Dear all, I have developed a firmware application for my TMS320F28335 with the help of Code Composer Studio and the eZdspf28335. The application works (quite) well in debug mode, thus I want to finally program the flash on-chip memory in order to have the dsp working immediately after a reset without the need of the jtag interface and debug. Now I'm trying to understand how to program the flash memory and I find the SPRA8958G application report on "Running an Application from Internal Memory on the TMS320F28xxx DSP". I tried to use the sample projects found in the corresponding zip file but it doesn't work: when I program the DSP with the F28335_example_nonBIOS_ram, all work properly, but when I use the F28335_example_nonBIOS_flash program, I have the following error: "Target halted during Flash operation. Flash operation aborted." I have programmed the flash memory of the DSP using F28xxx On-Chip Flash Programmer that I find under Tool and I have correctly modified the SW1 switch on the eZdspf28335 in order to have a jump to flash in boot load option. Which would be the problem? Can anyone help me? Thank you, Polpet
TMS320F28335 Flash Programming
Started by ●June 25, 2008
Reply by ●June 25, 20082008-06-25
polpet wrote:> I have developed a firmware application for my TMS320F28335 with the help > of Code Composer Studio and the eZdspf28335. > > The application works (quite) well in debug mode, thus I want to finally > program the flash on-chip memory in order to have the dsp working > immediately after a reset without the need of the jtag interface and > debug. > > Now I'm trying to understand how to program the flash memory and I find > the SPRA8958G application report on "Running an Application from Internal > Memory on the TMS320F28xxx DSP". I tried to use the sample projects found > in the corresponding zip file but it doesn't work: when I program the DSP > with the F28335_example_nonBIOS_ram, all work properly, but when I use the > F28335_example_nonBIOS_flash program, I have the following error: "Target > halted during Flash operation. Flash operation aborted." > > I have programmed the flash memory of the DSP using F28xxx On-Chip Flash > Programmer that I find under Tool and I have correctly modified the SW1 > switch on the eZdspf28335 in order to have a jump to flash in boot load > option. > > Which would be the problem? > Can anyone help me?I can certainly read the manuals for you, but not here and not for free. VLV
Reply by ●June 26, 20082008-06-26
Can anyoune help me "for free". It's an university research project... I have not so much money!!! Thanks Polpet> > >polpet wrote: > > > >> I have developed a firmware application for my TMS320F28335 with thehelp>> of Code Composer Studio and the eZdspf28335. >> >> The application works (quite) well in debug mode, thus I want tofinally>> program the flash on-chip memory in order to have the dsp working >> immediately after a reset without the need of the jtag interface and >> debug. >> >> Now I'm trying to understand how to program the flash memory and Ifind>> the SPRA8958G application report on "Running an Application fromInternal>> Memory on the TMS320F28xxx DSP". I tried to use the sample projectsfound>> in the corresponding zip file but it doesn't work: when I program theDSP>> with the F28335_example_nonBIOS_ram, all work properly, but when I usethe>> F28335_example_nonBIOS_flash program, I have the following error:"Target>> halted during Flash operation. Flash operation aborted." >> >> I have programmed the flash memory of the DSP using F28xxx On-ChipFlash>> Programmer that I find under Tool and I have correctly modified theSW1>> switch on the eZdspf28335 in order to have a jump to flash in bootload>> option. >> >> Which would be the problem? >> Can anyone help me? > >I can certainly read the manuals for you, but not here and not for free. > > >VLV >
polpet wrote:> Can anyoune help me "for free". > > It's an university research project... I have not so much money!!! > > Thanks > > Polpet > >I went to http://www.google.com/search?sourceid=mozilla&q=diei.unipg.it [notice I used the Google server(s) located in USA] The first 10 hits seemed to have a number of people at your university that may be able to solve your problem or point you in the right direction. I don't speak Italian and was using Google's automatic translation facility. Good luck. [And don't take VLV too personally ;]
"polpet" <alessandro.polpetta@diei.unipg.it> wrote in message news:z9WdnQf-v-JsKP7VnZ2dnUVZ_qjinZ2d@giganews.com...> Can anyoune help me "for free". > > It's an university research project... I have not so much money!!! >Then get some money before going into the projects.> Thanks > PolpetAlways welcome. VLV> > > > > > >polpet wrote: > > > > > > > >> I have developed a firmware application for my TMS320F28335 with the > help > >> of Code Composer Studio and the eZdspf28335. > >> > >> The application works (quite) well in debug mode, thus I want to > finally > >> program the flash on-chip memory in order to have the dsp working > >> immediately after a reset without the need of the jtag interface and > >> debug. > >> > >> Now I'm trying to understand how to program the flash memory and I > find > >> the SPRA8958G application report on "Running an Application from > Internal > >> Memory on the TMS320F28xxx DSP". I tried to use the sample projects > found > >> in the corresponding zip file but it doesn't work: when I program the > DSP > >> with the F28335_example_nonBIOS_ram, all work properly, but when I use > the > >> F28335_example_nonBIOS_flash program, I have the following error: > "Target > >> halted during Flash operation. Flash operation aborted." > >> > >> I have programmed the flash memory of the DSP using F28xxx On-Chip > Flash > >> Programmer that I find under Tool and I have correctly modified the > SW1 > >> switch on the eZdspf28335 in order to have a jump to flash in boot > load > >> option. > >> > >> Which would be the problem? > >> Can anyone help me? > > > >I can certainly read the manuals for you, but not here and not for free. > > > > > >VLV > >
