Hi Friends, I have implemented a basic LPC coder in matlab using the following blocks. Kindly let me know your comments on some of my questions detailed down. I have taken sample .wav file with sampling frequency -8000 frame length =20 ms = 160 samples Overlap = 50% Block length = 240 sampels Overlapping samples of size 240 is copied from the input speech file. I windowed the samples with a hamming window.In order to cancel the effect of one pole in the glottal response, i pre-emphasised the signal. The LPC filter coefficnets Ak are found out and this is inverse filtered to get he residue. Pitch and voicing decision and gain is found out from auto correlation coefficients using zero crossing. This information is used to decode the signal by synthesizing the source signal. Overlap and added the prev samples and then de-empasised the signal to get the synthesized output. I would like to know 1. Voice/Unvoice Decision using speech samples What is the threshold for zero crossing rate of the speech signals for fs =8000 with block length 240 so that i can safely assume that anything below that can be flagged as voiced frame? 2. Pitch Detection using auto correlation coefficients. I took the auto corr coefficients from middle, search for zero crossing of the auto corr coefficient after 24 samples. Then searched for the the maximum peak after the zero crossing of auto corr coefficients. The index of this second max peak is taken as the pitch if the energy of the same is greater than 0.30 times the R(0). Is this can be reliabilty used for pitch detection? 3. How do i get the the SNR and MOS of my basic LPC codec. Is there any help available in matlab for the same. Regards, Sooraj.
Basic LPC Codec implemetation
Started by ●July 14, 2008
Reply by ●July 14, 20082008-07-14
On Jul 14, 8:54�am, "sooridas" <soori...@gmail.com> wrote:> Hi Friends, > � � � � � � I have implemented a basic LPC coder in matlab using the > following blocks. Kindly let me know your comments on some of my questions > detailed down. > > I have taken sample .wav file with > sampling frequency -8000 > frame length =20 ms = 160 samples > Overlap = 50% > Block �length � = 240 sampels > > Overlapping samples of size 240 is copied from the input speech file. I > windowed the samples with a hamming window.In order to cancel the effect of > one pole in the glottal �response, i pre-emphasised the signal. The LPC > filter coefficnets Ak are found out and this is inverse filtered to get he > residue. Pitch and voicing decision and gain is found out from auto > correlation coefficients using zero crossing. This information is used to > decode the signal by synthesizing the source signal. Overlap and added the > prev samples and then de-empasised the signal to get the synthesized > output. > > I would like to know > > 1. Voice/Unvoice Decision using speech samples > �What is the threshold for zero crossing rate of the speech signals for fs > =8000 with block length 240 so that i can safely assume that anything below > that can be flagged as voiced frame? > > 2. Pitch Detection using auto correlation coefficients. > > I took the auto corr coefficients from middle, search for zero crossing of > the auto corr coefficient after 24 samples. Then searched for the �the > maximum peak after the zero crossing of auto corr coefficients. The index > of this second max peak is � taken as the pitch if the energy of the �same > is greater than 0.30 times the R(0). > Is this can be reliabilty used for pitch detection? > > 3. How do i get the the SNR and MOS of my basic LPC �codec. Is there any > help available in matlab for the same. > > Regards, > Sooraj.What kind of LPC are trying to implement? What is the exitation? What is the bit rate? Does calculating SNR make any sense for the version you are implementing, i.e. is there any effort to duplicate waveforms rather than the way it sounds? Dirk
sooridas wrote:> 1. Voice/Unvoice Decision using speech samples > What is the threshold for zero crossing rate of the speech signals for fs > =8000 with block length 240 so that i can safely assume that anything below > that can be flagged as voiced frame?The Voice/Unvoice distinction is very relative and rather artificial.> > 2. Pitch Detection using auto correlation coefficients. > > I took the auto corr coefficients from middle, search for zero crossing of > the auto corr coefficient after 24 samples. Then searched for the the > maximum peak after the zero crossing of auto corr coefficients. The index > of this second max peak is taken as the pitch if the energy of the same > is greater than 0.30 times the R(0). > Is this can be reliabilty used for pitch detection?No, it can not. Care should be taken about the pitch multiplication problem.> 3. How do i get the the SNR and MOS of my basic LPC codec. Is there any > help available in matlab for the same.The SNR doesn't make sense since your LPC is not a waveform coder. The MOS figure can be estimated numerically according to ITU-T P 8xx specifications. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Jul 15, 12:07�am, Vladimir Vassilevsky <antispam_bo...@hotmail.com> wrote:> sooridas wrote: > > 1. Voice/Unvoice Decision using speech samples > > �What is the threshold for zero crossing rate of the speech signals for fs > > =8000 with block length 240 so that i can safely assume that anything below > > that can be flagged as voiced frame? > > The Voice/Unvoice distinction is very relative and rather artificial. > > > > > 2. Pitch Detection using auto correlation coefficients. > > > I took the auto corr coefficients from middle, search for zero crossing of > > the auto corr coefficient after 24 samples. Then searched for the �the > > maximum peak after the zero crossing of auto corr coefficients. The index > > of this second max peak is � taken as the pitch if the energy of the �same > > is greater than 0.30 times the R(0). > > Is this can be reliabilty used for pitch detection? > > No, it can not. Care should be taken about the pitch multiplication problem. > > > 3. How do i get the the SNR and MOS of my basic LPC �codec. Is there any > > help available in matlab for the same. > > The SNR doesn't make sense since your LPC is not a waveform coder. The > MOS figure can be estimated numerically according to ITU-T P 8xx > specifications.I really don't trust opinionated maths. :-) Steve
