trigonometric "downsampling" in frequency domain
Started by RobR ●June 2, 2008
On Mon, 02 Jun 2008 09:57:20 -0400, Jerry Avins <jya@ieee.org> wrote:
>RobR wrote: >> Hi, >> >> Problem description: >> >> i have 12 complex frequency domain (FD) samples that are a subset of a >> time domain (TD) sampled signal (known sampling rate) that has been FD >> converted via fixed size fft; so the frequency spacing is known. >> >> now i pad zeros to those 12 FD samples and perform an 2048-ifft to achieve >> oversampled (trigonometrically interpolated) TD representation. >> then i apply a TD window filter. >> next i transform back to FD via 2048-fft over all TD samples (also those >> that have been supressed by the filter). > >OK so far. > >> so i end up with an FD representation being 2048/12 (about 170) times the >> FD resolution i started over. > >No. You have more points to plot -- you call them trigonometrically >interpolated -- but no more information, Therefore no more resolution. >*No information was created. You have learned nothing new.* > >> So my understanding is, that when i had frequency spacing x in the >> beginning, now i have frequency spacing x/170, so about 170 times finer. > >Yes. > >> Now my question: >> what is the correct FD operation to merge this fine resolved FD samples to >> the original frequency spacing? >> In other words: i want my 12 complex FD samples back (but now filtered of >> course). > >Why didn't you just filter the time-domain signal? > >> Is it take a bunch of 170 finer samples and add them together, or do i >> have to apply a (anti alias) filter and then pick out every 170th sample? >> Or? > >What do you want to accomplish? All filters, no matter how implemented, >trash the beginning and end of the signal (start and end transients). A >sequence of only 12 samples is hard to deal with. > >Jerry
Hi Jerry, ah, you ask just the right questions. RobR is certainly performing a lot of number crunching to 'process' (whatever 'process' means) 12 time samples. Good point about the "start and end transients" Jerry. I wonder what, exactly, RobR is trying to accomplish. Regards, [-Rick-]
