Hi all, I am working on a project where I am trying to detect the direct path signal for ranging purposes using UWB technology. I am developing an algorithm that accounts for noise, but am still not sure how to account for the noise. I know I can't use the noise mean because that should be zero. I am pretty sure I should be using the variance but do not exactly understand why. Can anyone explain to me the significance of the noise variance as opposed to the noise mean in a signal? Or can anyone direct me to literature that discusses the processing of noise? Thanks. -jyproc
Noise processing
Started by ●June 24, 2008
Reply by ●June 24, 20082008-06-24
On Jun 24, 9:15�pm, "jyproc" <jyaqu...@gmail.com> wrote:> Hi all, > > I am working on a project where I am trying to detect the direct path > signal for ranging purposes using UWB technology. I am developing an > algorithm that accounts for noise, but am still not sure how to account for > the noise. I know I can't use the noise mean because that should be zero. I > am pretty sure I should be using the variance but do not exactly understand > why. Can anyone explain to me the significance of the noise variance as > opposed to the noise mean in a signal? Or can anyone direct me to > literature that discusses the processing of noise? Thanks. > > -jyprocI'm not sure what exactly you are looking for. But let's try a simple example. Suppose there is a value A that you are looking to estimate based on a set of observations: y_n = A + w_n, n = 0,1,...,N-1. Let's now say that w_n are Gaussian noise terms with variance \sigma^2 and mean 0. OK, so intuitively (and formally) the best estimate is given by: \hat{A} = 1/N \sum_n y_n. Then one way to assess the quality of your estimate is to look at the mean-square error: E[ | \hat{A} - A |^2 ] Now do some algebra and probability and you see how \sigma^2 effects this. Does that help? Julius
Reply by ●June 25, 20082008-06-25
Noise variance is the measure of noise power. the power of a noise signal is given by the following expression noise_power = (mean*mean) + variance ...... Eq 1 for noisy signals whose mean is zero, the variance indicates the power of the noisy signal. the above equation is true for periodic signals too like sine, square, triangular, etc. signal to noise ratio is a very important term to evaluate the performance of the datapath module. SNR = 10*log10(sig_pow/noi_pow) for periodic signals we know how to compute signal power. so only thing left is how to compute noise power, which is as mentioned in equation 1. If you look at the "physics" definition of RMS, things will be much more clearrer, RMS is defined as an equivalent amount of power dissipated by the dc source. then the dc value of the source is same as the rms value of the varying source. Thanks and Best Regards Bharat Pathak Arithos Designs www.Arithos.com DSP Design Consultancy and Training Company. Join us on Orkut community : http://www.orkut.co.in/Community.aspx?cmm=52708286
>On Jun 24, 9:15=A0pm, "jyproc" <jyaqu...@gmail.com> wrote: >> Hi all, >> >> I am working on a project where I am trying to detect the direct path >> signal for ranging purposes using UWB technology. I am developing an >> algorithm that accounts for noise, but am still not sure how to accountf=>or >> the noise. I know I can't use the noise mean because that should bezero.=> I >> am pretty sure I should be using the variance but do not exactlyundersta=>nd >> why. Can anyone explain to me the significance of the noise varianceas>> opposed to the noise mean in a signal? Or can anyone direct me to >> literature that discusses the processing of noise? Thanks. >> >> -jyproc > >I'm not sure what exactly you are looking for. >But let's try a simple example. Suppose there is >a value A that you are looking to estimate based >on a set of observations: > > y_n =3D A + w_n, n =3D 0,1,...,N-1. > >Let's now say that w_n are Gaussian noise terms >with variance \sigma^2 and mean 0. > >OK, so intuitively (and formally) the best estimate >is given by: > > \hat{A} =3D 1/N \sum_n y_n. > >Then one way to assess the quality of your estimate >is to look at the mean-square error: > > E[ | \hat{A} - A |^2 ] > >Now do some algebra and probability and you see >how \sigma^2 effects this. > >Does that help? > >Julius >Julius, I have a waveform obtained from the receiver that displays the amplitude received. I want to detect the first instance that corresponds to an actual received signal and not noise. Sorry for not being clearer earlier. That's why the algorithm should process the noise and account for it...to reduce the likelihood of detecting a noise signal as a received signal. Thanks for the help.
>Noise variance is the measure of noise power. > >the power of a noise signal is given by the >following expression > >noise_power = (mean*mean) + variance ...... Eq 1 > >for noisy signals whose mean is zero, the variance >indicates the power of the noisy signal. > >the above equation is true for periodic signals >too like sine, square, triangular, etc. > >signal to noise ratio is a very important term >to evaluate the performance of the datapath module. > >SNR = 10*log10(sig_pow/noi_pow) > >for periodic signals we know how to compute signal >power. so only thing left is how to compute noise >power, which is as mentioned in equation 1. > >If you look at the "physics" definition of RMS, things >will be much more clearrer, RMS is defined as an equivalent >amount of power dissipated by the dc source. then the dc >value of the source is same as the rms value of the varying >source. > >Thanks and Best Regards > >Bharat Pathak > >Arithos Designs >www.Arithos.com > >DSP Design Consultancy and Training Company. > >Join us on Orkut community : >http://www.orkut.co.in/Community.aspx?cmm=52708286 > > >Thanks for the help. So if all I need is the mean amplitude of the noise, I could simply use average_noise_amplitude=the mean of the absolute value of all noise samples. Right? Thanks. -jyproc
On 25 Jun, 15:36, "jyproc" <jyaqu...@gmail.com> wrote:> So if all I need is the mean amplitude of the noise, I could simply use > > average_noise_amplitude=the mean of the absolute value of all noise > samples. Right?If you really want to look at the *amplitude* then yes. But I doubt the result will be very helpful to you, since most noise processes encountered in communications are characterized as 'zero mean', referring to the mean of the amplitude. So you could have a lot of noise in your signal and still have the mean amplitude equal 0. The noise variance (which equals noise power in zero mean processes) is a far more helpful number, since it can be used in discussions about SNR and so on. Rune
On Jun 25, 8:30 am, "jyproc" <jyaqu...@gmail.com> wrote:> >On Jun 24, 9:15=A0pm, "jyproc" <jyaqu...@gmail.com> wrote: > >> Hi all, > > >> I am working on a project where I am trying to detect the direct path > >> signal for ranging purposes using UWB technology. I am developing an > >> algorithm that accounts for noise, but am still not sure how to account > f= > >or > >> the noise. I know I can't use the noise mean because that should be > zero.= > > I > >> am pretty sure I should be using the variance but do not exactly > understa= > >nd > >> why. Can anyone explain to me the significance of the noise variance > as > >> opposed to the noise mean in a signal? Or can anyone direct me to > >> literature that discusses the processing of noise? Thanks. > > >> -jyproc > > >I'm not sure what exactly you are looking for. > >But let's try a simple example. Suppose there is > >a value A that you are looking to estimate based > >on a set of observations: > > > y_n =3D A + w_n, n =3D 0,1,...,N-1. > > >Let's now say that w_n are Gaussian noise terms > >with variance \sigma^2 and mean 0. > > >OK, so intuitively (and formally) the best estimate > >is given by: > > > \hat{A} =3D 1/N \sum_n y_n. > > >Then one way to assess the quality of your estimate > >is to look at the mean-square error: > > > E[ | \hat{A} - A |^2 ] > > >Now do some algebra and probability and you see > >how \sigma^2 effects this. > > >Does that help? > > >Julius > > Julius, > > I have a waveform obtained from the receiver that displays the amplitude > received. I want to detect the first instance that corresponds to an actual > received signal and not noise. Sorry for not being clearer earlier. That's > why the algorithm should process the noise and account for it...to reduce > the likelihood of detecting a noise signal as a received signal. Thanks for > the help.Well, start by describing your noise. Is it white? Gaussian? Zero- mean? This determines what estimator/detector works.
>On Jun 25, 8:30 am, "jyproc" <jyaqu...@gmail.com> wrote: >> >On Jun 24, 9:15=A0pm, "jyproc" <jyaqu...@gmail.com> wrote: >> >> Hi all, >> >> >> I am working on a project where I am trying to detect the directpath>> >> signal for ranging purposes using UWB technology. I am developingan>> >> algorithm that accounts for noise, but am still not sure how toaccount>> f= >> >or >> >> the noise. I know I can't use the noise mean because that should be >> zero.= >> > I >> >> am pretty sure I should be using the variance but do not exactly >> understa= >> >nd >> >> why. Can anyone explain to me the significance of the noisevariance>> as >> >> opposed to the noise mean in a signal? Or can anyone direct me to >> >> literature that discusses the processing of noise? Thanks. >> >> >> -jyproc >> >> >I'm not sure what exactly you are looking for. >> >But let's try a simple example. Suppose there is >> >a value A that you are looking to estimate based >> >on a set of observations: >> >> > y_n =3D A + w_n, n =3D 0,1,...,N-1. >> >> >Let's now say that w_n are Gaussian noise terms >> >with variance \sigma^2 and mean 0. >> >> >OK, so intuitively (and formally) the best estimate >> >is given by: >> >> > \hat{A} =3D 1/N \sum_n y_n. >> >> >Then one way to assess the quality of your estimate >> >is to look at the mean-square error: >> >> > E[ | \hat{A} - A |^2 ] >> >> >Now do some algebra and probability and you see >> >how \sigma^2 effects this. >> >> >Does that help? >> >> >Julius >> >> Julius, >> >> I have a waveform obtained from the receiver that displays theamplitude>> received. I want to detect the first instance that corresponds to anactual>> received signal and not noise. Sorry for not being clearer earlier.That's>> why the algorithm should process the noise and account for it...toreduce>> the likelihood of detecting a noise signal as a received signal. Thanksfor>> the help. > >Well, start by describing your noise. Is it white? Gaussian? Zero- >mean? >This determines what estimator/detector works. >I believe the noise is Additive White Gaussian Noise. -jyproc
On Jun 25, 1:03 pm, "jyproc" <jyaqu...@gmail.com> wrote:> I believe the noise is Additive White Gaussian Noise. > > -jyprocOK, when the signal s(t) is known and you want to detect it in the presence of AWGN, the optimal detector is a correlator (of the received signal versus s(-t)), followed by magnitude estimator and a threshold. To set the threshold properly depends on s(t) and the noise variance, since AWGN will appear at the output of the correlator also. Is this what you are looking for?
Reply by ●June 26, 20082008-06-26
> >Thanks for the help. >So if all I need is the mean amplitude of the noise, I could simply use > >average_noise_amplitude=the mean of the absolute value of all noise >samples. Right?No, Not right. mean_of_noise = mean(noise_samples); Regards Bharat Pathak Arithos Designs www.Arithos.com A Premier DSP Design Consultancy and Training Company.
