Jerry Avins schrieb:> I don't know about that. I once decided to see how concentrated I could > make hydrogen peroxide. My last measurement showed something over 80%. I > had planks rigged so the force of the explosion went over my head. Just.As a kid I found out (by accident) how to make prussian blue pigments out of chemicals I had at home. My father did photos and etched pcbs so we had quite a collection of chemicals.. I checked out what that prussian blue was and found out that it is not toxic. However, I did not checked what happends if you try to burn it (which I did). It dissolves into hydrocyanic acid. I found that out years later. I'm pretty sure I killed an army of guardian angles that day.. :-) Nils
sorta OT: A little knowledge is a dangerous thing.
Started by ●June 3, 2008
Reply by ●June 5, 20082008-06-05
"robert bristow-johnson" <rbj@audioimagination.com> wrote in message news:ec6f679d-3e64-4683-b9c0-2ec7bea74b4f@y21g2000hsf.googlegroups.com...> On Jun 4, 3:01 pm, Jerry Avins <j...@ieee.org> wrote: >> John Hadstate wrote: >> > On Jun 4, 9:16 am, Jerry Avins <j...@ieee.org> wrote: >> >> A series current limiter, like the inductive ballast in >> >> fluorescent >> >> lamps. If my mother's iron didn't blow the fuse when >> >> plugged in alone, >> >> why would it when in series with the arc? >> >> > My Dad used to swear that he could build a decent arc >> > welder using an >> > old stove burner in series with the welding rod. > ... >> I once arc welded a broken bell crank from a throttle >> linkage by winding >> one jumper cable through a tire rim to make an inductive >> ballast, > > i once made a simple arc welder outa a fully charged car > battery (shop > class in high school). voltage was a little low, but i could > get > about as much current as i needed. > > i imagine a parallel circuit of a few pairs of car batteries > in series > would give you enough juice to weld anything. kinda hard to > control.The voltage across a typical welding arc is quite low, about 3-5 volts if I remember correctly, so a 12-volt car battery will work. Higher voltage helps to establish the arc, especially with AC. When using DC, this is less of a problem, amd once you've got the arc going, it tends to be more stable. In fact, this was one major problem of the 36 VDC electrical system for passenger cars that was proposed a few years ago: once established and protected by insulation, DC arcs can be stable over amazing distances. It would still be a good idea to have some kind of ballast in series, especially when your source is a car battery. Otherwise, the battery internals provide the ballast, and we all know what happens to a ballast when it dissipates energy.
John E. Hadstate wrote:> > "robert bristow-johnson" <rbj@audioimagination.com> wrote in message > news:ec6f679d-3e64-4683-b9c0-2ec7bea74b4f@y21g2000hsf.googlegroups.com... >> On Jun 4, 3:01 pm, Jerry Avins <j...@ieee.org> wrote: >>> John Hadstate wrote: >>> > On Jun 4, 9:16 am, Jerry Avins <j...@ieee.org> wrote: >>> >> A series current limiter, like the inductive ballast in >> >>> fluorescent >>> >> lamps. If my mother's iron didn't blow the fuse when >> plugged in >>> alone, >>> >> why would it when in series with the arc? >>> >>> > My Dad used to swear that he could build a decent arc > welder >>> using an >>> > old stove burner in series with the welding rod. >> ... >>> I once arc welded a broken bell crank from a throttle linkage by winding >>> one jumper cable through a tire rim to make an inductive ballast, >> >> i once made a simple arc welder outa a fully charged car battery (shop >> class in high school). voltage was a little low, but i could get >> about as much current as i needed. >> >> i imagine a parallel circuit of a few pairs of car batteries in series >> would give you enough juice to weld anything. kinda hard to control. > > The voltage across a typical welding arc is quite low, about 3-5 volts > if I remember correctly, so a 12-volt car battery will work. Higher > voltage helps to establish the arc, especially with AC. When using DC, > this is less of a problem, amd once you've got the arc going, it tends > to be more stable. In fact, this was one major problem of the 36 VDC > electrical system for passenger cars that was proposed a few years ago: > once established and protected by insulation, DC arcs can be stable over > amazing distances. > > It would still be a good idea to have some kind of ballast in series, > especially when your source is a car battery. Otherwise, the battery > internals provide the ballast, and we all know what happens to a ballast > when it dissipates energy.I imagine that 12V with a suitable ballast (at least some inductance is very helpful for establishing low-voltage arcs) could work rather well. (At least some portable motor-generator sets for DC welding use reverse compounding to stabilize the arc current, and the armature winding provides plenty of inductance.) I made my tack welds using a six-volt battery. Ah, youth! Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Nils wrote:> Jerry Avins schrieb: >> I don't know about that. I once decided to see how concentrated I >> could make hydrogen peroxide. My last measurement showed something >> over 80%. I had planks rigged so the force of the explosion went over >> my head. Just. > > As a kid I found out (by accident) how to make prussian blue pigments > out of chemicals I had at home. My father did photos and etched pcbs so > we had quite a collection of chemicals.. > > I checked out what that prussian blue was and found out that it is not > toxic. However, I did not checked what happends if you try to burn it > (which I did). > > It dissolves into hydrocyanic acid. I found that out years later. > > I'm pretty sure I killed an army of guardian angles that day.. :-)My chemistry set taught me to make Prussian blue by reacting potassium ferrocyanide (the iron-cyanide bond is strong, effectively sequestering the CN) with iron chloride, both colorless. I went one better by dispersing the unreacted chemicals in a bar of soap, so that the color developed when the soap was used with water. Fun stuff! Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●June 6, 20082008-06-06
good stories. I shorted frequently 12V radio eliminator to see the sparks. I took this to 220V socket (on my bro's work bench). I put 2 screw drivers in the socket and shorted with a third one. unfortunately nothing spectacular happened not even a single spark. lights in the room just went off. I came down stairs and my mom was worried about big flash of light and thud in the main supply board :)
Reply by ●June 7, 20082008-06-07
Jerry Avins wrote: (snip)> Then he took the time to sit me down and explain about impedance and > such, adding to what I knew about circuits. When I built an electric-arc > furnace, I used an electric iron as ballast. I blew the main fuse again > anyway (how?), but I knew how to replace it.The closest story I have is supposed to have happened when I was about four. (I don't remember it, but this is how it was retold to me.) We were going into a furniture store, as I was walking slightly behind my parents. Just after passing a floor outlet (common in furniture stores) that was a little frayed looking (probably also too common), my dad realized that I would find it interesting. When the store lights went out, he immediately realized why. We ended up with a small table, free, to get us out of the store. I found yesterday a cord and socket for one C7 lamp that I have had since I was about four. It was originally for a fake fireplace as a christmas decoration, with a clip and sharp point that goes over the bulb and a little fan that turns from the convection over the bulb. That makes a shadow that looks like fire in the fireplace. I don't think I was allowed to have the sharp point, but the lamp socket has been mine since, usually used for lighting halloween pumpkins. -- glen
On 4 Jun, 08:27, "Fred Marshall" <fmarshallx@remove_the_x.acm.org> wrote:> It seemed like all I could do was to make pits. > > There was the pit in the kitchen faucet where I'd stabbed it with a test > probe connected to the 120vac. �This was part of an experiment in the > resistance of water with various amounts of salt in it - in series with a > light bulb. �The probes generally went into the salt water. �I witnessed that sort of thing in my first job, as a furnace operator on a metal plant. One of my duties was to walk an inspection round at start of shift. There was one more control room at the factory, and one day an operator from the other control room, who had walked the inspection round already, came to us to notify about 'sparks' in one of our furnaces. I went upstairs to see, and sure enoug, there was a ~1-1.5 m long light arc where none was supposed to be. I emptied a couple of fire extinguishers to try and control the thing, but to no avail. I went back down to the control room to notify my colleagues who went upstairs to have a look, after having instructed me to switch the furnace down to 'idle' but not shut it down. The area where the problem occured was monitored by a CCTV system (which of course did not cover the area where the rouge light arc occured) so I could see the guys bringing out the fire hose to attack the light arc. Suffice it to say that me shutting down the 40 MW / 120 kA furnace by the emergency switch is among the quickest operations I've ever done in my life. Rune
