Hi! I would like to calculate the BER of an optical communications system. The only known value is the total collected intensity as a function of time (I thus can calculate mean intensity, variance,...). The modulation format doesn't matter. The simplest is the best; so we can take OOK modulation. I think that BER is also function of the SNR. How can I calculated the BER if I take a OOK modulation (or any other) and fix the SNR to a certain value? Thank you for your time, Noah
Calculating BER for optical communications
Started by ●June 3, 2008
Reply by ●June 3, 20082008-06-03
noahh.schwartz@gmail.com wrote:> Hi! > > I would like to calculate the BER of an optical communications > system. > > The only known value is the total collected intensity as a function of > time (I thus can calculate mean intensity, variance,...). The > modulation format doesn't matter. The simplest is the best; so we can > take OOK modulation. I think that BER is also function of the SNR. > > How can I calculated the BER if I take a OOK modulation (or any other) > and fix the SNR to a certain value? > > Thank you for your time, > NoahHave you done a web search for "BER calculation?" In broad terms, you find the probability distribution of your received signal when a zero has been transmitted, and the probability distribution of your received signal when a one has been transmitted. Then you use these PDFs along with the receiver design to calculate the fraction of bits received in error. Doing this calculation requires that you know the SNR of your received signal at your receiver's bit slicer, which usually requires you to know the SNR of the signal going into your detector as well as the physics of your detector (or at least its behavior in detail) and any signal processing hardware that follows it. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" gives you just what it says. See details at http://www.wescottdesign.com/actfes/actfes.html
