Generating non-Gaussian signal
Started by DigitalSignal July 6, 2008
In article
<1136d214-a420-4ef7-a1db-ed10303a1651@27g2000hsf.googlegroups.com>,
 DigitalSignal <digitalsignal999@yahoo.com> wrote:
> It is a general question. We make dynamic signal analyzers. In a > signal analyzer, the typical waveform signa sources include sine, > white noise, swept sine, saw tooth, square etc.. The white noise is > always Gaussian type (with Kuotosis 3). This signal is usually > generated by summing up a few uniformly distributed random numbers. In > order to simulate what is happenning in the physical world, some users > ask for a random signal of which the Kuotosis is larger than 3. We > don't have a easy way to generate such as signal. > > James > www.go-ci.com
there are other ways, one of which is completely general, to get a normal variate from a uniform distribution. more importantly, if you need to generate some non-gaussian variate, you need to know the general transformation. you could look in "numerical recipes". for a normal (i.e. gaussian) distribution, the (moment coefficient of) kurtosis is always 3, independent of mean and variance. your title &#4294967295; non-gaussian &#4294967295; suggests that you know this. about all that comes to mind is: look at families of distributions, say the Pearson's, to see if something has a plausible kurtosis and shape. once you have the probability distribution, you can apply the general method of generating variates from a uniform distribution. vale, rip -- NB eddress is r i p 1 AT c o m c a s t DOT n e t
On 10 Jul., 22:21, DigitalSignal <digitalsignal...@yahoo.com> wrote:
> It is a general question. We make dynamic signal analyzers. In a > signal analyzer, the typical waveform signa sources include sine, > white noise, swept sine, saw tooth, square etc.. The white noise is > always Gaussian type (with Kuotosis 3). This signal is usually > generated by summing up a few uniformly distributed random numbers. In > order to simulate what is happenning in the physical world, some users > ask for a random signal of which the Kuotosis is larger than 3. We > don't have a easy way to generate such as signal. > > Jameswww.go-ci.com
You could sample values according the following distribution: http://en.wikipedia.org/wiki/Pearson_distribution#The_Pearson_type_VII_distribution In this description the parameter m is connected to the kurtosis, and if m->infty you get a normal-distribution. One method to sample values to an arbitrariy distribtution f(x) is: http://en.wikipedia.org/wiki/Rejection_sampling Greetings, Uwe
On 12 Jul., 12:03, Uwe Schmitt <rocksportroc...@googlemail.com> wrote:
> On 10 Jul., 22:21, DigitalSignal <digitalsignal...@yahoo.com> wrote: > > > It is a general question. We make dynamic signal analyzers. In a > > signal analyzer, the typical waveform signa sources include sine, > > white noise, swept sine, saw tooth, square etc.. The white noise is > > always Gaussian type (with Kuotosis 3). This signal is usually > > generated by summing up a few uniformly distributed random numbers. In > > order to simulate what is happenning in the physical world, some users > > ask for a random signal of which the Kuotosis is larger than 3. We > > don't have a easy way to generate such as signal. > > > Jameswww.go-ci.com > > You could sample values according the following distribution: > > &#4294967295; &#4294967295;http://en.wikipedia.org/wiki/Pearson_distribution#The_Pearson_type_VI... > > In this description the parameter m is connected to the kurtosis, and > if m->infty > you get a normal-distribution. > > One method to sample values to an arbitrariy distribtution f(x) is: > > &#4294967295; &#4294967295; &#4294967295;http://en.wikipedia.org/wiki/Rejection_sampling >
Look at GNU Scientific Library (GSL) which has lots of random generators. Greetings, Uwe
Thank you all for the insights and comments. They are really helpful.
Let me go further for this question:
How to generate a random process of which both its PSD (Power Spectral
Density) and Kurtosis can be controlled? A traditional method is that
to apply a uniformed randomized phase to the defined PSD and conduct
inverse FFT to create the time signal. Unfortunately this method
always create Gaussian distributed time signal.
James
www.go-ci.com
On Jul 12, 8:18 am, DigitalSignal <digitalsignal...@yahoo.com> wrote:
> Thank you all for the insights and comments. They are really helpful. > Let me go further for this question:
> How to generate a random process of which both its PSD (Power Spectral > Density) and Kurtosis can be controlled? A traditional method is that > to apply a uniformed randomized phase to the defined PSD and conduct > inverse FFT to create the time signal. Unfortunately this method > always create Gaussian distributed time signal. > > Jameswww.go-ci.com
You could try: http://www.engineers.auckland.ac.nz/~aste127/Jies97.pdf Of course, to find this you would have had to Google on controlled kurtosis. Dale B. Dalrymple
Thank you again. I met with the author a while back and we had an
argument. He uses multiple sine tones to create a random-look
deterministic signal of which the Kurtosis is controlled. I said it is
not a real random signal...
But his approach is certainly one worth considering...
James
www.go-ci.com
DigitalSignal wrote:
> Thank you again. I met with the author a while back and we had an > argument. He uses multiple sine tones to create a random-look > deterministic signal of which the Kurtosis is controlled. I said it is > not a real random signal... > But his approach is certainly one worth considering... > > James > www.go-ci.com
No sequence that can be reproduced without being copied is truly random. What did you mean? Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
