Hi Vikram,>I think that you have given the right way to solve my problem for >addressing my research.Great! Would you mind sharing in which application this problem appears?>Two final queries: > >a). In Wainwright's theorem, the off-diagonal entries in the X matrix >are the same (equaling B). This requirement is not necessary for the S- >Lemma, right? That applies to my case.Now, looking back, it seems that S-lemma requires symmetric (or hermitian) matrices. So (I-G), and hence G, needs to be hermitian to invoke it. However, if your G is not hermitian, the story is not over. There is a neat trick to work around it: define H=(G+G*)/2, which implies (I-G)>0 => (I-H)>0 and (I+G)>0 => (I+H)>0 and then invoke S-lemma with this matrix. The result should look like 1-(v1+v2)'/2 * [I-(F+F*)/2]^{-1} * (v1+v2)/2 >0 and 1-(v1+v2)'/2 * [I+(F+F*)/2]^{-1} * (v1+v2)/2 >0.>b). It looks like your proof to show that Spectral Radius(G)<1 implies >I+G and I-G are positive definite is also a necessary condition.Do you mean |G|<1 => (I+G)>0 and (I-G)>0? If so, then yes. I believe the converse is also true.>Thank you very much. It was a pleasure interacting with you.Likewise. Good luck with your research. Emre
Spectral radius of non-negative matrix
Started by ●June 16, 2008
Reply by ●June 18, 20082008-06-18
