Hello group, I have a question regarding minimum phase system and causal enforcement. For a minimum phase system, the measured discrete frequency domain data are given. To remove the measurement noise, I use the -hilbert(log(abs(H(F))) to generate the phase of the system, and then get time domain waveform through h(t) = IFFT(abs(H(F))* exp(j*phi(F))). I found h(t) is not causal. From the text book, it says the minimum phase system is causal and stable. I don't understand it's not causal in my case. thanks a LOT and admiration to anyone able and willing to answer,
enforce minimum phase using hilbert transform
Started by ●February 18, 2009
Reply by ●February 19, 20092009-02-19
I am not sure what you mean by: "To remove the measurement noise, I use the -hilbert(log(abs(H(F))) to generate the phase of the system" But have you tried using the matlab's rceps function to generate a MP version of your signal it seems to be doing something similar to what you have attempted)? : http://www.mathworks.com/access/helpdesk/help/toolbox/signal/index.html?/access/helpdesk/help/toolbox/signal/rceps.html&http://www.google.com/search?hl=en&q=cepstrum+minimum+phase&aq=f&oq=
