Removing Revision clouds on a PDF
Started by 5 years ago●204 viewsSo I have just started working as a document controller and part of my job is to edit AutoCAD drawings and up rev them. Sometimes I would have to delete revision clouds from a CAD drawing which I would do on AutoCAD however I have a bunch of documents that I could only find a PDF file for and no CAD file. The problem with these drawings is that I need to remove revision clouds from them before I could upload them to be accepted for AS Built. Is there any way to remove revision clouds from a PDF file or will I have to use paint or something like Photoshop to try and remove the revision clouds? youjizz pornhub tubegalore
