Kalman Filter for Speech Denoising
Started by jylee8 3 years ago2 replieslatest reply 3 years ago194 views
Hi, I have been trying to denoise a speech signal using Kalman Filter. I have use the following code for my calculation. May I know if I am in the right direction? Many literature that I have read uses a state space model for the Kalman Filter? How can I do that for a corrupted speech signal? System Identification?
Thanks.
def my_calculation(y_corrupt):
  sum1 = 0
  square1 = 0
  mean1 = 0
  E_estimated = 0.00001
  E_measured = 0.00001
  noise_model= np.zeros((len(y_corrupt)))
  y_filtered = np.zeros((len(y_corrupt)))
  N = len(y_corrupt)
  for i in range (2,N):
    KG = E_estimated/(E_estimated+E_measured)
    #KG = KG**2
    noise_model[i] = noise_model[i-1] + KG*(y_corrupt[i]-noise_model[i-1])
    E_estimated= (1-KG)*E_measured;
    #E_estimated= (1-KG)*E_estimated;
    square1 = square1 + noise_model[i]**2
    sum1 = sum1 + noise_model[i]
    mean1 = (mean1*(i-1)+noise_model[i])/i
    E_measured = square1/i - mean1**2
    y_filtered[i] = y_corrupt[i] - noise_model[i]
  return y_filtered
Reply by diegofriasMay 29, 2021
I suggest you see the notebook https://github.com/strongio/torch-kalman for a general application. You can customize it for your data.
Reply by omersayliMay 29, 2021
