the selections. To deselect something you have to either press the Cntl key while clicking on it or you have to use the ESC key. I have *never* seen a program use this sort of selection mechanism. I have seen variations on how you select multiple, but every other program I have ever worked with, the default action of clicking a new thing while an old thing was selected was to deselect the first thing and to select the new thing. It was more than once that I tried to move some things and ended up with a mess because extra moves kept happening. Combine this with the lack of a working undo feature and I ended up rather frustrated and gave up. I was looking for something that would save me time over a program like Visio. I suggest that the author get some references on CUI or better yet, use some other programs with graphical interfaces and go with the flow. It is so much more productive than trying to retrain the world... if you don't believe me, just look down at your keyboard. Do you think the keyboard layout we all use was a good idea? It's just easier to continue to use it than it is to retrain everyone that is using it now. Rick
Reply by ●June 5, 20082008-06-05
On Jun 4, 3:44 pm, rickman <gnu...@gmail.com> wrote:> On Jun 2, 8:58 am, timinganalyzer <timinganaly...@gmail.com> wrote: >> > > > Hello All, > > > The TimingAnalyzer can be used to quickly and easily draw timing > > diagrams. > > Signals, clocks, buses, delays, constraints, and states are easily > > added > > from the GUI. > > > It can also be used to quickly do a timing analysis and check for > > timing faults. Minimum, typical, and worst case analysis can be > > performed. > > Delays and constraints are easily specified and changed to see if > > faster > > clocks or slower parts can be used without any timing faults. > > > There are 3 editions planned. The Free Edition(FE), the Standard > > Edition(SE), > > and the Professional Edition(PE). > > > You can download the Free Edition now and read all about the > > TimingAnalyzer at: > > >www.timing-diagrams.com > > > Comments and feedback are welcome at > > > supp...@timing-diagrams.com > > I spent about 5 minutes working with this program before I gave up. > My reason is not the problem posted below, but because of the user > interface decisions made. I don't know why every new program has to > reinvent something about the user interface. There is a standard call > Common User Interface (CUI) that is even documented by Microsoft, > IIRC. > > The one big difference that hit me up side my head was the way the > Cntl key is used counter-intuitively with mouse clicks for > selections. If you click on one item it is selected. If you click on > an second item, it is *added* to the selections. To deselect > something you have to either press the Cntl key while clicking on it > or you have to use the ESC key. I have *never* seen a program use > this sort of selection mechanism. I have seen variations on how you > select multiple, but every other program I have ever worked with, the > default action of clicking a new thing while an old thing was selected > was to deselect the first thing and to select the new thing. > > It was more than once that I tried to move some things and ended up > with a mess because extra moves kept happening. Combine this with the > lack of a working undo feature and I ended up rather frustrated and > gave up. I was looking for something that would save me time over a > program like Visio. > > I suggest that the author get some references on CUI or better yet, > use some other programs with graphical interfaces and go with the > flow. It is so much more productive than trying to retrain the > world... if you don't believe me, just look down at your keyboard. Do > you think the keyboard layout we all use was a good idea? It's just > easier to continue to use it than it is to retrain everyone that is > using it now. > > RickHello Rick, The goal is to make drawing timing diagrams as easy as possible, and I do agree about sticking to standard GUI practices, and that should be done for each OS. The program is in beta testing and I know it's not perfect but don't forget to look at the big picture. Not only can you draw timing diagrams, you can do timing analysis and show margins and find faults in designs, you can write scripts that automatically draw the diagrams so complex diagrams can be made with one command, or test vectors or testbenches can be generated with one command. If you need to document simulation results, it can read VCD formated files, then you can make annotated timing diagrams from simulations and include them in design documentation. With actual logic functions you can simulate gates, registers, counters, shift registers, and other logic functions which can help when deciding if the logic if fast enough or the clocks are to fast. So, keeping all that in mind, if beta users make valid and constructive suggestions for improvements and new features, they will incorporated into the program. Most all of them will be added before the final release 1.0. -Dan
On Wed, 4 Jun 2008 12:44:03 -0700 (PDT), rickman <gnuarm@gmail.com> wrote:>On Jun 2, 8:58 am, timinganalyzer <timinganaly...@gmail.com> wrote: >> Hello All, >> >> The TimingAnalyzer can be used to quickly and easily draw timing >> diagrams. >> Signals, clocks, buses, delays, constraints, and states are easily >> added >> from the GUI.>> www.timing-diagrams.com >> >> Comments and feedback are welcome at >> >> supp...@timing-diagrams.com > >I spent about 5 minutes working with this program before I gave up. >My reason is not the problem posted below, but because of the user >interface decisions made. I don't know why every new program has to >reinvent something about the user interface. There is a standard call >Common User Interface (CUI) that is even documented by Microsoft, >IIRC.Do you work in the NHS, or for one of their equipment suppliers? All the CUI references (including http://www.mscui.net/ seem to be associated with the health care sector. If you are thinking of some other user interface specification, can you help find it? (Not that a specification for the medical industry couldn't be more generally useful, but it seems unlikely to cover complex drawing tools) - Brian
On Jun 5, 9:14 am, Brian Drummond <brian_drumm...@btconnect.com> wrote:> On Wed, 4 Jun 2008 12:44:03 -0700 (PDT), rickman <gnu...@gmail.com> > wrote: > > > > >On Jun 2, 8:58 am, timinganalyzer <timinganaly...@gmail.com> wrote: > >> Hello All, > > >> The TimingAnalyzer can be used to quickly and easily draw timing > >> diagrams. > >> Signals, clocks, buses, delays, constraints, and states are easily > >> added > >> from the GUI. > >>www.timing-diagrams.com > > >> Comments and feedback are welcome at > > >> supp...@timing-diagrams.com > > >I spent about 5 minutes working with this program before I gave up. > >My reason is not the problem posted below, but because of the user > >interface decisions made. I don't know why every new program has to > >reinvent something about the user interface. There is a standard call > >Common User Interface (CUI) that is even documented by Microsoft, > >IIRC. > > Do you work in the NHS, or for one of their equipment suppliers? > All the CUI references (includinghttp://www.mscui.net/seem to be > associated with the health care sector.I have no idea what you are talking about... I am an electronic design engineer and have never worked in the health care sector. What exactly is NHS? Is that a government agency or a company? BTW, I typoed above "call" should have been "called". CUI is a windows standard as far as I know. I guess maybe it is more general, but I have only heard the term used in the context of Windows.> If you are thinking of some other user interface specification, can you > help find it?Doesn't Microsoft provide a CUI for Windows? If nothing else, all you have to do is fire up most *any* program to learn how mouse clicks work to select items. Having the default action of a click to be "adding" items to the selection is a new twist. Most programs use Cntl-Left Click to cumulatively select items (or often to unselect them too). Unselection is typically done by clicking on *anything* else including nothing. So if I click on object A and then click on object B and drag, I would not expect object A to be dragged along with B. This happened to me with this program. Object A was dragged off the view and the undo didn't work. I couldn't find a way to expand the view, so I ended up with a drawing that had things in it that I couldn't delete or see. I ended up closing the program (partly out of frustration and partly out of time constraints) and let it save the file. I tried to start the program up again and it would not run. The author says the drawing file is now corrupt. When the program auto-opens it on startup, it crashes. Independant of the UI issues, a program really shouldn't crash when it reads a data file... of any nature. Of course that is a theoretical goal and can be difficult to achieve in practice. But certainly crashing on startup without visible error messages is not a good thing either. I had to start it from a DOS box to get anything useful from it... maybe that is more of a Java issue... and don't get me started complaining about Java. Does *anything* written in Java actually work? I'm really not trying to bash the tool. I expect there are those who like it and use it. I have often wanted a good tool for drawing waveforms and timing diagrams. But the very first and most important feature is that it has to be easy and intuitive to use. I feel that I should be able to sit down and use it without reading a manual or taking a tutorial. Many years ago I did that with a Mac! I expect most people do that with the iPhone and iPod. A timing diagram editor is not a complex tool. I should be able to draw simple waveforms without learning a complex interface. I currently use Visio and I find that to be a burdensome tool for simple things. It also has its own ways in which it doesn't work. I just wanted something a bit simpler.> (Not that a specification for the medical industry couldn't be more > generally useful, but it seems unlikely to cover complex drawing tools)I agree. I'm not sure why you mention this, but it sounds right. Do you know of a common denominator for tools with graphical interfaces? BTW, as long as I am ragging on the world of software. I don't like excessive movements of the mouse and switching back and forth with the keyboard. One of the things I have done to minimize movements is to move my windows toolbar to the top of the screen next to the menu of most programs. I find this so much easier to use than dragging the mouse around from top to bottom of the screen when I want to select between programs (which I seem to do a lot). The problem is that *many* programs (including Visio) don't understand that the windows toolbar is at the top now. New windows open with the title bar at the top of the screen, under the toolbar. Worse, some programs remember that they were at the top of screen, but remember it correctly (as being X pixels above the visible edge). Then when they restart incorrectly (or the dialog is reopened) the window is that much *more* off the top of the screen!!! With those applications I have to drag them well back onto the visible screen and try to remember to drag them back toward the middle before I close when they start drifting off the top again. Is it time to start cutting off fingers of programmers who continually mess up things like this? After a few mistakes they will be much less proficient at pumping out code (producing fewer bad programs) and after 10 mistakes... well I guess they could still type with their noses... 8^* Just a thought... Rick PS I am currently struggling with the Aldec simulator which has it's own set of problems. I'm actually here to complain about that, but I'll do it in another thread.
"rickman" <gnuarm@gmail.com> wrote in message news:3253a340-9804-4fd5-b6d8-df9dd706ae86@c58g2000hsc.googlegroups.com... [snip]> Independant of the UI issues, a program really shouldn't crash when it > reads a data file... of any nature. Of course that is a theoretical > goal and can be difficult to achieve in practice. But certainly > crashing on startup without visible error messages is not a good thing > either. I had to start it from a DOS box to get anything useful from > it... maybe that is more of a Java issue... and don't get me started > complaining about Java. Does *anything* written in Java actually > work? >I suggest that any program for Windows Vista that uses Java should start with a check to see if Java is even installed, and if so, whether the version installed is suitable for what the program needs. My version of Vista came without Java, and the Microsoft version is no longer available. I installed the Sun version, but still have problems with getting all the programs that use Java to run correctly. http://www.java.com/en/
