what error control coding do CD, VCD, DVD, MD, etc. use?
Started by walala ●April 9, 2004
"Dilip V. Sarwate" <sarwate@YouEyeYouSee.edu> writes:
> "Randy Yates" <yates@ieee.org> wrote in message > news:r7uw7l72.fsf@ieee.org... > > CD contains a cross-interleaved extended (32,28) Reed-Solomon code. > > This is not quite correct. Cross-interleaving is indeed used in CDs, but > the > (32, 28) Reed-Solomon code is not over GF(2^5) = GF(32), and thus is > not an extended Reed-Solomon code in the usual sense of the word (add > an overall parity check symbol to a code of length one less than the size of > the field). The (32, 28) Reed-Solomon code used in CDs is over GF(2^8) > and can be thought of as a shortened version of a (255, 251) Reed-Solomon > code. In fact, TWO Reed-Solomon codes are used in CDs; a (32, 28) code > and a (28, 24) code; and both have 8-bit symbols. Extensive details can be > found in Chapter 4 of the book "Reed-Solomon Codes and Their Applications" > (S. B. Wicker and V. K. Bhargava, eds.) IEEE Press, 1994.
Interesting! Thanks for the correction and reference, Dilip. -- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
