Hi, On "Adaptive filter theory" by Simon Haykin, it gave the multiple linear regression model as: d(n) = A^H Um(n)+v(n) A and U are vectors. I don't understand the reason for this model why it put noise v(n) just before the desired signal d(n). For normal FIR filtering, the noise is just before the filter input. This multiple linear regression model is not the same for the filter practice. Furthmore, after the introduction of this model, it applied it to the Wiener filtering, which is not consider the noise component before the introduction of multiple linear regression model. I think the abstract model may be different from the practice, but it should not be diverse far away fundamentally. In the digital communication system simulation, noise is always added at the filter input. Can you explain it to me? Thanks in advance
Question about multiple linear regression model in adaptive filer
Started by ●June 28, 2008
Reply by ●June 28, 20082008-06-28
On 28 Jun, 17:44, fl <rxjw...@gmail.com> wrote:> Hi, > On "Adaptive filter theory" by Simon Haykin, it gave the multiple > linear regression model as: > > d(n) = A^H Um(n)+v(n) > > A and U are vectors. > > I don't understand the reason for this model why it put noise v(n) > just before the desired signal d(n). For normal FIR filtering, the > noise is just before the filter input. This multiple linear regression > model is not the same for the �filter practice.That's because you are dealing with and *adaptive* filter. One needs a random component internal to the filter in order to get it to adapt to changes in the input. Rune
Reply by ●June 29, 20082008-06-29
On 28 Jun, 18:16, Rune Allnor <all...@tele.ntnu.no> wrote:> On 28 Jun, 17:44, fl <rxjw...@gmail.com> wrote: > > > Hi, > > On "Adaptive filter theory" by Simon Haykin, it gave the multiple > > linear regression model as: > > > d(n) = A^H Um(n)+v(n) > > > A and U are vectors. > > > I don't understand the reason for this model why it put noise v(n) > > just before the desired signal d(n). For normal FIR filtering, the > > noise is just before the filter input. This multiple linear regression > > model is not the same for the �filter practice. > > That's because you are dealing with and *adaptive* filter. > One needs a random component internal to the filter in > order to get it to adapt to changes in the input.I was a bit absent-minded yesterday. The above is true for the Kalman filter. In your case, the noise term v(n) might also be an adaption error. Rune
