We have developed mpeg2 decoder,mp3 decoder with excellent performance on Blackfin uClinux, for many applications with LCD, Scaler with mpeg2 decoder is also developed to suit LCD with pixel format ,the following are the details of the performance of the above: MPEG2 decoder: MCPS for MPEG2 decoder: 300MHZ on BF54X DSP, for 3M bps stream,D1 25fps; 350MHZ on BF53X DSP, for 1M � 3M bps stream,D1,25fps; MCPS for scaler: 50MHZ; Memory for the above two: L1 data: 24K bytes; L1 program: 33.8K bytes; L3 data memory: 6M; Features: decodes non-scalable, spatial scalable, SNR scalable and data partitioning MPEG-2 video bit streams supports Simple, Main, SNR Scalable and Spatially Scalable Profile streams at all defined levels decodes MPEG-1 (ISO/IEC IS 11172-2) video bit streams Output: YUV420,YUV422, output size can be set through API Test: Passed decoder conformance test; Performance of MP3: MCPS for MP3 decoder: 55MHZ; Memory for MP3 decoder: L3 program: 28K; L3 data: 65K; Features: Support MPEG AUDIO LAYER 1/2/3; We will provide strong support if you interested in our algorithm and integrate them into your applications! We are a company focus on DSP algorithm development, we can also provide other DSP algorithms development, such as voice codec, echo cancellation, DTMF, caller ID, on voip,MPEG4,H.264 for multimedia applications. Thanks! Contact: zhou_xiangyang0406@126.com; phone: 86 755 13316987130; Smart International Inc.
Commercial mpeg2 decoder/scaler with industry leading performance on Blackfin uClinux are available!
Started by ●June 21, 2008
