Jerry Avins wrote:> Given the type of artifacts that he described, I guessed that the OP's are.Well, maybe he is misusing the LFSR, even if it is not clear to me if the artifacts are measured before or after the codec. Because if they're after, I could imagine the codec has something to do with it. bye, -- piergiorgio
white noise generation
Started by ●July 3, 2008
Reply by ●July 4, 20082008-07-04
"esfield" <ethanstubblefield@hotmail.com> wrote in message news:QvWdnVZr1ahas_DVnZ2dnUVZ_tXinZ2d@giganews.com...> Hello, newbie here in need of some help: > > I'm trying to generate white noise. I found a paper online > called > "Xorshift RNG's" by George Marsaglia, and found it attractive > because of > its simplicity, and its also supposed to generate very good > random numbers > that have long periods, pass the diehard randomness tests, > etc.First of all, the Xorshift PRNG is not an LFSR, but it has been proven that for every Xorshift PRNG there is an LFSR that will generate exactly the same sequence of pseudo-random numbers. Both families generate uniformly-distributed pseudo-random numbers (they must) and both can be modelled using the Berlekamp-Massey algorithm. http://en.wikipedia.org/wiki/Berlekamp-Massey_algorithm Because of this, they are not suitable for cryptography, though they may be very well suited for modeling and simulation and other DSP applications where security is not an issue. Either an LFSR or an Xorshift PRNG, with suitable choice of parameters, will generate every possible bit pattern in a group of bits exactly once before repeating the sequence. Thus, uniform distribution is the only possibility. However, when you subset the parallel output of the Xorshift PRNG, you should expect to see repetitions in the sequence of numbers that you would not see if you were considering the whole parallel word. If this is a problem, there are two alternative solutions. First, you can cook up a set of parameters for that generate an Xorshift PRNG with the desired word length, in your case 24 bits. Second, you can create the equivalent LFSR and assemble the serial output into 24-bit words. (Do not, however, take the shift register state as your random number--it's not.) There is another solution, one that might serve you better. T. G. Lewis and W. H. Payne published a paper called "Generalized Feedback Shift Register Pseudorandom Number Algorithm", Journal of the ACM, Vol. 20, No. 3, July, 1973, pp 456-468. In essence, they choose a polynomial for a long-period LFSR, and run the same polynomial on N bits in parallel. The trick is that they initialize the N parallel shift registers to different pseudo-random values. Then they cycle the LFSRs many times to insure that they are properly initialized. Below is the C code that actually computes the parallel pseudo-random numbers from the L&P GFSR (after initialization). As you can see, it's likely to be as fast as any Xorshift PRNG, and decidedly faster than assembling bits from a single serial LFSR. In the code below, each element of m[] holds the memory of up to 32 parallel shift registers of length P. Q represents the position (and exponent) of a single tap. If you want the complete C source code, send a request to my e-mail address. It's free and available under LGPL. /***************************************************\ ** ** ** YEARS* P Q ** ** ------ --- --- ** ** 10^17 124 37 ** ** 10^31 170 23 ** ** 10^55 250 103 ** ** 10^94 380 47 ** ** 10^140 532 37 ** ** ** ** * YEARS TO REPEAT CYCLE ASSUMING 1 WORD PER ** ** PICOSECOND (10^12 WORDS PER SECOND) -- ** ** CURRENT (2002) TECHNOLOGY CAN'T QUITE ** ** YIELD 10^9 WORDS PER SECOND USING THIS ** ** ALGORITHM. ** ** ** ** According to Lewis and Payne, avoid designs ** ** where Q is close to zero or close to (P-1)/2. ** ** By these criteria, P=124, Q=37 appears to be ** ** the best design. ** ** ** \***************************************************/ #define P 124 /* Polynomial Order */ #define Q 37 /* Polynomial Tap */ unsigned long RandLP_int(unsigned long m[], int *j) { int k; *j += 1; if (*j >= P) *j = 0; k = (*j + Q); if (k >= P) k = k - P; return (m[*j] ^= m[k]); } By the way, if you want to know how bad every Linear Congruential Generator is, implement one (any one), generate a few "random numbers", and look at the low-order bit of each word in your sequence. Then, after you're done throwing-up, look at the bit next to it. One or two such observations are likely to cure any illusions you might have about pseudo-random numbers generated by LCGs.
John E. Hadstate wrote: ...> Either an LFSR or an Xorshift PRNG, with suitable choice of parameters, > will generate every possible bit pattern in a group of bits exactly once > before repeating the sequence. Thus, uniform distribution is the only > possibility.That's true, but possibly misleading. All zeros (all ones in some implementations) is not a possible bit pattern, so there is a small bias that can be made evident by integration. ... Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●July 6, 20082008-07-06
"Jerry Avins" <jya@ieee.org> wrote in message news:p_udnbalrN_LWvPVnZ2dnUVZ_qHinZ2d@rcn.net...> John E. Hadstate wrote: > > ... > >> Either an LFSR or an Xorshift PRNG, with suitable choice of >> parameters, will generate every possible bit pattern in a >> group of bits exactly once before repeating the sequence. >> Thus, uniform distribution is the only possibility. > > That's true, but possibly misleading. All zeros (all ones in > some implementations) is not a possible bit pattern, so there > is a small bias that can be made evident by integration.The usable output of the LFSR is a single bit per clock (not the whole shift register). A maximal-length N-bit LFSR will generate ((2**N)-1) bits before the sequence repeats. Since 2**N-1 is an odd number, there must always be more zeroes than ones or vice versa in the output, producing the small bias to which you referred. On the assumption that consecutive bits are uncorrelated, there is an algorithm called the "Von Neumann Corrector" that will remove this bias at the expense of discarding some of the original bits. (This algorithm can also be applied to hardware sources of random numbers, like radioactive decay, which, for one reason or another, may exhibit bias.) The Von Neumann Corrector algorithm works on pairs of consecutive bits, and produces output as follows: 1.. If the input is "00" or "11", the input is discarded (no output). 2.. If the input is "10", output a "1". 3.. If the input is "01", output a "0". Further information is available at http://everything2.com/index.pl?node_id=1467753 and http://www.helsbreth.org/random/removing_bias.html
