hello all, just a question; I have a FIR filter and LMS algorithm to update the weights... after the algorithm converge I need copy the values of weights in a file, like a .dat or .txt... I'm going use the files in tests with matlab... Is there some way to do that in assembler (my algorithm is all in assembler)... ?? I'm using ADSP-21161 EZ-KIT, and Visual DSP 4.5... my vector of weights, is a circular buffer with 600 positions regards Henrique L. Barcellos
write data in file .dat using assemble
Started by ●June 10, 2008
Reply by ●June 11, 20082008-06-11
You can write the values into a specific memory location.Then open memmory in Visual DSP and dump the values from that memory location into a dat file. hbarcellos wrote:> hello all, > > just a question; I have a FIR filter and LMS algorithm to update the > weights... after the algorithm converge I need copy the values of weights > in a file, like a .dat or .txt... I'm going use the files in tests with > matlab... > > Is there some way to do that in assembler (my algorithm is all in > assembler)... ?? > > I'm using ADSP-21161 EZ-KIT, and Visual DSP 4.5... my vector of weights, > is a circular buffer with 600 positions > > > regards > > Henrique L. Barcellos
