I implemented the matlab simulation model according to hardware architecture.The impulse response is ok when the impulse length is short.But when I increase the length of impulse stimulus, I found increasing spurs. I don't know whether this is caused by the instability of the filter or some other reasons. Attached is the matlab code,and at the end of code I added the matlab internal function mfilt.cicdecim for comparison. %Filter Stimulus %data_in =sin((1:2^15)*pi/2^10); data_in =[1 zeros(1,4*6000-1)]; %Filter Parameters R= 4;%decimation factor M=1;%differential delay N=5;%cascaded numbers of section %Integrator Section Registers Initialization intg_reg1(1) = data_in(1); intg_reg1_d(1) =0; intg_reg2(1) = 0; intg_reg2_d(1) =0; intg_reg3(1) = 0; intg_reg3_d(1) =0; intg_reg4(1) = 0; intg_reg4_d(1) =0; intg_reg5(1) = 0; intg_reg5_d(1) =0; for i=2:length(data_in) intg_reg1_d(i) = intg_reg1(i-1); intg_reg1(i) = intg_reg1_d(i) + data_in(i); intg_reg2_d(i) = intg_reg2(i-1); intg_reg2(i) = intg_reg2_d(i) + intg_reg1_d(i); intg_reg3_d(i) = intg_reg3(i-1); intg_reg3(i) = intg_reg3_d(i) + intg_reg2_d(i); intg_reg4_d(i) = intg_reg4(i-1); intg_reg4(i) = intg_reg4_d(i) + intg_reg3_d(i); intg_reg5_d(i) = intg_reg5(i-1); intg_reg5(i) = intg_reg5_d(i) + intg_reg4_d(i); end % Decimation by R deci_data=intg_reg5_d(R:R:end); %Comb Section Registers Initialization diff_reg1(1) = deci_data(1); diff_reg1_d(1) = 0; diff_reg2(1) = 0; diff_reg2_d(1) =0; diff_reg3(1) = 0; diff_reg3_d(1) = 0; diff_reg4(1) = 0; diff_reg4_d(1) = 0; diff_reg5(1) = 0; diff_reg5_d(1) = 0; diff_reg6(1) = 0; for ii=2:length(deci_data) diff_reg1(ii) = deci_data(ii); diff_reg1_d(ii) = diff_reg1(ii-1); diff_reg2(ii) = diff_reg1(ii)-diff_reg1_d(ii); diff_reg2_d(ii) = diff_reg2(ii-1); diff_reg3(ii) = diff_reg2(ii)-diff_reg2_d(ii); diff_reg3_d(ii) = diff_reg3(ii-1); diff_reg4(ii) = diff_reg3(ii)-diff_reg3_d(ii); diff_reg4_d(ii) = diff_reg4(ii-1); diff_reg5(ii) = diff_reg4(ii)-diff_reg4_d(ii); diff_reg5_d(ii) = diff_reg5(ii-1); diff_reg6(ii) = diff_reg5(ii)-diff_reg5_d(ii); end data_out = diff_reg6; data_in =[1 zeros(1,4*10000-1)]; hm=mfilt.cicdecim(4,1,5); cic_ir=double(filter(hm,data_in));
5 Stages CIC Filter Matlab Simulation Problem
Started by ●June 26, 2008
Reply by ●June 27, 20082008-06-27
On Jun 27, 9:39�am, tonyjian...@hotmail.com wrote:> I implemented the matlab simulation model according to hardware > architecture.The impulse response is ok when the impulse length is > short.But when I increase the length of impulse stimulus, I found > increasing spurs. I don't know whether this is caused by the > instability of the filter or some other reasons. Attached is the > matlab code,and at the end of code I added the matlab internal > function mfilt.cicdecim for comparison. > > %Filter Stimulus > %data_in =sin((1:2^15)*pi/2^10); > data_in =[1 zeros(1,4*6000-1)]; > > %Filter Parameters > R= 4;%decimation factor > M=1;%differential delay > N=5;%cascaded numbers of section > > %Integrator Section Registers Initialization > intg_reg1(1) = data_in(1); > intg_reg1_d(1) =0; > intg_reg2(1) = 0; > intg_reg2_d(1) =0; > intg_reg3(1) = 0; > intg_reg3_d(1) =0; > intg_reg4(1) = 0; > intg_reg4_d(1) =0; > intg_reg5(1) = 0; > intg_reg5_d(1) =0; > > for i=2:length(data_in) > > � � intg_reg1_d(i) = intg_reg1(i-1); > � � intg_reg1(i) = intg_reg1_d(i) + data_in(i); > > � � intg_reg2_d(i) = intg_reg2(i-1); > � � intg_reg2(i) = intg_reg2_d(i) + intg_reg1_d(i); > > � � intg_reg3_d(i) = intg_reg3(i-1); > � � intg_reg3(i) = intg_reg3_d(i) + intg_reg2_d(i); > > � � intg_reg4_d(i) = intg_reg4(i-1); > � � intg_reg4(i) = intg_reg4_d(i) + intg_reg3_d(i); > > � � intg_reg5_d(i) = intg_reg5(i-1); > � � intg_reg5(i) = intg_reg5_d(i) + intg_reg4_d(i); > > end > > % Decimation by R > > deci_data=intg_reg5_d(R:R:end); > > %Comb Section Registers Initialization > diff_reg1(1) = deci_data(1); > diff_reg1_d(1) = 0; > diff_reg2(1) = 0; > diff_reg2_d(1) =0; > diff_reg3(1) = 0; > diff_reg3_d(1) = 0; > diff_reg4(1) = 0; > diff_reg4_d(1) = 0; > diff_reg5(1) = 0; > diff_reg5_d(1) = 0; > diff_reg6(1) = 0; > > for ii=2:length(deci_data) > > � � diff_reg1(ii) = deci_data(ii); > � � diff_reg1_d(ii) = diff_reg1(ii-1); > > � � diff_reg2(ii) = diff_reg1(ii)-diff_reg1_d(ii); > � � diff_reg2_d(ii) = diff_reg2(ii-1); > > � � diff_reg3(ii) = diff_reg2(ii)-diff_reg2_d(ii); > � � diff_reg3_d(ii) = diff_reg3(ii-1); > > � � diff_reg4(ii) = diff_reg3(ii)-diff_reg3_d(ii); > � � diff_reg4_d(ii) = diff_reg4(ii-1); > > � � diff_reg5(ii) = diff_reg4(ii)-diff_reg4_d(ii); > � � diff_reg5_d(ii) = diff_reg5(ii-1); > > � � diff_reg6(ii) = diff_reg5(ii)-diff_reg5_d(ii); > end > data_out = diff_reg6; > > data_in =[1 zeros(1,4*10000-1)]; > > hm=mfilt.cicdecim(4,1,5); > cic_ir=double(filter(hm,data_in));I got it! In fact double type in matlab is represented with 54(including 1 sign bit) ,so the so-call floating point simulation is fixed-point theoritically. Thus overflow is inevitable with the increase of integration length."Wrap-around" is needed according to Hogenauer's paper in order to avoid overflow error.
