Multimedia Processing with FFMPEG
There are lot of color spaces available like RGB, CMYK, HSV, YUV, CIELAB etc., The one that is widely used for video processing is YUV color space. YUV was invented when engineers wanted color television in a black and white infrastructure. They needed a signal transmission method that was compatible with black-and-white TV being able to add color. The luma component already existed as the black-and-white signal, they added the UV signal to this as a solution. More details here.
Inputs to the Image and Video Processing will be generally YUV files. Input video will be usually in YUV 4:2:0 chroma subsampled format. More details here.
Sample YUV sequences, YUV player for Linux and YUV player for Windows are available in the following links respectively
http://trace.eas.asu.edu/yuv/
http://www.avarexgroup.com/downloads/yuvplayer_linux_v09.zip
http://www.avarexgroup.com/downloads/yuvplayer_win_v09.zip
Video Processing with FFMPEG
The below command resizes the input YUV video of resolution 1920x1080 in YUV 4:2:0 format to 1280x720 YUV video
ffmpeg -s:v 1920x1080 -i input.yuv -vf scale=1280:720 -c:v rawvideo -pix_fmt yuv420p output.yuv
If you want to resize to some other resolution change the width and height assigned to the parameter scale.
To compress the YUV file of resolution 1280x720, frame rate 30 fps in H.264 video format at 5 Mbps
ffmpeg -s:v 1280x720 -i input.yuv -vcodec h264 -r 30 -pix_fmt yuv420p -b:v 5000k output.h264
To compress the above video in MPEG4 video format
ffmpeg -s:v 1280x720 -i input.yuv -vcodec mpeg4 -r 30 -pix_fmt yuv420p -b:v 5000k output.m4v
where the parameters present next to the following parameters
-s:v represents input resolution
-i represents input file
-vcodec represents output codec type
-r represents frame rate of the output video
-pix_fmt represents input video YUV chroma subsampling format
-b:v represents bitrate of the output video
Image Processing with FFMPEG
The following command decompresses the JPEG image file and stores it in YUV format
ffmpeg -i image.jpg -pix_fmt yuv420p image.yuv
The following command can be used to resize the JPEG image
ffmpeg -i image.jpg -vf scale=width:height output.jpg
(or)
ffmpeg -i image.jpg -vf scale=1280:720 output.jpg
The following command can be used to convert JPG image to BMP image format
To make individual still images from the compressed video
To make individual still images from the YUV file
ffmpeg -s:v 1280x720 -pix_fmt yuv420p -i inputyuvfile %03d.jpg
To make individual still images from the YUV file with good quality
ffmpeg -s:v 1280x720 -pix_fmt yuv420p -i inputyuvfile -q 1 %03d.jpg
FFMPEG can also be used to convert/transcode audio files compressed with MP3 codec to AAC using the following command
ffmpeg -i input.mp3 -c:a libvo_aacenc -b:a 128k output.m4a
(or)
ffmpeg -i input.mp3 -acodec aac -ab 128k -strict experimental output.m4a
-c:a or -acodec represents output codec type
-b:a or -ab represents bitrate of the output audio
ffmpeg -i input.mp3 output.wav
To compress the uncompressed raw PCM audio samples in wav file to compressed MP3 & AAC format use the below commands
ffmpeg -i input.wav -c:a mp3 -b:a 128k output.mp3
ffmpeg -i input.wav -c:a libvo_aacenc -b:a 128k output.m4a
(or)
ffmpeg -i input.wav -acodec aac -ab 128k -strict experimental output.m4a
Combining Audio and Video files
Suppose if we have video and audio in elementary stream format and we can use the following command to mix them
ffmpeg -i videofile -i audiofile -c:v copy -c:a copy -strict experimental output.mp4
The above command does not perform any processing on the audio and video samples when we use -c:a copy and -c:v copy. It simply copies the contents and packs them in the MP4 container.
TV not playing audio for certain files
Often we would have seen certain TV's while playing videos fail to play audio. Use the following command to fix this issue. Almost all of the TV support AAC audio format and the following command converts the audio to AAC format, stores both the video and AAC audio in MP4 container format.
ffmpeg -i inputfile -vcodec copy -acodec aac -ab 128k -strict experimental outfile.mp4
Capture uncompressed videos from webcam with FFMPEG
ffmpeg -f video4linux2 -r 30 -s 640x480 -i /dev/video0 output.avi
If the above command is executed on Laptop /dev/video0 by default selects the Integrated webcam. To capture from external webcam on Laptop change it to/dev/video1.
- Comments
