>(snip) > >My Master's Thesis has an ancient, student-written, all-assembly >algorithm for MSK in it. But there's a block diagram that applies. You>may be interested in taking a look: >http://www.wescottdesign.com/articles/MSK/mskTop.html. > >The hardware way to do this would have been to lock on to the suppressed>carrier using a square-and-PLL or a Costas loop, then extract the data >clock with another PLL, then use the PLL outputs to drive a demodulate, >integrate and dump. > >A more "DSPish" thing to do would probably be to bring your signal in, >multiply it by a 10kHz sine wave and it's quadrature (so, sine and >cosine), integrate each channel with a 200 microsecond long boxcar >filter, and look for phase changes. You'll still need to extract the >data clock. > >In an AVR, you may want to come closer to the 'hardwareish' thing: run >the whole thing as a Costas loop or as a signal-square-and-PLL, and do >integrate-and-dump. This will allow you to reduce the number of signals>running around, and the integrate-and-dump will reduce the computational>load and storage requirement over an alway-updating FIR. > >-- > >Tim Wescott >Wescott Design Services >http://www.wescottdesign.com > >Do you need to implement control loops in software? >"Applied Control Theory for Embedded Systems" gives you just what itsays.>See details at http://www.wescottdesign.com/actfes/actfes.html >Thanks for taking the time to reply Tim. I used the 6800 device back in the 1970s. Your code was easy to follow. Would be nice to examine it in .txt or .asm text document format. As far as your apology for the "spaghetti code" style, I remember instructing my students on the two unforgivable sins of coding for others to view: 1) Excesive Cryptic defines scattered over multiple source files that only have meaning to the original author. 2) Unnecessary & unstructured module crafting. (spaghetti code patially fits fits here?) Time critical requirements can cancel out rule #2 within reasonable limits.> >You may also be able to reduce clock cycles by 'multiplying' by a 10kHz >square wave -- whether you need to do this depends on the cost of a >multiply in your AVR. I know that the demodulator in my thesis radio >worked on 400 baud data being sampled at 6800Hz or so, and it was with a>processor (68HC11) that's more than 10 times less capable than an AVR >running at full speed.I'm running an AVR with 20mhz capability and HW MUL in the core. Not bad for a $2.00 part. If I read your code correctly, you are using 8bits A/D? The SAR in the AVR can generally perform a convertion in ~13 clock cycles (~25 cycles for the first sample-read). I noticed you used 15 samples per cycle scan. My signal has relatively low noise. Could I get away fewer samples with sacrificing end results? I ask this only out of curiosity. Far be it from me to question your design motives! The ADC can be programmed to perform an ISR after each convertion, but this timing is dependent on the ADC pre-scaler and probably no where near the input sample needs? I'll probably use your concept where the ADC is read during a scheduled TMOVF isr and start a new conversion within the scope of this module. If anything I've assumed here is incorrect Tim, please let me know. I have no ego to bruise when someone with your talent is trying to help. I'll give it a go. Thanks for the useful link and pointers Tim. B.R. Jack
10khz DBSK decoder
Started by ●July 13, 2008
Reply by ●July 14, 20082008-07-14
On Mon, 14 Jul 2008 06:04:51 -0500, "ijt" <ijackt@sbcglobal.net> wrote:>>It's a USENET group, ergo it has flame wars. It gets aliased from at >>least one web site (DSPrelated), but it's still USENET. >> >>So, do the USENET thing: stay above 'em or dive in. Just don't expect >>them to go away. >> > >Point well taken Tim. Uhm...On this one, I'll try to stay above 'em. >Whether he goes away from this or not depends on his charater?Hmmm...you said you'll stay above 'em and then in the next sentence make unfavorable implications about the individual. FWIW, he's been posting here for a while, and while his style can be a bit abrasive I've found his technical input to be highly competent and generally reliable. I he left I'd consider it a substantial loss to the newsgroup. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
>On Mon, 14 Jul 2008 06:04:51 -0500, "ijt" <ijackt@sbcglobal.net> >wrote: > >>>It's a USENET group, ergo it has flame wars. It gets aliased from at >>>least one web site (DSPrelated), but it's still USENET. >>> >>>So, do the USENET thing: stay above 'em or dive in. Just don't expect>>>them to go away. >>> >> >>Point well taken Tim. Uhm...On this one, I'll try to stay above 'em. >>Whether he goes away from this or not depends on his charater? > >Hmmm...you said you'll stay above 'em and then in the next sentence >make unfavorable implications about the individual. > >FWIW, he's been posting here for a while, and while his style can be a >bit abrasive I've found his technical input to be highly competent and >generally reliable. I he left I'd consider it a substantial loss to >the newsgroup. > >Eric Jacobsen >Minister of Algorithms >Abineau Communications >http://www.ericjacobsen.org > >Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php >Eric, He is fortunate to have such favorable attitudes from his peers. I probably should not reply to this. But for HIS sake, and to show my hind-quaters are not made of cobalt, please let me clarify.>If he left I'd consider it a substantial loss to >the newsgroup.Agree totally! Re-read my initial post. "His code sample worked PERFECT". I did a lot of research to find a highly skilled individual to help with my problem. From my googling, HE is probably as good as it gets w/DSP!!! It has been over 2000 years since any human knew every detail about ever subject. If he was an expert in every field, he could have cautioned me using C# and the special steps would have to be taken to use his code, or at least written the code in C# (which I first asked for). Just because the worlds finest Geologist can answer 99.999... percent of questions regarding formations does not qualify him as the best choice for space travel to other planets. This takes nothing away from an individuals gifts and talents, but most of all, there hard work to become a specific area expert. Next point. I stand by statement. It never entered my mind to be offensive or inflamitory, just an accurate reply to an earlier post. Sorry you took it as a challenge. In retrospect, the "Uhm...On this one, I'll try to stay above 'em." was probably improper. The second part was very pertinent to the post reply. Last point. He should have never replied, as none would have known the source. I only mentioned the incident to display my frustration. Even the best of us get in over our head. In this area, I'm sure he has a good track record. Wow, this getting too personal. I hope you view this in another way Eric. Let's stay technical and not let this become an unnecessary tragedy (almost silly?). Jack
ijt wrote:>> (snip) >> >> My Master's Thesis has an ancient, student-written, all-assembly >> algorithm for MSK in it. But there's a block diagram that applies. You > >> may be interested in taking a look: >> http://www.wescottdesign.com/articles/MSK/mskTop.html. >> >> The hardware way to do this would have been to lock on to the suppressed > >> carrier using a square-and-PLL or a Costas loop, then extract the data >> clock with another PLL, then use the PLL outputs to drive a demodulate, >> integrate and dump. >> >> A more "DSPish" thing to do would probably be to bring your signal in, >> multiply it by a 10kHz sine wave and it's quadrature (so, sine and >> cosine), integrate each channel with a 200 microsecond long boxcar >> filter, and look for phase changes. You'll still need to extract the >> data clock. >> >> In an AVR, you may want to come closer to the 'hardwareish' thing: run >> the whole thing as a Costas loop or as a signal-square-and-PLL, and do >> integrate-and-dump. This will allow you to reduce the number of signals > >> running around, and the integrate-and-dump will reduce the computational > >> load and storage requirement over an alway-updating FIR. >> >> -- >> >> Tim Wescott >> Wescott Design Services >> http://www.wescottdesign.com >> >> Do you need to implement control loops in software? >> "Applied Control Theory for Embedded Systems" gives you just what it > says. >> See details at http://www.wescottdesign.com/actfes/actfes.html >> > > Thanks for taking the time to reply Tim. I used the 6800 device back in > the 1970s. Your code was easy to follow. Would be nice to examine it in > .txt or .asm text document format. As far as your apology for the > "spaghetti code" style, I remember instructing my students on the two > unforgivable sins of coding for others to view: > > 1) Excesive Cryptic defines scattered over multiple source files that only > have meaning to the original author. > 2) Unnecessary & unstructured module crafting. (spaghetti code patially > fits fits here?) > > Time critical requirements can cancel out rule #2 within reasonable > limits.The part that is really unacceptable for production code is the bloated ISR and the non-existent main loop. I mean, that ISR is _designed_ to interrupt itself. In retrospect, the ISR should have just taken ADC samples and shoved them into a queue, then set a flag. Then the main loop should have spent (nearly all) of it's time chewing through the queue. But I had never seen that design pattern, so it just ran with that big bloated ISR...>> You may also be able to reduce clock cycles by 'multiplying' by a 10kHz >> square wave -- whether you need to do this depends on the cost of a >> multiply in your AVR. I know that the demodulator in my thesis radio >> worked on 400 baud data being sampled at 6800Hz or so, and it was with a > >> processor (68HC11) that's more than 10 times less capable than an AVR >> running at full speed. > > I'm running an AVR with 20mhz capability and HW MUL in the core. Not bad > for a $2.00 part. If I read your code correctly, you are using 8bits A/D? > The SAR in the AVR can generally perform a convertion in ~13 clock cycles > (~25 cycles for the first sample-read). > > I noticed you used 15 samples per cycle scan. My signal has relatively low > noise. Could I get away fewer samples with sacrificing end results? I ask > this only out of curiosity. Far be it from me to question your design > motives!Oh, question away. For one thing, I'm not perfect. For another, that design is just about 20 years old by now. While I was astonishingly capable for a Master's candidate (at least my thesis adviser claims to have been astonished that the radio worked) I was still a zit-faced kid doing his very first DSP project, and without a lot of formal DSP background. That sample rate was 'designed' by trying the algorithm out, then throwing out functionality and reducing the sample rate until the thing actually ran in the time available. Once my processor usage was below unity (98% is the number that I recall) I stopped trimming meat from the algorithm (the fat was long gone) and I thanked the DSP gods that I wasn't trimming bone. To capture a good portion of the bandwidth of your signal you probably want to sample at 40kHz. If you're not shaping the pulses BPSK has a very broad spread, so a somewhat bone-headed reading of theory would put your sampling rate much higher. But you're already 'aliasing' it by riding it on a carrier that's only 2x the baud rate, so you probably won't lose too much at 40kHz (note that I'm not doing any math here, I could be completely cracked). If your SNR is particularly good you could perhaps get away with something as low as 15kHz sampling, but I'd have to crank on the math to promise that you'd be able to synchronize to your signal at that low rate.> The ADC can be programmed to perform an ISR after each convertion, but > this timing is dependent on the ADC pre-scaler and probably no where near > the input sample needs? I'll probably use your concept where the ADC is > read during a scheduled TMOVF isr and start a new conversion within the > scope of this module.You'll get more consistent timing if you can trigger your ADC from hardware and interrupt on the end of conversion pulse. If you have the freedom to set the ADC to an arbitrary rate this is the way to go. Most of the modern chips that I have worked with let you trigger the ADC off of a timer, which in turn you can set to pretty much whatever you want. Were I doing this, and if the timer hardware allowed it, I would consider driving the timer rate from my carrier recovery PLL, to synchronize the ADC samples to my carrier. This _really_ simplifies the processing software, at the expense of making the overall application a bit more arcane.> If anything I've assumed here is incorrect Tim, please let me know. I have > no ego to bruise when someone with your talent is trying to help. > > I'll give it a go. Thanks for the useful link and pointers Tim. > B.R. > Jack >-- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" gives you just what it says. See details at http://www.wescottdesign.com/actfes/actfes.html
